I just fried one of my 1C's. Like literally, smoke. See pic...
24
    Toolfan66 Posts: 17,984
    edited July 2011
    That sucks!!! But I had to save that pic in my photos..
  • headrott
    headrott Posts: 5,496
    edited July 2011
    That is an awesome photo (as photos go). Not an awesome situation though.:frown: I am glad you have the replacement drivers on hand already. Definately JB weld, etc. them before installing them. Keep us posted on the recovery.
    Greg
  • CoolJazz
    CoolJazz Posts: 572
    edited July 2011
    The older repair techs can tell you how often this happens when you mix a tube preamp and a SS power amp.
    The output blocking cap on the preamp stage can and will let thru a blip of DC as it charges up upon power up. You get by with it some and then again sometimes not. It's just that much more important to try and remember the correct power up sequence. Mixing a really potent amp like a Krell increases what can be driven into the poor little voice coils.
    Hope the amp is ok and you get the speakers straightened out! Thanks for sharing the picture...it's a great cautionary story for all!!
    CJ
    A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
    More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping."
  • headrott
    edited July 2011
    CJ, maybe you could give everyone who's interested a rundown of the correct power up/down sequences. From what I understand it would go (at power up): source, DAC (if there is one), pre-amp, amp. Or, basically lower power (current) gear to higher power gear. Then, the opposite would be true at power down: amp, pre-amp, DAC, source(s). Sound about right? I know this is a little off topic from the OP, but still relavent and useful.
    Greg
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited July 2011
    What were you playing? Smoke on the Water or Purple Haze? Talk about realistic sound!
  • FTGV
    FTGV Posts: 3,650
    edited July 2011
    CoolJazz wrote: »
    Yes any direct coupled design will pass or even amplify the DC doing the voicecoils no good at all.
    headrott wrote: »
    Greg
    Always amp on last off first.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited July 2011
    RuSsMaN wrote: »
    That is one of the coolest pics EVER.
    Damn I was thinking the same. :smile:
    BTW anytime a speaker does that, your amp died. IHMO. The amp died placed one of the buses voltage out so the speaker could have seen 40v to 80vdc. Blowing the speaker up.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • quadzilla
    quadzilla Posts: 1,543
    edited July 2011
    nspindel wrote: »
    I already have the armacell. Is there a thread showing pics of installing it? The stuff isn't thick enough to cut a full size round piece from a template. So what do you do? Cut it into thin strips and then curl it around the drivers?
    That's how I did it. Measure the circumference of the speaker, then cut a piece about 1/2 inch longer. Use a razor knife and a straight edge to split that into 4 strips lengthwise. Make sure you have a fairly hard backing, because you need to put a lot of force on the straight edge as you move it. Otherwise, the armacell will tend to chunk instead of forming nice strips. I applied mine to the back of the speaker.
    For the tweeters, Just cut a rectangle that fits in in the tweeter hole, then cut a piece of paper the same size and run a pencil held so the side of the lead is against the paper with the paper in the cutout, and gently run it all over the paper until you have the outline of the tweeter cutout. Then just trim that out of the paper and use that to cut the hole for the tweeter in the armacell. That can be applied directly into the tweeter cutout or to the back of the tweeter.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • FTGV
    FTGV Posts: 3,650
    edited July 2011
    disneyjoe7 wrote: »
    Entirely possible as looks like a considerable amount DC was involved.
  • nspindel
    nspindel Posts: 5,343
    edited July 2011
    Wow, I really hope I didn't damage the Krell. That would definitely not leave me with a positive attitude.
    nooshinjohn Posts: 25,877
    edited July 2011
    I hope the Krell is ok too, but I do know there are a few models that are known for this. Reminds me nostolgic for the of old "Flame Linear" amps... ahhh the memories!:eek::redface::wink:
  • dkg999
    dkg999 Posts: 5,647
    edited July 2011
    I love the smell of audio smoke in the morning :eek:
    DKG999
  • FTGV
    FTGV Posts: 3,650
    edited July 2011
    nspindel wrote: »
    As I suggested previously a check for DC at the outputs is prudent.
  • nspindel
    edited July 2011
    So what do I do? Power up the amp and lay the red/black's of the meter across the same colored speaker posts for each channel?
  • FTGV
    FTGV Posts: 3,650
    edited July 2011
    nspindel wrote: »
    Yes without speakers or preamp hooked up and meter set to DC mv scale you touch the probes to the binding posts.Repeat for other channel.Typically it should be less than 50mv or so.
  • nspindel
    edited July 2011
    ok, thanks. i'll update later.
  • dpowell
    dpowell Posts: 3,081
    edited July 2011
    nspindel wrote: »
    So sorry this happened. I sure hope it never happens on my 1C's. Had to bring the picture to the second page. Too cool to have to go through the hassle of clicking back to the beginning of the thread. :rolleyes:
  • michaeljhsda2
    michaeljhsda2 Posts: 2,200
    edited July 2011
    nspindel wrote: »
    Yes. I just installed it a few minutes ago on a MW6511 and it curls around it perfectly. I'm redoing all of the MW's, PR's and tweeters with Armacell and getting rid of the mortite!!! While I'm at it, I'm replacing the threaded wood inserts and installing hurricane nuts on every bolt hole including the tweeters (no more wood screws!!!) My buddy has the 1.2's and the tweeters are bolted in...damn solid). Of course it works great on the crossover plates on the 1.2 TL's as well.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • dpowell
    edited July 2011
    FTGV wrote: »
    Thanks! learned something new and have already instructed the wife on proper system power on/off. I'd hate for this to happen to her when I'm at work.:eek:
  • nspindel
    edited July 2011
    Well, things are looking good. Did the dynamat, armacell, and jbweld mods today. So lucky I had a spare set of drivers, although I still need to get replacements. Everything is back together.
    I just ran my meter across the Krell. I'm seeing 54 mV DC on the left channel, and 36mv DC on the right. Curiously it was the right speaker that blew.
    Ok, getting ready to power everything up. Fingers crossed...
    edited July 2011
    nspindel wrote: »
    Don't forget one of these:tongue:...
    edited July 2011
    If it was me I would have bought a cheaper pair of speakers off craigslist to do some testing..
  • nspindel
    edited July 2011
    AND I AM BACK IN BUSINESS!!!! :cool:
    Everything working perfectly. Thanks everyone for the advice. A good lesson learned, and I finally motivated on the mods I've been procrastinating. Now that the right speaker is back, I'll do the mods to the left this week.
    WHEW!!!!
    edited July 2011
  • michaeljhsda2
    edited July 2011
    nspindel wrote: »
    WHEW!!!!
    Cool. Keep a fire extinguisher nearby from now on.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • FTGV
    FTGV Posts: 3,650
    edited July 2011
    nspindel wrote: »
    Awesome! glad your all fixed up.
  • jim 249
    jim 249 Posts: 347
    edited July 2011
    Glad to see it fixed! Now the real worry is why did it burn in the first place.
  • FTGV
    FTGV Posts: 3,650
    edited July 2011
    jim 249 wrote: »
    It was covered in these posts.
    FTGV wrote: »
    My guess is that when he switch on his preamp it sent a DC voltage spike that the amp then sent to the woofers voicecoils,which if high enough in level will destroy them.Being a tube pre it will have DC blocking coupling caps at it's output but if they had insufficient time to charge fully(such as at turn on) or leaky ,DC can be passed to the amp.For this scenario to happen the amp would need to be a directly coupled design,I'm assuming it is.
    CoolJazz wrote: »
  • disneyjoe7
    edited July 2011
    Nice too hear you're back in business.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • nspindel
    edited July 2011
    brgman wrote: »
    If you cannot find old 10's and 11's i have a couple new style from current polk stock if you want them.
    How are the new 10's and 11's? Wondering if I should just buy new ones for the rebuild of the CRS+'s, or do I want to be searching for the originals?
