Tweeter Mounting Brackets..
24
  • thsmith
    thsmith Posts: 6,082
    edited August 2010
    Put me down for 4 to do my 1Cs.
  • muncybob
    muncybob Posts: 3,263
    edited August 2010
    I'll take 1 set....if you have not yet sent me the other rings for my 2B's that I just sent the $$ on, can you add these to them and let me know what I owe you including any additional shipping?
    Yep, my name really is Bob.
  • audiobilly
    audiobilly Posts: 351
    edited August 2010
    T-Nuts SUCK! All this work to make something nice and T-Nuts are OK with you. NOT!
    Why would anyone need rings for the spikes? If your speakers didn't come with threaded inserts, simply buy 1/4-20 T-nuts and call it a day.
  • audiobilly
    edited August 2010
    4 maybe 8 sets Big Larry!
  • vmaxer
    vmaxer Posts: 5,121
    edited August 2010
    I guess I am going to need enough to do my 1C's and 1.2TL's....
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Disc Jockey
    Disc Jockey Posts: 1,013
    edited August 2010
    2 sets for my 2Bs please, thanks Larry!
    "The secret of happiness is freedom. The secret of freedom is courage." Thucydides
    Toolfan66 Posts: 18,165
    edited August 2010
  • bikerboy
    bikerboy Posts: 1,235
    edited August 2010
    Hi Larry,
    I would like 3 pair for my sda 2.3. Thanks for the great job on the brackets, they make it easy to properly tighten the drivers into these 20+ year old speakers.
    Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
    Bottlehead Eros
    CD: DIY Shigaclone
    F1nut Posts: 51,962
    edited August 2010
    audiobilly wrote: »
    Why don't you explain to us why the use of T-nuts for the spikes is not Ok with you. I'm dying to hear this.
    edited August 2010
    Hummm me too, T nuts work just fine, they hold up my 185lb speaker..:eek:
  • On3s&Z3r0s
    On3s&Z3r0s Posts: 1,013
    edited August 2010
    Before the run sells out, I'd like to get in line for 2 sets for a pair of 2B's. I assume the screw holes will line up with the 198 tweeters? (I'm gearing up to do the TL mod.)
    Also, Larry, I sent you a PM about a full set of rings for the 2B's as well if you still have 4 MW rings and 2 passives. This rocks! Thanks!!!
  • audiobilly
    edited August 2010
    I am dumbfounded that you regard my opinions so highly. Hold on brother.
    I do not like them. I do not like them Sam-I-Am. You have your opinions, and so do I.
    I do not like T-Nuts. Quick and easy, yes. Will they get the job done, yes. You can do better. You have with every other mod on your speakers,,, or have you? This is why Larry made the Rings, or at least one reason I would think.
    Wow, let down huh? Still got a pulse?
    F1nut Posts: 51,962
    edited August 2010
    audiobilly wrote: »
    It's obvious that you don't understand the purpose of the rings or the purpose of the spikes, so I'll explain it to you. The purpose of the rings is to couple the baskets to the cabinet. The purpose of the spikes is to decouple the cabinet from the floor. Additionally, the spikes do not go thru the cabinet wall, they are attached to the base board, which in turn is bolted thru the cabinet wall. Therefore, your opinion on the matter is without merit as is your attitude.
  • Malbec
    Malbec Posts: 558
    edited August 2010
    Larry, PM me a cost for 12 sets, with shipping of course, when you arrive at an exact price for a set.
    Thanks,
  • audiobilly
    edited August 2010
    Oh boy ,,,, so much for "me" having a strong opinion on T-Nuts. It is obvious that I do not agree that T-Nuts are the best way. It is also obvious that you are very busy dying to be right.
    T-Nuts, I do not like them Sam-I-Am.
    Fin
    This is Larrys' thread, and I apologize for this intrusion.
    F1nut Posts: 51,962
    edited August 2010
    audiobilly wrote: »
    For someone with such a strong opinion you don't seem to be able to relate how and why you formed that opinion. Nor have you been able to offer a better alternative.
    It's not a matter of me being right as I'm always open to learning new info concerning all things audio related. It is a matter of you not understanding the purpose of the rings or the spikes and the fact that you are evidently unable to express yourself without resorting to wise crack comments that have no bearing on the topic at hand.
  • drselect
    drselect Posts: 664
    edited August 2010
    Please put me in for 2 sets for my CRS+
  • hoosier21
    hoosier21 Posts: 4,420
    edited August 2010
    enought for 12 tweeters please
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
    edited August 2010
    I will have these up by the end of the week.. Just tring to close out some loose ends before I let loose..
  • headrott
    headrott Posts: 5,496
    edited August 2010
    Looks good Larry. They should work well. I will defiantely be in for 2 sets when you are ready to sell.
    Greg
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited August 2010
    I want 22 sets for my:
    1.2TL's (8 sets)
    SRS's (8 sets)
    3 pairs of CRS+'s (6 sets)
  • agfrost
    agfrost Posts: 2,474
    edited August 2010
    2 sets for me, please!
    Jay
    Jay
  • JayCee
    JayCee Posts: 1,509
    edited August 2010
    I'd like 12 for 1.2tl's and 1C's.
    Thanks,
    John
    Speakers: Polk1.2tl's (Uber Mods) Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" Power Conditioner: PS Audio P15 Power Plant Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited August 2010
    Larry 1 set please for my 2B's
    Thanks,
    Scott
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
    edited August 2010
    I will PM everyone on this list as soon as I have them going. I should be cutting them tomorrow morning..
    They will be $6 a set plus shipping... (a set is one tweeter)
    I tried to get them lower but I can't. I don't have enough drop 16ga material to cut them so I have to dig into a new sheet, Sorry fellas but I went through all are scrap material,it just is'nt there..
    Thanks,
    Larry.
  • BIZILL
    BIZILL Posts: 5,432
    edited August 2010
    does your laser microtab to keep parts from tipping up and killing the head? when we got our bystronic with microtabbing, it was a godsend over our cincinnati that did not. then you can really cut thin parts close together. another thing, dunno if ya'll have liquid nitrogen available as assist gas. we switched over to that over oxygen and it leaves no scale. the cut is clean as though it was polished. we had to because our powdercoat would sometimes flake off when the lasered edges would de-scale. it also keeps the part cool so you can pack 'em tight like sardines, that is, if you're not already common-cutting.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • Big Dawg
    Big Dawg Posts: 2,005
    edited August 2010
    4 sets for my SRS2's please!
  • geoff727
    geoff727 Posts: 546
    edited August 2010
    Larry, sign me up for 3 sets please.
    Polk SDA SRS 2
    Polk RTA 15tl
    Polk Monitor 7C
    Polk Lsi9
    Infinity RS-II (modded)
    Infinity RS-IIIa (modded)
    Infinity RS 2.5 x 2
    Magnepan 1.6QR (modded)
    System: http://forum.audiogon.com/cgi-bin/fr.pl?vevol&1290711373
    edited August 2010
    Emails being sent a little at a time. Tweeter brackets are ready.
    I only cut 300 sets..
    edited August 2010
    If I missed PMing anybody please contact me. I'm on my Iphone doing this so I'm sure you understand..
    Thanks!!
    Larry.
