Anyonw tried these wires?Golden Parallel Speaker Cables from Mapleshades
13»
  • ohskigod
    ohskigod Posts: 6,505
    edited May 2011
    oooh, another cable debate, haven't had one of those in a while..lol
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • TouchOfEvil
    TouchOfEvil Posts: 967
    edited May 2011
    ohskigod wrote: »
    Thats the thing, i didn't ask for a debate i asked if members had tried that wire and how they liked it/recommend it or something else based off them using it. However it did not turn out that way with the exception of i think 3 or 4 post.
    Living Room Rig:D
    Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
    Xbox360/PS3/WII
    M.Br. setup:)
    Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
    Computer Rig:
    Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
    Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
  • dorokusai
    dorokusai Posts: 25,576
    edited May 2011
    I did and do not care for the Mapleshade brand at all. They don't have the overall dynamics that my current MIT have and it may be superficial but the aesthetics are simply awful. The smaller, less high end rig I used them in sounded as good as the low/mid Audioquest that were installed although the low end sounded very thin....a lot like Nordost to me.
  • TouchOfEvil
    edited May 2011
    dorokusai wrote: »
    Thanks for the feedback Doro. What wire would you suggest under 3bucks a foot for my surrounds? I'm gonna end up with at least 30foot runs for each speaker maybe a tad more.
    Living Room Rig:D
    Xbox360/PS3/WII
    M.Br. setup:)
    Computer Rig:
  • dorokusai
    edited May 2011
    www.signalcable.com
    The Classic Speaker Cable....is as low as I go and the standard, starter brand for everything I do. I don't like nor use Monoprice, BJC or anything in that bracket. It's more than $3/ft....and I'm sure you can find something that is more in line with your requirement.
  • TouchOfEvil
    edited May 2011
    dorokusai wrote: »
    www.signalcable.com
    thanks, i was looking at their cables earlier today. Polkies still get a discount from signal don't they? I gotta get em to make me a power cord for my amp. Won't need a 6foot cord once i move, might just have to get everything all at once from signal.:smile:
    Living Room Rig:D
    Xbox360/PS3/WII
    M.Br. setup:)
    Computer Rig:
  • dorokusai
    edited May 2011
    Yes, you still get a discount which usually ends up being free shipping depending on how much and what you purchase.
  • TouchOfEvil
    edited May 2011
    dorokusai wrote: »
    Thank you sir.
    Living Room Rig:D
    Xbox360/PS3/WII
    M.Br. setup:)
    Computer Rig:
