I pulled the trigger...
I'm gonna' replace all the caps and resistors except for and unless I can find a suitable replacement for the 5Uf Hovland in the tweeter circuit. I'm considering sonicaps and dueland ,,any suggestions are always appreciated.JC approves....he told me so. (F-1 nut)
Be sure to give them a little time to break in before making any impressions.Vr3MxStyler2k3 wrote: »What all are you replacing in the chain George?
I hope my binding post arrive today I would love to hear what this all sounds like lol
http://www.partsconnexion.com/capacitor_film_duelund_pio_speaker.htmlgeorge daniel wrote: »I'm gonna' replace all the caps and resistors except for and unless I can find a suitable replacement for the 5Uf Hovland in the tweeter circuit. I'm considering sonicaps and dueland ,,any suggestions are always appreciated.
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
waaaaaaaaaaaa-- 3400.00 for that cap-- maybe I can get one this year,,and wait and do the other speaker next fall,,,,, ,, on a more serious note-- any other suggestions for a good 20 watt resistor.JC approves....he told me so. (F-1 nut)
Depends on where it's being used. In series with a driver, parallel 2 Duelund resistors. In parallel with a woofer or mid: http://www.partsconnexion.com/resistors_mills_mrc.html"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Thanks Face-- I'll look inside again,,IIRC the two resistors in series are in the tweeter circuit,,they are the 20 watt Eagle brand.JC approves....he told me so. (F-1 nut)
Cap values are 4 uf(400 volt),,31 uf,, 12 uf,,the 31 and 12 are 100 volt caps,,I'm gonna shop around cause I've always used sonicaps in crossovers,,Trey,, sorry for stomping on your thread,,I really like your idea about the external crossovers,please post pic's when you are finished --please and thanks--george
JC approves....he told me so. (F-1 nut) -
Hey George I only see eagle resistors that are 10 watts.
Also, on my binding post the wire was oxidizing (silver plated copper) so might want to check your wiring as well...
I ran all new internal wiring, new solder joints, the works
Just need my binding post and I will have sound again!!!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Vr3MxStyler2k3 wrote: »Hey George I only see eagle resistors that are 10 watts.
Yep-- you are correct sir,, my bad--that just made things easier.ThanksJC approves....he told me so. (F-1 nut) -
George, fwiw I was very impressed with the performance of the Clarity Cap SA series on the woofer network...
I noticed alot more bass response and an openness in the mids that was not there before almost immediately- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Well I couldnt wait any longer on my binding post.. lol
I had some spare parts laying around in the closet...
so I just twisted some wires together to go to the speaker, heat shrinked them - wrapped wires about the post, heat shrinked them together
Called it a day! lol
First impressions between left speaker to right speaker are very positive...
Changes done to the left speaker vs. right
1) gaskets put between drivers and enclosure
2) Reattached and sealed ports to enclosure
3) Lined enclosure with a sheet of No-Rez particularly around the drivers, the very back of the enclosure and bottom
4) New Wiring throughout
5) Clarity MR series on the tweeter network
6) External crossovers
7) 18" Tile, elevated off the floor by felt pads - with speaker spiked to it...
8) Diffraction be gone
With all of these changes, it was immediately easier to pick out micro details, more so easier to understand and process these micro details..
Chestiness present in bass and vocals was no more.
Bass accuracy is far superior
Mids to highs transition is far smoother
Tweeter is far more controlled
I am excited to hear these things after the caps burn in and everything settles.
To bad I will have to tear it all apart again to install my real binding post hahah- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Here are some pics of my rigged up setup- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Wow Im an idiot
I was looking at the pic of the tweeter network and noticed I had the tweeter out of phase... LOL
Now you want to talk about a pretty big difference?
Ill keep my opinions and observations to myself but I am headed the right direction- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Honestly I should have done these upgrades one by one but... I didnt feel like taking my speakers apart alot.
The No Rez has made a huge improvement in just the quickness of the midbasses. I played some songs I am very familiar with and listened for midbass chestiness I had heard previously and none was to be found. Quite the opposite - very fast response with super clean upper midbass registries, even better than I once had. Very impressive.
The highs are far more controlled than before, but I can't decide if it is the cap that is doing it or the Diffraction be gone.
