Anyonw tried these wires?Golden Parallel Speaker Cables from Mapleshades
TouchOfEvil
TouchOfEvil Posts: 967
I'm going to need runs of roughly 30foot give or take a little for my surrounds. This wire will be running to my lsi7's.
Anyone tried this wire before and if so how did you like it? Would you recommend it or is there something else i should be looking at?
http://shop.mapleshadestore.com/Golden-Parallel-Speaker-Cables/productinfo/PARALLEL/
Living Room Rig:D
Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
Xbox360/PS3/WII
M.Br. setup:)
Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
Computer Rig:
Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
«13
  • BlueFox
    BlueFox Posts: 15,250
    edited April 2011
    I have not used that specific wire, but do have the Clearview Double Helix Plus in my HT, and it definitely is an upgrade over hardware store stranded, twisted copper 12 gauge. At first I had this cable in my two channel, and it convinced me cables do make a difference. I was amazed at the detail that came out after installing it. Later, I upgraded the two-channel to their sister company, Omega-Mikro, Planar I, and then V cables.
    After the two-channel upgrade, I ordered more Double Helix for the surround and center channel speakers in the HT. Good move.
    http://shop.mapleshadestore.com/Double-Helix-Speaker-Cable-with-PLUS-Upgrade/productinfo/DHELIX-PL/
    One other tweak on the HT was installing MIT CVT Terminator 1 between the pre[pro and the amp. Along with the Mapleshader speaker wire I love the detail in the sound for both HT, and multi-channel SACD.
  • TouchOfEvil
    edited April 2011
    Thanks for posting blue. I'm only looking for wire for my surrounds at the moment. I'm more than happy with the mains but on the surrounds i currently have like 14foot runs and will need around 30foot runs once i move in a month. Also looking to upgrade the wire as i'm currently using monoprice 12gauge for em.
    Living Room Rig:D
    Xbox360/PS3/WII
    M.Br. setup:)
    Computer Rig:
  • TouchOfEvil
    edited April 2011
    nobody else has anything to add.:frown:
    Living Room Rig:D
    Xbox360/PS3/WII
    M.Br. setup:)
    Computer Rig:
  • ROHfan
    ROHfan Posts: 1,014
    edited April 2011
    Yes, I do. What a waste of hard-earned money.
    TV: 65" Samsung QLED 4K
    AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier
    heiney9 Posts: 25,713
    edited April 2011
    ROHfan wrote: »
    Re-read the OP, I don't think he asked YOU to pass judgment. I am certainly not passing judgment on you about..............:rolleyes:
  • jinjuku
    jinjuku Posts: 1,523
    edited April 2011
    Find out the return policy there. Purchase them along with some Belden 5000u and compare.
    Not sure if the LSi 7's are a done deal or not but I would take that $250 the cables cost and upgrade to the 9's.
    I would put the 9's on Belden up against the 7's with 'Golden Parallel' any day of the week.
  • ROHfan
    ROHfan Posts: 1,014
    edited April 2011
    heiney9 wrote: »
    I added my opinion on expensive cables--I think they're a waste of money. I did not pass judgment about the poster like you so graciously refrained from doing to me...:tongue:
    edited April 2011
    So you have tried these particular cables against "cheaper" cables, and you drew your own conclusion? Or, you just rally against anything you feel is over priced regardless whether you've spent any time listening to the product(s).
    Seems very logical to me :rolleyes:
  • ROHfan
    ROHfan Posts: 1,014
    edited April 2011
    heiney9 wrote: »
    I'm sorry, but I read the "warning" statement about cable burn-in on the OP's link and almost threw up. My logical conclusion is that the company is trying to dazzle me with bullsh*t so they can take my money. I think my reaction is quite logical, on the contrary. I'm not going to spend hundreds of dollars on a cable to prove a point to someone on the internet. Now that would be illogical, don't you think?
    edited April 2011
    So, just as I thought, you are basing your decision, as well as advising others, without any experience using the cable in question or for that matter any other cables that sell above your arbitrary threshold of cost which I can resonably assume is low.
    Good to know.........that certainly is a worthwhile and helpful statement :rolleyes: It's based on nothing but hot air.....you've been most helpful.
  • ROHfan
    ROHfan Posts: 1,014
    edited April 2011
    heiney9 wrote: »
    Glad I can help.
  • BlueFox
    edited April 2011
    ROHfan wrote: »
    Why are you offering an opinion when you have zero knowledge of the subject? Cable trolls are amazingly arrogant since they feel they know everything, have no problem telling people what they should or should not do, yet have absolutely no actual experience with the subject. Apparently, they get their 'opinions' from their butt. :wink:
  • ROHfan
    ROHfan Posts: 1,014
    edited April 2011
    BlueFox wrote: »
    Arrogant? Maybe, but at least I didn't stoop to name calling. Nice job!
  • Rodeo0530
    Rodeo0530 Posts: 797
    edited April 2011
    Just shut up if you aren't going to help the OP with any of this. All this BS doesn't help anyone.
    Front - Polk Audio Monitor 70
    Center - Polk Audio CS2
    Rear - Polk Audio TSi 100
    Sub - Klipsch rw-10d
    AVR - Onkyo ht-rc180
    Main Amp- Parasound HCA-2003
    Surround Amp- Sonance Sonamp 260
    Tuner- Parasound tdq-1600
    Turntable- Pro-ject Debut III USB w/upgraded platter
    IPod dock - Pure i20
    TV - Panasonic Viera tc-p46g10
    Sony Playstation 3(250GB)
    Nintendo Wii
    Power Conditioner- Panamax 5100
    Not in use-
    Polk Audio Monitor 60
    Polk Audio PSW10
    Parasound p/sp-1000
  • ROHfan
    ROHfan Posts: 1,014
    edited April 2011
    Rodeo0530 wrote: »
    You're absolutely right.
