Sunfire TGP-401 No Sound ?
tbui2007
tbui2007 Posts: 128
edited December 2010 in Troubleshooting
hey guys, i just bought a sunfire tgp-401 processor and hook it up with a Sony blu-ray dvd player? i don't know why i'm not getting any sounds. I talk to Sunfire technical support and he told me that the HDMI is for the pictures only but not for sounds. That's kind of strange because i always thought hdmi is for both. Am i missing something with this processor? Can someone verify this?
LSI15 Front LSIC Center Lsi7 Rears Lsi7 Sides DSW600
Sony S560 Blu-Ray DVD
Sony 46W5100
Monster HTS-3600
Sunfire TGP-401 Pre
Sunfire Grand 200x7
Post edited by tbui2007 on
    pitdogg2 Posts: 27,557
    some of the older equipment only used HDMI for video as in HDMI 1.0.
    If you called Sunfire and that is what they said well then that is what they did.
    nooshinjohn Posts: 26,064
    The Sunfire supports video only over HDMI, so you will need to run an optical out for the audio portion, or the analog outputs. I find the Sunfire sounds better than my old Yamaha reciever did, and it had full support of HDMI.
  • tbui2007
    tbui2007 Posts: 128
    Thanks for the inputs, i wish i knew about it before i spend $1500 for it. I can't believe that a processor worth $3000 won't fully support HDMI. I guess i just have to find a better blu-ray with 7.1 analog.
    Sony 46W5100
    Monster HTS-3600
    Sunfire TGP-401 Pre
    Sunfire Grand 200x7
  • thuffman03
    thuffman03 Posts: 1,325
    I knew the TGP V was that way but thought they upgraded to HDMI 1.3 in the 401. Guess I assumed incorrectly.
    You still have a great unit even though it does not do exactly as you thought. They are well known for sounding great in 2 channel and in HT modes.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
    The optical out should provide all the connectivity you need. I too was suprised that the Sunfire did not fully support HDMI, but the overall performance has more than made up for that shortcoming. If I can help at all, just let me know. I have the TGP mkV which is exactly the same thing as yours, minus the updated cosmetics.
    tbui2007 wrote: »
    Good luck, most have done away with the analog outputs on BDP's. You may have to go used if you don't want to break the bank. Why don't you just re-sell the Sunfire and buy the right processor you need ? Also keep in mind when useing the analog outputs on a BDP, which are 5.1 btw, you need all the speakers. In other words, if you don't have a center channel, you lose that info,or if you don't have a sub, you'll lose that info. Only in the digital domain does AVR's or Processors re-route signals for speakers you may not have. Ooops, just saw in your sig you have 7.1, the only problem I see going analog, is that most on BDP are 5.1, so your sides won't get sound. But if it was all by way of HDMI, the processor will take care of that, see what I'm sayin' ?
  • tbui2007
    tbui2007 Posts: 128
    tonyb wrote: »
    Yeah I know u mean. I have an onkyo 805 that I use prior to updating to the sunfire. I thought it would be a big jump but just a little unexpected with the hdmi. But it's ok though, I'm going buy a blu-ray 3d with 7.1 analog output, hopefully it will turn out the way it should perform.
    Sony 46W5100
    Monster HTS-3600
    Sunfire TGP-401 Pre
    Sunfire Grand 200x7
    tbui2007 wrote: »
    Just get an optical out from your current BluRay and connect it to the optical input on the Sunfire. I even have a couple I will send you if you like.
  • tbui2007
    tbui2007 Posts: 128
    Oh thanks. I got one optical cable. I'll test it out later
    Sony 46W5100
    Monster HTS-3600
    Sunfire TGP-401 Pre
    Sunfire Grand 200x7
    Why does he need that John, if he's going analog ? The BDP, when useing the analog outputs does all the decoding.
    I don't know of any Blu-ray discs as of yet that are 7.1.
    the optical out handles the audio while the HDMI takes care of the video. This eliminated the need to buy or change anything else in his setup. Mine is set up this way and the performance is fantastic in either 5.1 or 7.1.
    There are a handful of 7.1 discs out there, but literally I can count them all on one hand.
    txcoastal1 Posts: 13,519
    The real pisser is getting a new toy home, hooking it up, and boom nothing happens
    Yes but he won't get the new audio codecs this way. If he's useing analog,he will, thus negateing the need for an optical cable.
  • TNRabbit
    TNRabbit Posts: 2,168
    tonyb wrote: »
    Bingo. Analog connections are the way to go.
    The new Oppo BDP-93 has analog connections for 7.1 & is $499. If you can pick up the older BDP-83 used they have the same connections.
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
