Tweeter Mounting Brackets..
Put me down for 4 to do my 1Cs.Speakers: SDA-1C (most all the goodies)
I'll take 1 set....if you have not yet sent me the other rings for my 2B's that I just sent the $$ on, can you add these to them and let me know what I owe you including any additional shipping?Yep, my name really is Bob.
Parasound HCA1500A(indoor sound) and HCA1000(outdoor sound), Dynaco PAS4, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub. -
T-Nuts SUCK! All this work to make something nice and T-Nuts are OK with you. NOT!Why would anyone need rings for the spikes? If your speakers didn't come with threaded inserts, simply buy 1/4-20 T-nuts and call it a day.
4 maybe 8 sets Big Larry!
I guess I am going to need enough to do my 1C's and 1.2TL's....Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
2 sets for my 2Bs please, thanks Larry!"The secret of happiness is freedom. The secret of freedom is courage." Thucydides
deleted
Hi Larry,
I would like 3 pair for my sda 2.3. Thanks for the great job on the brackets, they make it easy to properly tighten the drivers into these 20+ year old speakers.Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
Bottlehead Eros
CD: DIY Shigaclone
Vinyl rips: ESI Juli@24/192->Goldwave->i7 PC server -
audiobilly wrote: »T-Nuts SUCK! All this work to make something nice and T-Nuts are OK with you. NOT!
Why don't you explain to us why the use of T-nuts for the spikes is not Ok with you. I'm dying to hear this.Political Correctness'.........defined
President of Club Polk -
Hummm me too, T nuts work just fine, they hold up my 185lb speaker..:eek: -
Before the run sells out, I'd like to get in line for 2 sets for a pair of 2B's. I assume the screw holes will line up with the 198 tweeters? (I'm gearing up to do the TL mod.)
Also, Larry, I sent you a PM about a full set of rings for the 2B's as well if you still have 4 MW rings and 2 passives. This rocks! Thanks!!! -
I am dumbfounded that you regard my opinions so highly. Hold on brother.
I do not like them. I do not like them Sam-I-Am. You have your opinions, and so do I.
I do not like T-Nuts. Quick and easy, yes. Will they get the job done, yes. You can do better. You have with every other mod on your speakers,,, or have you? This is why Larry made the Rings, or at least one reason I would think.
Wow, let down huh? Still got a pulse?Why don't you explain to us why the use of T-nuts for the spikes is not Ok with you. I'm dying to hear this. -
audiobilly wrote: »I am dumbfounded that you regard my opinions so highly. Hold on brother.
It's obvious that you don't understand the purpose of the rings or the purpose of the spikes, so I'll explain it to you. The purpose of the rings is to couple the baskets to the cabinet. The purpose of the spikes is to decouple the cabinet from the floor. Additionally, the spikes do not go thru the cabinet wall, they are attached to the base board, which in turn is bolted thru the cabinet wall. Therefore, your opinion on the matter is without merit as is your attitude.Political Correctness'.........defined
Larry, PM me a cost for 12 sets, with shipping of course, when you arrive at an exact price for a set.
Thanks, -
Oh boy ,,,, so much for "me" having a strong opinion on T-Nuts. It is obvious that I do not agree that T-Nuts are the best way. It is also obvious that you are very busy dying to be right.
T-Nuts, I do not like them Sam-I-Am.
FinIt's obvious that you don't understand the purpose of the rings or the purpose of the spikes, so I'll explain it to you. The purpose of the rings is to couple the baskets to the cabinet. The purpose of the spikes is to decouple the cabinet from the floor. Additionally, the spikes do not go thru the cabinet wall, they are attached to the base board, which in turn is bolted thru the cabinet wall. Therefore, your opinion on the matter is without merit as is your attitude.
This is Larrys' thread, and I apologize for this intrusion. -
audiobilly wrote: »Oh boy ,,,, so much for "me" having a strong opinion on T-Nuts. It is obvious that I do not agree that T-Nuts are the best way. It is also obvious that you are very busy dying to be right.
For someone with such a strong opinion you don't seem to be able to relate how and why you formed that opinion. Nor have you been able to offer a better alternative.
It's not a matter of me being right as I'm always open to learning new info concerning all things audio related. It is a matter of you not understanding the purpose of the rings or the spikes and the fact that you are evidently unable to express yourself without resorting to wise crack comments that have no bearing on the topic at hand.Political Correctness'.........defined
Please put me in for 2 sets for my CRS+
enought for 12 tweeters pleaseDodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
I will have these up by the end of the week.. Just tring to close out some loose ends before I let loose..
Looks good Larry. They should work well. I will defiantely be in for 2 sets when you are ready to sell.
Greg
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
I want 22 sets for my:
1.2TL's (8 sets)
SRS's (8 sets)
3 pairs of CRS+'s (6 sets)Proud and loyal citizen of the Digital Domain and Solid State Country! -
2 sets for me, please!
JayJay
I'd like 12 for 1.2tl's and 1C's.
Thanks,
John➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬ -
Larry 1 set please for my 2B's
Thanks,
ScottI like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D -
I will PM everyone on this list as soon as I have them going. I should be cutting them tomorrow morning..
They will be $6 a set plus shipping... (a set is one tweeter)
I tried to get them lower but I can't. I don't have enough drop 16ga material to cut them so I have to dig into a new sheet, Sorry fellas but I went through all are scrap material,it just is'nt there..
Thanks,
Larry. -
does your laser microtab to keep parts from tipping up and killing the head? when we got our bystronic with microtabbing, it was a godsend over our cincinnati that did not. then you can really cut thin parts close together. another thing, dunno if ya'll have liquid nitrogen available as assist gas. we switched over to that over oxygen and it leaves no scale. the cut is clean as though it was polished. we had to because our powdercoat would sometimes flake off when the lasered edges would de-scale. it also keeps the part cool so you can pack 'em tight like sardines, that is, if you're not already common-cutting.
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
7.1 SURROUNDS: RTI6'S
XBOX 360WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
http://polkarmy.com/forums/index.phpbobman1235 wrote:I have no facts to back that up, but I never let facts get in the way of my arguments. -
4 sets for my SRS2's please!
Larry, sign me up for 3 sets please.Polk SDA SRS 2
Polk RTA 15tl
Polk Monitor 7C
Polk Lsi9
Infinity RS-II (modded)
Infinity RS-IIIa (modded)
Infinity RS 2.5 x 2
Magnepan 1.6QR (modded)
System: http://forum.audiogon.com/cgi-bin/fr.pl?vevol&1290711373 -
Emails being sent a little at a time. Tweeter brackets are ready.
I only cut 300 sets.. -
If I missed PMing anybody please contact me. I'm on my Iphone doing this so I'm sure you understand..
Thanks!!
Larry.
