in-wall speaker cable?
245
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited December 2010
    Bring it is all I can say. :smile:
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
    F1nut Posts: 51,750
    mantis wrote: »
    My cravings have changed once I learned the truth that I'm deaf.
    Well, there you have it.
  • Beta
    Beta Posts: 267
    I just went through this process as I just had Polk LCi fronts, rears and a center installed in my walls. I had no idea MIT sold in-wall wire. Had I known, I would have had the MIT 12/2 AWG wire installed simply because I am a huge fan of MIT.
    At any rate, I consulted with a few folks whose opinions and knowledge I value very much. My application for the wire is strictly for HT.
    I kept getting directed back to Monoprice. Ultimately, I had Monoprice 12/2 AWG in-wall wire installed. To my ears the Monoprice works excellent for HT.
    F1nut Posts: 51,750
    mantis wrote: »
    Really? Lets see , Audioquest , sold by the foot , Cardos , sold by the foot , Kimber Kable sold by the foot , Liberty sold by the foot , Transparent sold by the foot , Belden sold by the foot ,Ixos sold by the foot any custom made wire by anyone sold by the foot. All wire is sold by the foot. The length determines the price hence sold by the foot. How do I know this? Gee lets see my company carries more wire then most people have seen in a lifetime.
    And yes I have heard in wall MIT wire many times. I'm not impressed or the least bit fooled by companies like them. You or anyone else can buy what ever you like. Good luck with all that.
    You should not speak of which you lack knowledge of.
    I don't see it that way. What I see is that for $379.99 you get 250 feet of cable. I do not see it priced as $1.52 per foot.
    http://www.crutchfield.com/p_703144250/AudioQuest-FLX-14-4-4-Conductor-14-Gauge-In-Wall-Speaker-Cable-250-feet.html?tp=1432
    When you buy an amp do you price it per watt? Let's see, amp A costs $5000.00 and puts out 100 watts, so that would be $50.00 per watt. Amp B costs $3500.00 and puts out 250 watts, so that would be $14.00 per watt. Yeah, that would be a really stupid way to buy an amp.
  • megasat16
    megasat16 Posts: 3,521
    Even though I don't fond of the idea but it's no truer than how people measure the performance of them.
    Amps performance is measured with cost per Watt.
    Wire is measured with cost per Length.
    There are millions of people who buy amps based on the Cost per Watt. You probably don't notice but it happened here on CP all days everyday since the beginning.
    They don't just call it Cost per Watt but they says 200W this and 150W that and what sounds better, blah...blah....blah....so it's essentially that way.
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • WilliamM2
    WilliamM2 Posts: 4,807
    AudioAdvisor sells some Audioquest speaker wire by the foot, so do many others. All the local dealers here also sold speaker wire by the foot, before they went under.
    http://www.audioadvisor.com/prodinfo.asp?number=AQT4B
    F1nut Posts: 51,750
    It seems that I haven't made my point clear enough, so I'll try again. If one buys cable with the price per foot in mind, they are buying it for the wrong reason.
  • WilliamM2
    Right, Mantis already covered that:
    Rule of thumb with wire is follow the American wire standard with gauge and length. Get good quality wire with proper termination. Once you achieve the ability to send the signal from A to B correctly , nothing can improve it.
    F1nut Posts: 51,750
    Two wrongs do not make a right.
  • megasat16
    Under any case, the affordability is always a concern to 99.999999999% of us.
    If anyone affords anything, we will have no reasons to argue about anything in any forum / message boards / discussion groups.
    Money unfortunately is a limited resource unless you have a printer to make your own. Of coz, Uncle Sam will pursue hot on your tail in this case.
  • mantis
    mantis Posts: 17,374
    Now you want to put words in my mouth?
    Dan
  • mantis
    Dude we are not talking about amps , wire is sold by the foot , it always has been always will be. I don't see your point man.
    Dan
  • mantis
    My man when you are running wire , you have to buy it by the foot. Like rears which is what started this entire conversation.
    When you buy 2 channel wire for a 2 channel system , you buy it by the foot. If you need a 10 foot pair , you buy it by the foot. It's just how THEY sell it. You can pick your terminations and level of wire from any company.
    I think you are taking this is a weird direction without any point behind it.
    Dan
  • mantis
    So everyone on this forum can understand you , what are the 2 wrongs that don't make it right?
    Dan
  • mantis
    megasat16 wrote: »
    You bring up a very good point. Money. Value is in the one spending it. If F1nut feels owning MIT in wall wire is worth it , it's not up to us to decide that for him. If madmax wants to buy the MIt wire and use it for rear channels , thats up to him. He asked a question and got some opinions. F1nut has taken this way out in left field.
