Computer Build Advice
PerfectCreature
PerfectCreature Posts: 1,456
edited October 2011 in The Clubhouse
My computer I had hooked up to my tv recently died. I got some money from a scholarship that I can use for a new computer. I asked the people they said it counts if I use it on stuff to build one. So I would like to make one, since you can get better performance for your money if you do so.
Anyway my question is this, for alll you tech savvy people will this build work?
Also am I missing any components.
Are there any suggestions to it, maybe areas to improve without breaking the bank? Also, do I need to buy anything else with this stuff so that I can build it, like cables or anything like that?
Thanks.
LITE-ON CD/DVD Burner - Bulk Black SATA Model iHAS124-04
XION Solaris XON-403 Black with Green LED Light Steel ATX Mid Tower Computer Case
Western Digital Caviar Blue WD2500AAJS 250GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
GIGABYTE GA-MA770-UD3 AM2+/AM2 AMD 770 ATX AMD Motherboard
Radeon HD 4670 512MB 128-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card
CORSAIR CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply
Patriot Extreme Performance Gaming Series 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Desktop Memory Model PGS24G6400ELK
AMD Phenom II X2 550 Callisto 3.1GHz Socket AM3 80W Dual-Core Desktop Processor Model HDX550WFGMBOX
Receiver
Harman Kardon HK 3490
Speakers
Polk Audio Monitor 50s
Subwoofer
Klipsch KSW-100
Cables
AudioQuest Rocket 33s 10ft
AudioQuest Optilink1 2m
AudioQuest Alpha-Snake 25ft Interconnect
AudioQuest HDMI-1 2m
Alienware X51 R2
PS4
Samsung Smart TV 40" 1080p 3D
Post edited by PerfectCreature on
«134567
    tonyb Posts: 33,072
    edited June 2010
    Have you ever built one before ?
    If not,I suggest buying the parts you need and putting the actual build process in the hands of someone with experience. I know there is a member here who does just that,name is on the tip of my tongue...damn.
  • fatchowmein
    fatchowmein Posts: 2,637
    edited June 2010
    tonyb wrote: »
    Were you thinking Sami?
  • bobman1235
    bobman1235 Posts: 10,822
    edited June 2010
    tonyb wrote: »
    Why would you suggest that? Putting together a PC is pretty easy if you have all the parts in front of you. Pretty much everything fits together in only one way.
  • PerfectCreature
    edited June 2010
    My uncle can help me, he does stuff like that I was going to give him a call once I got the parts.
    I checked out the dell they don't show me the computer you ordered, and by the looked of it...it basically triples my price.
    Thanks though :D
    Receiver
    Speakers
    Subwoofer
    Klipsch KSW-100
    Cables
    Alienware X51 R2
    PS4
  • bobman1235
    edited June 2010
    Ah I guess that's one legitimate spot where you can run into trouble, but still, it is very straightforward. Plug in wires where they fit and you're good to go :)
  • PerfectCreature
    edited June 2010
    The silver compound right?
    So I should add that in too?
    Any other thoughts on this pc?
    Improvements or what not?
    Receiver
    Speakers
    Subwoofer
    Klipsch KSW-100
    Cables
    Alienware X51 R2
    PS4
  • polkatese
    polkatese Posts: 6,767
    edited June 2010
    given the same components' quality, how much money can you save vs. ordering from Dell?
    I used to do this more than a decade ago, and I did some calc back then, and came to the conclusion that Dell has too much buying cloud in making their TOTL systems a better buy vs. self-build.
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  • PerfectCreature
    edited June 2010
    So. Are you saying i should just buy a prebuilt from dell?
    Instead of build my own?
    Receiver
    Speakers
    Subwoofer
    Klipsch KSW-100
    Cables
    Alienware X51 R2
    PS4
  • polkatese
    edited June 2010
    If I were you, a resounding yes. think about burn-in and warranty.
    however, if you are interested to learn the intricate details of putting together a PC, load OS, learn C: prompt, power-supply size, eSATA vs. EIDE vs. SCSI, etc. etc. , then the journey (for me) was fun and got me some useable knowledge.
  • PerfectCreature
    edited June 2010
    Well, any computers come to mind with around the same specs as the one I was going to build?
    Around the same price would be nice as well.
    Thanks.
    Receiver
    Speakers
    Subwoofer
    Klipsch KSW-100
    Cables
    Alienware X51 R2
    PS4
  • polkatese
    edited June 2010
    I am not the right person to advice you on what's a good option. But, what I would do is to build a specs on dell.com just like what Sal did in the post above, and get it to come out closer to your budget.
  • PerfectCreature
    edited June 2010
    Ive tried that, most of the build a computer starts out at around 600 anyway.
    When I try to match the specs and ratings they always come short...
    I may try it a little later tonight see if I can get one that is close to all of it....
    Receiver
    Speakers
    Subwoofer
    Klipsch KSW-100
    Cables
    Alienware X51 R2
    PS4
  • mdaudioguy
    mdaudioguy Posts: 5,165
    edited June 2010
    Have you factored in the cost of an OS? What are you planning on using? Windows will cost you money. Ubuntu, or one of many other Linux variants, is free. It depends on what you want, and what you intend to do/run on it.
  • MacLeod
    MacLeod Posts: 14,358
    edited June 2010
    What are you going to be using this for? If its just for internet and watching movies, that's good enough gear.
    A couple tweaks:
    Get an Athlon II X2 quad core instead. Theyre not as fast as that 555 but theyre capable of more work and multitasking. So for the same money, you have a much more capable rig in terms of workload. If this were a gaming setup, the 555 would be a better choice because it screams!
    Try to get a 4850 instead of the 4670. Theyre about $20 more but have about 5 times more muscle.
    Unless you plan on a lot of upgrading, you won't need a 650 watt power supply. Get the 400 watt Corsair instead.
  • bdaley6509
    bdaley6509 Posts: 1,167
    edited June 2010
    Drop the Athlon altogether and go Intel. You'll be glad you did.
  • polkatese
    edited June 2010
    +1. and I would go all the way to i7
  • MacLeod
    edited June 2010
    Yeah, go Intel. Spend 200% more money and get 5% more performance. :rolleyes:
  • renowilliams
    renowilliams Posts: 920
    edited June 2010
    +2 on the i7. You will definatly not be disappointed. I built an i7 860 (1156 socket) around Christmas. If you plan on encoding video with this new computer, you will like the performance. It is difficult to build cheaper than buying prebuilt but I just prefer to build my own. Look around as some companies have barebone computers or bundle deals for mother board and processors.
    Good Luck
    "They're always talking about my drinking, but never mention my thirst" Oscar Wilde
    Pre-Amp: Anthem AVM 20
    Amp: Carver TFM-35
    Amp: Rotel RB-870BX
    Fronts : SDA 1B w/ RDO-194s
    T.V.:Plasma TC-P54G25
    Bluray: Oppo BDP-93
    Speaker Cables: MIT Terminater
    Interconnect Cables:DH Labs Silver Sonic BL-1isonic
  • polkatese
    edited June 2010
    Mac, it's called prevention against early planned obsolescence. :)
  • Fongolio
    Fongolio Posts: 3,516
    edited June 2010
    I've spent years building and repairing computers and I have to agree with polkatese, Intel is the way to go. I've just seen way too many problems with AMD's. As for self build, I say go for it. My very first comp was bought from a local assembler but after that I've built every one myself. About thermal past, it is essential unless the processor is brand new and has the factory "goo" on the heatsink/fan unit. The hard drive you've picked is reasonably fast but kind of small by today's standards. At a day after Christmas sale last December I picked up a Seagate 1 TB drive for $69 Canadian dollars. I recomend a minimum of 500 gigs to start. That rig that Lasareath is recomending is fantastic and has a Solid State Drive which makes it blazing fast but also everything state of the art is expensive. I'm holding out on SSD until prices come down a bit more. Last thing, as stated above, you haven't mentioned OS. You'll need one of those as well.
    Have fun.
    Kelvin
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • bdaley6509
    edited June 2010
    MacLeod wrote: »
    Get your facts straight...
  • nadams
    nadams Posts: 5,877
    edited June 2010
    Go with a larger HD, and make it a Caviar Black instead of the Blue. 5 yr warranty...
    I wouldn't put anything less than a 750 gb drive in my main system (and that's with another 750 for storage). The extra speed for the increased areal density is well worth it, even if you don't "need" the extra space.
    Ludicrous gibs!
  • exalted512
    exalted512 Posts: 10,735
    edited June 2010
    polkatese wrote: »
    You can save quite a bit hardware wise, its the software that gets you.
    If you have to buy everything new, and want things like Microsoft Office as well, going to Dell is usually slightly more expensive, but not by much...
    Not enough to justify the effort and not having any body to turn to software wise if something doesnt work right.
    I build my own, but I was also a student and had win7 and office purchased through my school for about $45 between the two of them :)
    -Cody
  • fatchowmein
    edited June 2010
    As others have asked, what O/S are you building but I also wanted to ask what you intend to do with this PC build?
    front end HTPC?
    gamebox?
    casual user (surf internet, office suite, email)?
    All of the above in one box?
  • bobman1235
    edited June 2010
    bdaley6509 wrote: »
    Yeah, it's only 150% more money for 3% performance increase.
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited June 2010
    I'm a fan of intel at the moment if you need the most power, but if you just need a media pc or something along those lines the amd will work fine.
    I like my i7 chips, but they're way overkill for the vast majority of people out there. You also need to consider things like power and heat.
    I could not disagree more on going with Dell over building your own. You may get similar specs with a comparable price, but the quality of components in a Dell are no where near what you can build on your own
  • AsSiMiLaTeD
    edited June 2010
    Also, people that say things like "don't go AMD, they have problems" are dumb. I've done this for years, and I cannot tell you the last time I had a problem that was hardware specific vs just a specific motherboard or component.
    I've had an equal amount of frustration dealing with intel and and. Intel does have the faster chips, but the notion that intel chips are somehow more reliable than amd chips is retarded.
  • MacLeod
    edited June 2010
    bdaley6509 wrote: »
    I'll be glad to. I'm on my Droid phone at work now so I can't link to all of them but once I get home I'll be happy to post plenty of benchmarks comparing the $170'ish AMD Phenom II's up against the $300'ish Intel i7's.
    I'm not saying the AMD procs are better than the Intels, just that the performance difference isnt that much and in most cases the only place youll actually notice the difference is in benchmarks tests. That's not worth twice the money IMO.
    Tack onto that the Intel sockets change with every new proc they come out with so you cant upgrade without buying a new motherboard (which also cost more than their AMD counterparts). AMD uses the same socket so when they come out with a new chip, all you have to do is drop it in.
  • Fongolio
    edited June 2010
    Also, people that say things like "don't go AMD, they have problems" are dumb. Intel does have the faster chips, but the notion that intel chips are somehow more reliable than amd chips is retarded.
    Uh, I'm dumb AND retarded. Such a compelling argument. Ok, you win cause your name calling is better than mine.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Ben's IC's
  • bdaley6509
    edited June 2010
    The I7 destroys the Phenom II in pretty much everything...from gaming to productivity.
    http://www.tomshardware.com/reviews/overclock-phenom-ii,2119-7.html
    Also...the I7 930 is $199.00. For thirty or forty bucks difference, it's well worth it IMO. I could be wrong...I've been wrong before.
    http://www.microcenter.com/search/search_results.phtml?N=4294966995
    MacLeod wrote: »