I also noticed the speaker throws out a far wider, deeper stage than the right speaker.
The bass also digs much deeper. There was a particular song I played where the bass was much deeper on the left than the right and it was the same signal per side.
Very interesting to listen to a decked out speaker vs. a stock speaker in the same rig at the same time.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
When they're both done, try them without the diffraction pads."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Ill give it a shot.
I know standing right up on the speaker or directly infront of it it sounds 1,000,000 times cleaner with the diffraction be gone on. It sounds disoriented without it outside the sweet spot.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Lightman was over today
And we both agreed
The left speaker (Modded)
Has cleaner, more controlled highs
Deeper, cleaner, more textured bass
More natural transition between mids and highs
Integrated better with the sub
Huge 3-D soundstaging, height-width-depth
Incredible, spot on center image
It honestly sounded like the right speaker was doing nothing in comparison.
No contest, whatever the major difference is - the combination of the No Rez, the outboard crossovers, the better tweeter cap, the diffraction be gone, the new internal wiring, resealing the ports, putting gaskets behind the drivers....
All of that combined has created a new level of speaker that unfortunately was subdued by poor quality parts.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
So when are you going to do the other one?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
The minute my binding post arrive... lol
I dont have anymore spare parts- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Vr3MxStyler2k3 wrote: »The left speaker (Modded)
And exactly how did you evaluate this?_________________________________________________
We played familiar music - the left speaker was modded, the right speaker is not.
The left speaker threw out a far greater stage, far better micro details, just really as soon as it got to the right side of the stage things just really fell apart.
In comparison the right speaker sounded just bad. If I had not modded them at all I obviously would have never thought this but seeing what has changed now compared to then the difference is huge.
For example, there was one particular track where there was a bass beat identical in both channels, the right speaker sounded hollow where as the right sounded very full and deep. Things like this are what made the difference.
I mean Russ sat down and immediately was like, wow - no contest, the left speaker is that much better...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
My question was just on the center image evaluation
Obviously the center image is harder to evaluate this way
But I actually had to bring myself closer to the right speaker as the left speaker projected better - it was far more pronounced on the left.
Not to mention things around the center image were far more distinguished.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Yep..The difference is leaps and bounds over the stock speaker. My high range hearing is only good up to around 11khz. But I could hear much more detail from the modded speaker. More presence and clarity from the tweets. The mids staging is wider and deeper. The midbass punch was rapid-fire sweetness. No decay or slop. Low end was gut punching and precise. Trey has built him a new set of speakers with the mods he's done.
Two thumbs up! -
I would like to take a second to thank Mike (Face) for all his help.
His guidance in all of this has been priceless.
He has helped me modify my speakers to what I would classify at this point the best rig I have ever heard.
There truly is no contest here. I can find no faults with the left side of my stage, it is so good it makes me giggle. I havent giggled when listening to music in years.
I mean seriously - wow. Guys, those Clarity MR capacitors with those duelund resistors are so hot they could catch water on fire. My god folks.
Incredible! Absolutely incredible and worth every freaking penny.
I cant wait till my binding post get here.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I dunno. At $50ish each cap.....I can't bring myself to think they will sound that much better. I guess I won't know until I try, right?_________________________________________________
If I had extra money to light on fire I would do the whole crossover in them (woofer network) only problem is we are talking about 1,800 bucks in caps- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
You're welcome!Vr3MxStyler2k3 wrote: »I would like to take a second to thank Mike (Face) for all his help.
So what are you waiting for?I dunno. At $50ish each cap.....I can't bring myself to think they will sound that much better. I guess I won't know until I try, right?
Here is my finished product...
It is not the best enclosure - but it is discrete and out of the way and you have to walk over to the corner of the room to notice them.
A perfect world would be me being able to place them directly behind the speaker - but none the less this will work!
Maybe one day I will put them in another enclosure? Who knows...
I used DH Labs wiring...
I used locking Banana plugs
Insulated binding post, 99.99% copper with 24k gold plating
There are 6 rubber dampening feet per enclosure...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
And......... I did it again - the tweeter is out of phase.... lol- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Some wood boxes that match those cabinets would be a nice touch.