    Bottom line is this , American wire standard. Get the job done , get it done correctly , nothing you do after this will not improve the signal getting to the speakers. As long as the wire is ran correctly , building codes are followed , you stay away from power wires and cross them when you have to be in the same area as them , if running parallel is necessary then the 6 inch rule applies. Honestly I think people get way out of hand when ever wire comes up.
    Dan
  • DMara
    DMara Posts: 1,434
    zingo wrote: »
    I have the monoprice 12g CL2 stuff and it has worked great in a number of applications; plus its crazy cheap.
    I second this. I used Monoprice 12AWG CL2 for my in-wall HT run (2 lsi15's, 2 lsiFX's, 1 lsiC) and did not have any issue with sound quality.
    Gears shared to both living room & bedroom:
    Integra DHC-80.3 / Oppo BDP-105 / DirecTV HR24 DVR /APC S15blk PC-UPS
    Living room:
    LSiM707's / LSiM706c / LSiM702 F/X's / dual JL Audio Fathom F113's / Parasound Halo A51 / Panasonic 65" TC-P65VT50
    Bedroom:
    Usher Dancer Mini 2 Diamond DMD's / Logitech SB Touch / W4S STP-SE / W4S DAC-2 / W4S ST-1000 / Samsung 52" LN52B750
    Other rooms:
    Audioengine AP4's / GLOW Audio Sub One / audio-gd NFB-3 DAC / Audioengine N22
    audio-gd NFB-10.2 / Denon AH-D7000
  • jinjuku
    jinjuku Posts: 1,523
    Let's see, bad teeth, nose full of boogers......yeah, I think it's a safe bet to say that your lack of personal hygiene means your ears are packed as well. :rolleyes:
    Well on the whole 'packing issue' I will have to defer to you since you are resident expert on fudge packing.
  • jinjuku
    mantis wrote: »
    F1 thinks that it keeps people from noticing the foot he keeps putting into his:wink:
  • jinjuku
    mantis wrote: »
    Mantis, I don't think he realizes that the numeric markings on the wire are inch indicators.
    F1nut Posts: 51,750
    mantis wrote: »
    Yes, that is obvious. I'll repost my comment so that you can give it some further thought.
  • TroyD
    TroyD Posts: 13,124
    Why is MIT such a controversial alternative? Chuck didn't ask what they cheapest was.....and, those of us that know him and love him know that Chuck is serious about his hifi.
    If I had the coin, I'd go MIT. I own MIT products (as does Chuck) so I have no reason not to recommend them either.
    BDT
  • Face
    Face Posts: 14,340
    If it's for the surrounds only, I'd go with something from Blue Jeans. For the center, I'd recommend something similar to what you're using for mains.
    F1nut Posts: 51,750
    This pro audio studio is wired with MIT cables.
    I'll bet they weren't told the cable would run them $****.xx per foot.
  • disneyjoe7
    I felt there's many Studio's that are wired with Belden cables also.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • DMara
    DMara Posts: 1,434
    War happened whenever suggestions on amps & cables were asked for :biggrin:
    Living room:
    Bedroom:
    Other rooms:
  • kevhed72
    kevhed72 Posts: 5,140
    jinjuku wrote: »
    Folks, I think the forum has hit an all-time low...and the day after X-Mas! :eek:
  • mantis
    Dude I don't get it , why are you so Anti by the foot pricing with wire? The Highest end wire in the world is sold by the foot bro. it doesn't make it Home depot wire. I love wire as much as the next guy but this by the foot thing of yours is silly. It's actually funny.
    Really dude , you found a home with MIT. Its cool man they make nice looking wire. But I bet if you give them a call and ask if they sell their wire priced by the foot , you will be shocked in their answer. Just keep a bottle near you so you can wallow in your pain. And if that doesn't work I know a good shrink.:cool:
    Dan
  • madmax
    madmax Posts: 12,434
    TroyD wrote: »
    BDT
    I want whatever he was smoking!
    Vinyl, the final frontier...
    tonyb Posts: 33,072
    mantis wrote: »
    I find this statement somewhat disturbing comming from you Dan. You have some darn good experience with a variety of gear and to not hear you treat cables with the same zest you do with gear, well, disheartening is all.
    Home depot 12 ga. will get a signal from point A to point B very well but to think that cable can't be improved on, is as far from the truth as one can imagine.
    Jess's point was you buy cable for the SQ it offers, not the price per foot ratio.
    I like to view cables as a piece of gear itself. Just as important to a system as a whole.
  • disneyjoe7
    tonyb wrote: »
    Yes I understand, but if cables are ran behind the walls where you can't see them would cable A, B, or C be better?
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
