Definitive Technology BP7000SC Mod Thread
13
  • blueboxer
    blueboxer Posts: 621
    edited April 2011
    Shipping for me would add about $300, if it ends up being the better option than so be it. The crossovers would be about $125, so not a huge difference. The main factor would be risk of damage during shipping and down time. Maybe Dan can get you a crossover quicker so the part cost can be determined first?
    VR3 Posts: 29,534
    edited April 2011
    I have a parts list already
    I am guessing parts will cost 200-600 depending on the quality you go with
  • blueboxer
    edited April 2011
    I would assume the space constraints might limit which caps you can fit and use. Are the more expensive caps the larger or smaller of the options? I am beginning to see why that one guy used external crossovers. I have an excellent granite guy, maybe that is the option to go with. lol
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited April 2011
    There's only three caps for the tweeters and mids so if one or two of the caps can get attached to the inner side walls it'll work just fine, there's plenty of room.
    VR3 Posts: 29,534
    edited April 2011
    We can keep it internal and make it awesome! Maybe even keep it on the board
    VR3 Posts: 29,534
    edited April 2011
    For the ST owners
    With ESA caps, Mills resistors -- the total comes to 388 with EVERYTHING + return shipping.
  • mantis
    mantis Posts: 17,557
    edited April 2011
    leroyjr1 wrote: »
    I took mine apart last night and discovered inner dampening material like acoustic block. Pretty cool. Seems like the one Yellow cap is about as big as it can be as far as tall is concerned.
    I have crossovers coming from Def Tech , I might even attempt this myself. I'll let you guys know when they come in.
    Dan
    VR3 Posts: 29,534
    edited April 2011
    I am going to bypass the large cap with a higher quality cap to keep space to a minimum
  • blueboxer
    edited April 2011
    LOOKs like its a race between me and Dan now. I love what these speakers can do with such little power, if these add some smooth softness on top of It this could be something special with an Inova.
    VR3 Posts: 29,534
    edited April 2011
    Hey Leroy --
    How much space is UNDER the Mythos ST board from the tweeter????
  • leroyjr1
    edited April 2011
    Hey Leroy --
    About 1/4".
    VR3 Posts: 29,534
    edited April 2011
    Pretty coils!!!
    VR3 Posts: 29,534
    edited April 2011
    All I gotta do now is put some breadboard under the inductors.... and throw some glue around on the boards and these will be project completed!!!
    VR3 Posts: 29,534
    edited May 2011
    Getting these bad boys ready for shipping!! Oh yeah!
    VR3 Posts: 29,534
    edited May 2011
    Spammers suck
    Here they are - reading for shipping. I just gotta find a box and some padding to put around the frame. I couldnt think of anyway to securely ship all three in a box so I made something to make it work!
    Ohhh yeah!
  • nadams
    nadams Posts: 5,877
    edited May 2011
    Top-notch packaging, Trey!
    Ludicrous gibs!
  • Face
    Face Posts: 14,340
    edited May 2011
    You should mail it just like that. :biggrin:
  • Outfitter03
    Outfitter03 Posts: 563
    edited May 2011
    Does it matter on these foil inductors which lead goes to the center and which to the outside? Trey did you have any issue with soldering onto these and making a good connection? I notice that one set of your inductors were not tinned. Did you have to strip or burn off the coating, or were the ends left bare copper?
    VR3 Posts: 29,534
    edited May 2011
    The smaller inductors were not tinned from the factory...
    With the Weller Digital Soldering Iron - this was a piece of cake... took just a few minutes to solder all the inductors up and the connection is super strong!
    Thanks guys!
    I thought about just getting some 1/8" plywood and putting it over the outside for shipping... I will think about it!
  • Face
    Face Posts: 14,340
    edited May 2011
    No. And with a hot iron, it's easy to make a good connection.
    VR3 Posts: 29,534
    edited May 2011
    Yep - the right tools makes the job easy!
    This was a fun project..
    I wish we could have made them externally and done some PTP action and spaced them and all that good stuff - but this will do just fine! :)
    VR3 Posts: 29,534
    edited May 2011
    Wouldnt you know it - after 10 years of shipping stuff... the thing I CRATE - put 1.5" foam padding all around, in a box - the whole nine yards get damaged?
    Who woulda thunk it..
    VR3 Posts: 29,534
    edited May 2011
    Jack sent me a picture of the 7000sc with the parts placed....
    We ordered two resistors for the one that got damaged...
  • truwarrior22
    truwarrior22 Posts: 18
    edited May 2011
    So, I've had some time to listen to the BP7000SC's with the upgraded crossovers and my feelings are mixed. It didn't work miracles, but it did seem to add more resolution and smoothness to the sound. They still have what I would call flaws as before, such as lack in lower midrange, but the best part is that when audyssey is enable, it sounds so much better then before and helps lift the lower midrange. Without the mods audyssey seemed to make the sound seem a little more edgy, harsh, and processed.
    So I'm not sure where that leaves me, I really hate having to resort to using processing to fix what I would call speaker flaws. I think if I liked how the speakers sounded before then this mod would have been more beneficial, but none the less it was an improvement.
    I haven't had time to compare my modded CLR3000 against the non-modded one, but hope to do so in the upcoming week or two. This is a speaker I liked a lot so it will be interesting how the modded one compares against the none modded one :)
    VR3 Posts: 29,534
    edited May 2011
    Sounds like you might not like where the subs are crossed with the midbasses -- maybe too high?
  • truwarrior22
    edited May 2011
    Despite what def tech states, I don't think the subs blend very well with the mids. The issues is around the 150hz+ range which is out of subwoofer range.
    I feel def tech implemented the blending better with the BP7002's. Need to copy that crossover design :)
  • truwarrior22
    edited May 2011
    Trey,
    I actually have a few pictures of a BP7002 crossover. If I sent it to you do you think you could figure out the difference is in the midbass crossovers between a BP7000 and a BP7002?
    VR3 Posts: 29,534
    edited May 2011
    Do you have pictures of the traces on the underside as well? Along with values?
    If so we can definitely give it a shot
  • truwarrior22
    edited May 2011
    I sure do, I'll send them your way!
    Thanks!
  • truwarrior22
    edited May 2011
    Email sent but here they are too. The biggest cap is a 250uf
