Computer Build Advice
24567
    tonyb Posts: 33,068
    edited June 2010
    bobman1235 wrote: »
    Why would you suggest that? Putting together a PC is pretty easy if you have all the parts in front of you. Pretty much everything fits together in only one way.
    Yes,but certain things work better with certain parts, a marriage of parts if you will. Aside from that,if you've paid attention to the OP's other posts, he doesn't seem to be a hands on guy...no offense to the OP. Give Sami a ring,he can guide you on what parts will work for what you want your computer to do,and can build it for you if you like, or take the shot yourself,up to you.
  • MacLeod
    MacLeod Posts: 14,358
    edited June 2010
    bdaley6509 wrote: »
    The I7 destroys the Phenom II in pretty much everything...from gaming to productivity.
    http://www.tomshardware.com/reviews/overclock-phenom-ii,2119-7.html
    Also...the I7 930 is $199.00. For thirty or forty bucks difference, it's well worth it IMO. I could be wrong...I've been wrong before.
    http://www.microcenter.com/search/search_results.phtml?N=4294966995
    Just you wait til I get home. Ill show ya. We'll have a battle of the benchmarks! ;)
  • polkatese
    polkatese Posts: 6,767
    edited June 2010
    Tony brought up a good point on compatibility between parts.
    So, to recap, PC, you need to clarify those questions above, mainly budget, usage, comfort level in building it yourself, and OS need.
    AMD, Intel, Republican, Democrat, Liberal, Conservative, Islam, Catholics, Mormon....did I miss anything? :)
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  • vc69
    vc69 Posts: 2,500
    edited June 2010
    I could not disagree more on going with Dell over building your own. You may get similar specs with a comparable price, but the quality of components in a Dell are no where near what you can build on your own
    I don't want to start any crap, but that is a pretty ridiculous statement.
    Home-builds are fun. If you have a particular function/need to fulfill, then home built can be the way to go. Think HTPC, where there is no need for a lot of proc power and you can narrow down your components to fit a specific need. But for the casual user or even the power gamer, a well thought out Dell order will actually save you money. Not to mention the warranty.
    I work with thousands of computers of all kinds. Dell is my choice for everything except highly specialized boxes and (Pro) multi-media production.
    The make a quality product and I save money.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • zeppage2
    zeppage2 Posts: 196
    edited June 2010
    build your own
    you will gain valuable knowledge
    use that 500GB as your C drive
    buy a second HD for music, video, etc.
    know that when you buy online, you might sacrifice convenience for price if anything arrives DOA or your memory is incompatible
    look for a PSU that has low db's when in idle, noisy PSU's can be very annoying
  • John30_30
    John30_30 Posts: 1,024
    edited June 2010
    That list looks fine. The video card should make you happy using the TV as a 2nd monitor. Look for some youtube tutes on assembling your own kit, or if your uncle is going to do it, get him a case of some good beer- for after it boots up the 1st time.
    Some don'ts if you do it- don't build it on a plush carpet or any area where static can be generated. If that's even a hint of possible, get an anti-static wrist strap.
    Do I not see a heatsink/fan on your list? Get the biggest, baddest one you can for that style board that you can still fit the other components in and around. AMD's historically run hot. If there's not a factory film of silver paste on the sink, just a dab is all you need on the CPU. Too much defeats the purpose.
    Don't try to force anything. I like to do a build in the early to midday. I've screwed up trying to get one built in the evening when I was dogtired and forgot something utterly obvious.
    Also, just skip all the AMD vs. Intel debate. Everyone has their prefs, like Fords and GM. Their build architectures and piping are radically different, so it's almost like apples and oranges.
    That's why the motherboards aren't interchangeable. Never have been.
  • polkatese
    edited June 2010
    Yep. That has been my experience too Kevin.
    I started my career in IT Desktop support (not really by choice, but because I like to build PCs, electronic kits build, etc. etc.) It was fun for sure, and later on I drifted away from building SOTA PCs that became an expensive door stopper after a couple years, to just buy it from Dell to get all the support I need if any part failed (and they do fail at some point). It is the nature of electronic parts. So, it boils down to bragging right to own SOTA in the first year of ownership, then it becomes a story that a mobo that used to cost $400 is $100 six months later.
  • bdaley6509
    bdaley6509 Posts: 1,167
    edited June 2010
    MacLeod wrote: »
    LOL...don't worry about it. They are both good and I'm sure there are pleanty of benchmarks that favor both...good luck OP on your decision.
  • ryanjoachim
    ryanjoachim Posts: 2,046
    edited June 2010
    Unless you're a "power" user, the average Dell is a great machine for you. They're sturdy, dependable (for the most part) and fairly affordable.
    I'm the tech at a middle school (800 kids from 11-14yrs old) and we are almost dell-exclusive for our 200+ desktops and 120 or so laptops. They go through a big beating every day, and we still have some from 2003 that still work just fine (granted they're slow as hell, but they still work).