    TOE, this is what I'm using for my rear surrounds. I did some A/B comparisons using these and a friend's MITs and found no discernable difference. Yes, the MIT's were much nicer and classier looking but this was not a concern considering I was shopping for in-wall cables:
    http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10239&cs_id=1023901&p_id=2817&seq=1&format=2
  • ROHfan
    ROHfan Posts: 1,014
    edited April 2011
    Touche'
  • george daniel
    george daniel Posts: 12,096
    edited April 2011
    why not canare s411 IIRC,, Signal cable used this in their entry level cable.Just my two cents.
  • TouchOfEvil
    edited April 2011
    ROHfan wrote: »
    Who said i work hard for my money?:rolleyes:
    jinjuku wrote: »
    I would put the 9' on Belden up against the 7's with 'Golden Parallel' any day of the week.
    This is a done setup. The 7's are just surrounds not fronts. I have 15's for that and i really doubt i could get the WAF on 9's mounted to the walls lol.This is the same setup in my sig as my bedroom setup only we are moving in one month and it will become my main/living room rig.
    I'm not against them....just was looking at a few cables and thought i'd ask about em.
    Living Room Rig:D
    Xbox360/PS3/WII
    M.Br. setup:)
    Computer Rig:
  • TouchOfEvil
    edited April 2011
    Let me add i have played around with several different wires and i DO notice a difference with wires. I was going to get runs of wire to match my fronts but the company went under so i can't do that anymore. Just looking for a nice wire "under $3.00 per foot" with some good reviews/member referrals. The wire will be ran in-wall and at least 30foot maybe longer.
    Living Room Rig:D
    Xbox360/PS3/WII
    M.Br. setup:)
    Computer Rig:
  • BlueFox
    edited April 2011
    An important point I forgot to mention in post #2 is this cable is solid wire, and it is also very small. It definitely isn’t 16 gauge, or probably even 18. While it does sound good (so much for the bigger is better school of thought), it easily breaks. I found that after installing the cable if I was not careful moving the rack in/out I would break a connection. Since there are five speaker connections the odds increase that one can be broken.
    But now that I am used to it, I am not having any problems, although I know that one day another connection is going to break.
  • TouchOfEvil
    edited April 2011
    BlueFox wrote: »
    An important point I forgot to mention in post #2 is this cable is solid wire, and it is also very small. It definitely isn?t 16 gauge, or probably even 18. While it does sound good (so much for the bigger is better school of thought), it easily breaks. I found that after installing the cable if I was not careful moving the rack in/out I would break a connection. Since there are five speaker connections the odds increase that one can be broken.
    I'm glad you posted this. I think i'm gonna be going with another cable in this case. I don't want to have to worry about breaking a cable so easy. Thank you!!
    Living Room Rig:D
    Xbox360/PS3/WII
    M.Br. setup:)
    Computer Rig:
  • Hawkeye
    Hawkeye Posts: 1,313
    edited April 2011
    I've tried several levels of MS speaker and interconnects. I liked the Golden Double Helix and some flat wire RCA's the best. I've given them up as a Karma and still waiting on a review from the guy who won them:frown:
    Anyway, despite the hyperbole Pierre may write, they are a solid cable worthy of an audition in the least. I can say this since I've owned them and have tried them in my kit unlike some posters here.
    Gordon
    2 Channel -
    Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
  • Hawkeye
    edited April 2011
    ROHfan wrote: »
    Pierre does tend to overstep the bounds of real advertising but what company does not? I would think if you haven't tried this "SPECIFIC" cable, you're unqualified to comment on them. Regardless of cost or hyperbole, you're NOT qualified to discuss this line on cables. Simple, cut and dried.
    Gordon
    2 Channel -
  • robsreef
    robsreef Posts: 33
    edited April 2011
    Cable selection should be based on material and diameter. Regular copper stranded, 12ga wire will work very well.
    "Cable burn-in"....wow, it's amazing what some companies will say. I used to own a saltwater aquarium shop. You'd be amazed at some of the claims manufacturers claim in that genre.
    Most wire and interconnect claims are pretty bogus. Monster was one of the pioneers in this market, and others have used them as a starting point for their BS.
    $30 for a 3' Best Buy brand HDMI cable,$65 for the Monster, seriously? They're $4 online and just as good.
    Sorry for the rant, but had to back up the reasonable people.
    F1nut Posts: 52,406
    edited April 2011
    robsreef wrote: »
    Amateur.
  • robsreef
    robsreef Posts: 33
    edited April 2011
    LOL, to each their own.
  • TouchOfEvil
    edited April 2011
    robsreef wrote: »
    If your trying to convince me to use .50cents a foot wire your fighting a losing battle. I do and can hear the difference in wires and therefore do not need your opinion on how i should spend my money.
    Living Room Rig:D
    Xbox360/PS3/WII
    M.Br. setup:)
    Computer Rig:
  • robsreef
    robsreef Posts: 33
    edited April 2011
    My comment above was to Keiko and F1nut.
    A second look at your OP reminds me that you have no problem spending $200 on wire for $600 speakers. Sorry for the intrusion.
  • TouchOfEvil
    edited April 2011
    robsreef wrote: »
    I'm sorry my setup makes you have little man syndrome but hey guess what, they make pills for that.:cool:
    And your wrong, i only paid $300 for the lsi7's that i am currently looking for some nice wires for long runs.lol. stay mad my friend, stay mad.
    Living Room Rig:D
    Xbox360/PS3/WII
    M.Br. setup:)
    Computer Rig:
