I just fried one of my 1C's. Like literally, smoke. See pic...
nspindel
I'm no electrical engineer, but I think this is bad. Very very bad.
I made the mistake of powering up my amp before I turned on the tube preamp. When I switched the preamp from headphones to line output, there was a pop noise, and then....
I'm pretty sure all four drivers are fried. One is literally burnt to a crisp, the other ones are not moving in and out well.
Can someone help me out with the steps to diagnose exactly what I fried here? How can I test out the crossovers? And the tweeters?
Damn. This ain't good...
Post edited by nspindel on
DAMN! When you do something you do it BIG!!Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Sucks to be you right now, sorry that happened! I need a checklist myself to keep me from making a big "pop" with my setup.:frown:
The good news, if there's any positive to be found here, is that I have a pair of CRS+'s that I haven't even started rebuilding yet, so I can poach the 6510's and 6511's from them, so I have the four replacement drivers in hand already, although will need new ones for the CRS+'s. I just need to know how to test the crossovers before I power anything up again.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
Proceed slowly & cautiously...... and good luck.
Damn that sucks! But uhhh take more pics! :biggrin:--Gary--
Sorry dude, smoke's all gone, show's over...Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
If you cannot find old 10's and 11's i have a couple new style from current polk stock if you want them.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Yeah, I meant take pics of the burnt drivers.
:rolleyes: --Gary--
The smoke looks to be from the voicecoils ,I suspect they protested so loudly because they recieved a large spike of DC.Get your credit card ready.
Not to be a dunce ...but can someone explain what happened so I or anyone else don't repeat
thanks
Or was this a volumn issue2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
My guess is that when he switch on his preamp it sent a DC voltage spike that the amp then sent to the woofers voicecoils,which if high enough in level will destroy them.Being a tube pre it will have DC blocking coupling caps at it's output but if they had insufficient time to charge fully(such as at turn on) or leaky ,DC can be passed to the amp.For this scenario to happen the amp would need to be a directly coupled design,I'm assuming it is.txcoastal1 wrote: »Not to be a dunce ...but can someone explain what happened so I or anyone else don't repeat
thanks
Or was this a volumn issue -
Ugh! Sorry about your misfortune, Neil, but I gotta say, you've got a great attitude! You got handed a bunch of lemons and you're already figuring out how to make lemonade!
Good luck getting it all straightened out, but I've no doubt you'll be fine. I'm sure you'll get all the help you need here.
Later,
Ed -
More good news, as good news goes here. Took everything apart, the tweeters have a dcr of 6.4 ohms each, and I can't find any evidence of burn marks on any of the Sonicaps, and meter readings don't show any shorts, resistors measure ok, etc. Drivers, different story. Three out of the four read dead on my meter, and the fourth is quite seized up even though it still shows a meter reading.
So I'm going to look at the bright side here. First of all, I've been procrastinating pulling these apart anyway to do the mortite, jb weld, dynamat, and rings. Well, now one of them is already pulled apart. Also, it looks like I only need to replace the four drivers, and I'm fortunate enough to have a complete set of spares on hand.
So I guess it's time to further mod my 1C's!Good music, a good source, and good power can make SDA's sing. Tubes make them dance. -
The caps in series with the tweets saved them,the woofers have no such line of defense.
So the problem only occured on one side? -
I'm pretty sure that nothing happened on the other side. Well, I didn't see any smoke, let's put it that way. I haven't tested it yet, but as long as I have some mods to do I'll measure everything when I pull it apart.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
That is one of the coolest pics EVER.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
Before using the amp and preamp again I would be putting a meter on their respective outputs to verify that there is not an excessive amount of DC offset present.(ie less than 50mv.)
Wow, sorry that happened. :frown:
I can count on 2 hands how many times I turned my system on, only to be reminded of where the volume knob had been moved to. Luckily I never had what happened to you happen to me. I did have a shorted balance knob blow up a RT3000p tweeter once. The other speakers handled the short real well. That sound might just be the loudest noise I've ever heard from a set of speakers..:eek:..It was like a bomb went off right in front of me..My wife even came running to the room to see if I was all right and to ask what the heck happened.:eek:This smilie was how she looked for real. I might have looked like it too.:eek:
I guess your experience was a quick pop and a quick sizzle of sorts?
Again, sorry for your misfortune in this case. I agree with others, you have a great outlook about this.
I'm pretty sure I'm lucky enough here that I can actually laugh at that. I actually think it's pretty funny that as my speaker was smoking like that, my first instinct was to take a picture of it to show all of you characters:cool:Good music, a good source, and good power can make SDA's sing. Tubes make them dance. -
Will do.Good music, a good source, and good power can make SDA's sing. Tubes make them dance. -
Took the words outa my f'n budlight stankin mouth .I love this pic and it should be put on a sticky for setting up precautions -
Toobes rule, right? Nice big DC spikes to the woofs and they go woof!My guess is that when he switch on his preamp it sent a DC voltage spike that the amp then sent to the woofers voicecoils,which if high enough in level will destroy them.Being a tube pre it will have DC blocking coupling caps at it's output but if they had insufficient time to charge fully(such as at turn on) or leaky ,DC can be passed to the amp.For this scenario to happen the amp would need to be a directly coupled design,I'm assuming it is.
nspindel, great attitude toward your miss fortune! I guess you see your glass as still half full.DARE TO SOAR:
awesome pic... did it smell too?PolkFest 2012, who's going>?
sorry for your misfortune--bummer-- what amp/pre was in use please sir/ Best of luck for a speedy recovery.
JC approves....he told me so. (F-1 nut) -
I called a haz-mat team for you, and they should be there shortly:biggrin:
try the Armacell on the new drivers instead of moretite. It does a better job of sealing to the baffle without any of teh complications that come from moretiteThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
danger boy wrote: »awesome pic... did it smell too?
Stunk!Good music, a good source, and good power can make SDA's sing. Tubes make them dance. -
nooshinjohn wrote: »try the Armacell on the new drivers instead of moretite. It does a better job of sealing to the baffle without any of teh complications that come from moretite
+1. http://www.homedepot.com/buy/plumbing-pipe-insulation/armacell-armaflex-2-in-x-30-in-r-1-foam-insulation-tape-153843.htmlSDA SRS 2.3TL's
SDA 2B TL's -
I already have the armacell. Is there a thread showing pics of installing it? The stuff isn't thick enough to cut a full size round piece from a template. So what do you do? Cut it into thin strips and then curl it around the drivers?Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
Thats just... Depleating...
Nope. It's an opportunity to further improve my already great speakers.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