    On the other hand, building your own PC is one hell-of-a-lot of fun. Also, when something goes wrong with the hardware in the future, you have a much better understanding of what is in your comp and how to replace something.
    MrNightly wrote: »
    "Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
    mystik610 wrote: »
    Best Buy is for people who don't know any better. Magnolia is for people who don't know any better and have more money to spend.
    My System:
    TV: SAMSUNG UN55B7000 55" 1080p LED HDTV
    HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server.
  • PhantomOG
    PhantomOG Posts: 2,409
    edited June 2010
    I find it humorous that people can lay blame for so many PC "problems" to what brand of microprocessor is inside. I have *never* come across a faulty CPU. Heatsinks/fans/power supplies/motherboards/memory/video cards/hard drives/etc sure. CPU's? Not so much.
  • polkatese
    edited June 2010
    Upgrade them to WIN7 and extra RAM, it breathes new life again.
    That's what I did with my Dimension 8400 (2004), and I was pleasantly surprised in how fast and reliable it becomes again.
  • zeppage2
    zeppage2 Posts: 196
    edited June 2010
    PhantomOG wrote: »
    word
    aside from the occasional bent pin (user caused, no doubt), CPU's are very resilient
  • Fongolio
    Fongolio Posts: 3,516
    edited June 2010
    PhantomOG wrote: »
    In that context, I stand corrected. I have seen both AMD and Intel heatsink fans fail. In all cases the AMD cpu core got so hot damage occured. In only one case have I seen an Intel chip destroyed because of fan failure and that was a Pentium 1 chip. Intel motherboards seem to shut down faster when overheated cpu's are detected.
    I am using water cooling on mine now and even overclocked from 3 GHz to 4 GHz the core is still at just above 50 degress idle and as high as 57 under heavy load. Enough can't be said about the importance of good cooling.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • zeppage2
    zeppage2 Posts: 196
    edited June 2010
    and poorly applied thermal past is also a culprit in overheating
  • Fongolio
    edited June 2010
    zeppage2 wrote: »
    Absolutely! I almost always nix the stock stuff and apply Arctic Cooling. Lately I've been using MX-3 with tremendous results.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Ben's IC's
  • zeppage2
    zeppage2 Posts: 196
    edited June 2010
    Fongolio wrote: »
    and it is funny that one would refuse to add a $10.00 tube of paste to a cart filled with $500-1000 of components:eek:
  • j allen
    j allen Posts: 363
    edited June 2010
    Unless I'm mistaken, you may want to check the compatibility of your cpu and the socket on that board. It looks the processor requires an am3 socket, and the board is am2+. If I'm not mistaken, you can plug it in anyway, but there's no benefit to that processor over a cheaper am2 or 2+ processor without having the am3 socket on the motherboard.
  • renowilliams
    renowilliams Posts: 920
    edited June 2010
    PerfectCreture,If you want a suggestion on a case to use,I was very happy with my Cooler Master HAF 932 case. Here are some pics of my build
    http://www.flickr.com/photos/renowilliams/
    I had some fun with this build
    "They're always talking about my drinking, but never mention my thirst" Oscar Wilde
    Pre-Amp: Anthem AVM 20
    Amp: Carver TFM-35
    Amp: Rotel RB-870BX
    Fronts : SDA 1B w/ RDO-194s
    T.V.:Plasma TC-P54G25
    Bluray: Oppo BDP-93
    Speaker Cables: MIT Terminater
    Interconnect Cables:DH Labs Silver Sonic BL-1isonic
  • wz2p7j
    wz2p7j Posts: 840
    edited June 2010
    PC:
    Try this forum for building a computer:
    http://forum.pcmech.com/
    Once you figure out all the components you need it only takes a couple hours to build and configure the unit.
    Chris
  • Sherardp
    Sherardp Posts: 8,038
    edited June 2010
    I think your build looks good so far. I would change two things though. I would actually swing for the Phenom II X4 CPU and go with a Western Digital Caviar Black instead of the Blue. Look into the Phenom II 945 or 955. Prices are very good since the release of the new 6core chip. Everything else should be good to go. Also make sure you get a tower that has great airflow.
    Building PC's is a ton of fun, and there's so much knowledge to gain. I spend most of my time on the darkside with crackz and other projects. FYI your new CPU will come with thermal paste on the chip so no worries there. Once you decide to overclock then you can step up to different coolers, and paste. I love AS5 or OCZ Freeze, good stuff.
  • PerfectCreature
    PerfectCreature Posts: 1,456
    edited June 2010
    Oh yeah I forgot about the cpu to the motherboard part. Its suppose to be am asus mother board....
    Anyway. So I should get liquid cooling and a big cpu fan?
    Thanks.
    Also I should use the arctic compound.
    What else?
    Thanks.
    Receiver
    Harman Kardon HK 3490
    Speakers
    Polk Audio Monitor 50s
    Subwoofer
    Klipsch KSW-100
    Cables
    AudioQuest Rocket 33s 10ft
    AudioQuest Optilink1 2m
    AudioQuest Alpha-Snake 25ft Interconnect
    AudioQuest HDMI-1 2m
    Alienware X51 R2
    PS4
    Samsung Smart TV 40" 1080p 3D
  • exalted512
    exalted512 Posts: 10,735
    edited June 2010
    MacLeod wrote: »
    I'll be glad to. I'm on my Droid phone at work now so I can't link to all of them but once I get home I'll be happy to post plenty of benchmarks comparing the $170'ish AMD Phenom II's up against the $300'ish Intel i7's.
    If you had an iPhone you could do it from your phone:p:p
    -Cody
  • zeppage2
    zeppage2 Posts: 196
    edited June 2010
    asus boards have strict memory compatibility, be warned
  • PerfectCreature
    edited June 2010
    I was told that about ausus....
    Hm...I may do some looking around then on a better mother board that is close to what I have.
    I will also check out Dell tonight and see what they have for me to customize...
    Anyone done cyber power pcs?
    They run about as much as dell, and you can customize more freely...?
    Receiver
    Speakers
    Subwoofer
    Klipsch KSW-100
    Cables
    Alienware X51 R2
    PS4
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited June 2010
    PhantomOG wrote: »
    That's basically exactly what I posted, except with the name calling :D
  • PerfectCreature
    edited June 2010
    In the process of looking at dell and cyber power....
    Receiver
    Speakers
    Subwoofer
    Klipsch KSW-100
    Cables
    Alienware X51 R2
    PS4
  • AsSiMiLaTeD
    edited June 2010
    vc69 wrote: »
    I didn't say Dell was crap, but if you're of the opinion that the parts inside a mass produced PC are of that same quality as one you can build yourself then there's really nothing for us to discuss.
    For about the same price as you can buy a Dell with comparable specs you can build a machine with better components. By 'better' I don't mean that the Dell will break down in a week and the home built will last a decade - but in terms of things like overclocking and future upgradability and in many cases even down to the capacitors taht are used on the motherboard, you're going to be able to get a better PC by building it yourself.
    Dell is out to make money, they're going to put the cheapest parts in the PC that they can which allow maximum profit while still delivering a set amount of performance. Ever tried overclocking a Dell? I have, on several friends setups, it ain't pretty. Pop open your Dell and tell me how many solid caps are on the motherboard. Etc Etc.....
    You can do better by building it yourself. It's the same reason that we're all into this audio hobby. Sure I could buy a HTIB, but I'm going to get better sound if I pick all my individual components and do it myself.
  • PerfectCreature
    edited June 2010
    Very well said.
    That is true, while a HTIB sounds nice, they really can't run bounds with a hand picked to your tastes set-up.
    Receiver
    Speakers
    Subwoofer
    Klipsch KSW-100
    Cables
    Alienware X51 R2
    PS4
  • MacLeod
    edited June 2010
    zeppage2 wrote: »
    word
    Whats the old saying? 99% of computer problems are between the chair and keyboard.
    Asus, MSI, Asrock and Gigabyte all make excellent quality boards. Shop around and find the one that meets your requirements and is cheapest. Theyll be about the same in quality.
    Its not that easy. I always have to have the last word. Just ask my wife. :p
    Here is a good review from Anandtech on the Phenom II X4 965 ($180). In every benchmark, it is at or near the top and is only beaten by CPU's costing twice and sometimes triple the price of the 965.
    The benchmarks that it lost on werent by much. For games, the AMD and Intel procs are pretty close and basically even across the board. Windows Media Coding - yeah it 2nd to a $500 processor but the actual difference in time was 4 seconds. Divx encoding, $170 AMD takes 42 seconds to do the job - the $300 Intel takes 39 seconds. Data recovery takes the AMD 32 seconds and the $500 Intel 24 seconds. The Microsoft Excel test, the AMD takes 23 seconds while the $500 Intel does it in 12. Yeah thats a lot faster but Id rather save $330 and wait 11 seconds.
    http://www.anandtech.com/show/2819/7
    Here is another review by Toms Hardware on the P2 965. Again, it gets beat a lot by the Intel i7's, but its by the same margins. The i7 is taking 3 minutes to complete a benchmark, the 965 is taking 3:45. The Intels also win the game benchmarks but again, only by a few frames per second.
    http://www.tomshardware.com/reviews/phenom-x4-965,2389-8.html
    These are just the 1st two I went to. Intel is definitely the performance leader and the fastest clock for clock. But on a dollar for dollar comparion, the AMD smokes the Intels. Offering 85-95% of the performance for half or less of the price. So like I said, Id rather keep $300 and wait 10 seconds more for encode a home movie. And when you consider the new Athlons that offer quad core CPU's for less than $100 or the new Phenom X6 6 core CPU's that start at $200, AMD is even more appealing.
