Sunfire TGP-401 No Sound ?
tbui2007
hey guys, i just bought a sunfire tgp-401 processor and hook it up with a Sony blu-ray dvd player? i don't know why i'm not getting any sounds. I talk to Sunfire technical support and he told me that the HDMI is for the pictures only but not for sounds. That's kind of strange because i always thought hdmi is for both. Am i missing something with this processor? Can someone verify this?
LSI15 Front LSIC Center Lsi7 Rears Lsi7 Sides DSW600
Sony S560 Blu-Ray DVD
Sony 46W5100
Monster HTS-3600
Sunfire TGP-401 Pre
Sunfire Grand 200x7
Sony 46W5100
Monster HTS-3600
Sunfire TGP-401 Pre
Sunfire Grand 200x7
Post edited by tbui2007 on
some of the older equipment only used HDMI for video as in HDMI 1.0.
If you called Sunfire and that is what they said well then that is what they did. -
The Sunfire supports video only over HDMI, so you will need to run an optical out for the audio portion, or the analog outputs. I find the Sunfire sounds better than my old Yamaha reciever did, and it had full support of HDMI.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Thanks for the inputs, i wish i knew about it before i spend $1500 for it. I can't believe that a processor worth $3000 won't fully support HDMI. I guess i just have to find a better blu-ray with 7.1 analog.LSI15 Front LSIC Center Lsi7 Rears Lsi7 Sides DSW600
Sony 46W5100
Monster HTS-3600
Sunfire TGP-401 Pre
Sunfire Grand 200x7 -
I knew the TGP V was that way but thought they upgraded to HDMI 1.3 in the 401. Guess I assumed incorrectly.
You still have a great unit even though it does not do exactly as you thought. They are well known for sounding great in 2 channel and in HT modes.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t -
The optical out should provide all the connectivity you need. I too was suprised that the Sunfire did not fully support HDMI, but the overall performance has more than made up for that shortcoming. If I can help at all, just let me know. I have the TGP mkV which is exactly the same thing as yours, minus the updated cosmetics.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Good luck, most have done away with the analog outputs on BDP's. You may have to go used if you don't want to break the bank. Why don't you just re-sell the Sunfire and buy the right processor you need ? Also keep in mind when useing the analog outputs on a BDP, which are 5.1 btw, you need all the speakers. In other words, if you don't have a center channel, you lose that info,or if you don't have a sub, you'll lose that info. Only in the digital domain does AVR's or Processors re-route signals for speakers you may not have. Ooops, just saw in your sig you have 7.1, the only problem I see going analog, is that most on BDP are 5.1, so your sides won't get sound. But if it was all by way of HDMI, the processor will take care of that, see what I'm sayin' ?HT SYSTEM-
lsi 9's -
Yeah I know u mean. I have an onkyo 805 that I use prior to updating to the sunfire. I thought it would be a big jump but just a little unexpected with the hdmi. But it's ok though, I'm going buy a blu-ray 3d with 7.1 analog output, hopefully it will turn out the way it should perform.LSI15 Front LSIC Center Lsi7 Rears Lsi7 Sides DSW600
Sony 46W5100
Monster HTS-3600
Sunfire TGP-401 Pre
Just get an optical out from your current BluRay and connect it to the optical input on the Sunfire. I even have a couple I will send you if you like.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
nooshinjohn wrote: »Just get an optical out from your current BluRay and connect it to the optical input on the Sunfire. I even have a couple I will send you if you like.
Oh thanks. I got one optical cable. I'll test it out laterLSI15 Front LSIC Center Lsi7 Rears Lsi7 Sides DSW600
Sony 46W5100
Monster HTS-3600
Sunfire TGP-401 Pre
Why does he need that John, if he's going analog ? The BDP, when useing the analog outputs does all the decoding.
I don't know of any Blu-ray discs as of yet that are 7.1.HT SYSTEM-
lsi 9's -
the optical out handles the audio while the HDMI takes care of the video. This eliminated the need to buy or change anything else in his setup. Mine is set up this way and the performance is fantastic in either 5.1 or 7.1.
There are a handful of 7.1 discs out there, but literally I can count them all on one hand.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
The real pisser is getting a new toy home, hooking it up, and boom nothing happens2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
nooshinjohn wrote: »the optical out handles the audio while the HDMI takes care of the video. This eliminated the need to buy or change anything else in his setup. Mine is set up this way and the performance is fantastic in either 5.1 or 7.1.
Yes but he won't get the new audio codecs this way. If he's useing analog,he will, thus negateing the need for an optical cable.HT SYSTEM-
lsi 9's -
Bingo. Analog connections are the way to go.
The new Oppo BDP-93 has analog connections for 7.1 & is $499. If you can pick up the older BDP-83 used they have the same connections.TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer
