Speaker cable size
acmf74
I will be setting up my first HT very soon. My concern is on the gauge of wire I should use. Should I use the same gauge all around or does it even matter? Thanks.
Post edited by acmf74 on
I'm sure a lot of others more knowledgable than I will chime in here, but you should be safe with either 14 or 12 gauge wire, depending on the length of the run. From what I have seen, most on this board prefer 12 gauge.Oh, you hate your job? Why didn't you say so? There's a support
group for that. It's called EVERYBODY, and they meet at the bar.
-Drew Carey
There is a very fine line between "hobby" and "mental illness."
-Unknown
My DVD Collection -
AC, an excellent source of information on speaker wire gauges and the wiring in general is found here . Because of the differences in the length of the runs 18ga would often be fine for the mains while 14ga might be a good choice for distant surrounds. As a practical matter, however, buying a larger quantity of a single gauge may be more convenient and cost-effective. For example, many years ago I bought a large quantity of 16ga lamp cord at a very good price and which I continue to use for all my setups.
acmf74, you would be well advised to ignore the link posted above, it is a terrible source of information. The author rails against high end cable, yet turns around and uses Cardas wire in his speakers. Can you say hypocrite!?!Political Correctness'.........defined
President of Club Polk -
Play it safe, buy a spool of 14 gauge wire, call it a day and start enjoying the sound of movies and music.- Jeremy
Amps: Jolida FX-10, NAD 3045, NAD C320BEE, Sansui G-9700
Speakers: Polk Monitor 7A's, KEF Reference 104aB
Sources: ProJect Debut Carbon, Sonos streaming FLAC -
12-14 AWG from Monoprice.com or Bluejeanscable.com will suit you just fine. Good luck.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
How many times must that link be posted?:rolleyes:acmf74, you would be well advised to ignore the link posted above, it is a terrible source of information. The author rails against high end cable, yet turns around and uses Cardas wire in his speakers. Can you say hypocrite!?!
+1
I've always used 14awg in my HT, and I've never had any problems with it.
As far as my 2 channel speaker cables go...I don't even know what gauge they are. That's not what I was considering when I bought them.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
As a relative noob to HT, I went along with similar suggestions a month ago and bought a 300 ft. spool of 14 ga. speaker wire from Monoprice, along with enough banana plugs to handle 7 speakers. I didn't feel the need to spend the extra $$ on 12 ga. wire, and I wanted the extra footage because I'm a firm believer in measure once, cut twice.
I feel I made the right choice. -
With 4 ohm load speakers I would not use anything less then 14g wire. Use good quality cable like Liberty , Audioquest , Beldon . All these companies make custom In wall design wire you can buy a spool of. It's fantastic quality and you can pretty much use any speakers with it in a tipical sized theater room with runs under 50 feet. 12g will cost you a bit more and add no benefit in short runs. If your rear speakers are over 50 ft runs then step up to a spool of 12g otherwise go 14g.Dan
It is because the table is sound from an engineering perspective.
While others may refer to the web poster as a hypocrite, the science behind the posting remains sound from a wire size/current supplied standpoint.
You can be dumb and run the largest diameter speaker cable with good results or want to be smart and investigate nuances ... including the benefits provided by Blue Jean and other high end cable companies. Most of the "superior" cables are shielded and are of large diameter. -
i bought the 12ga from monoprice for my rear and surrounds and it sounds greatLSI15 Front LSIC Center Lsi7 Rears Lsi7 Sides DSW600
Sony S560 Blu-Ray DVD
Sony 46W5100
Monster HTS-3600
Sunfire TGP-401 Pre
Sunfire Grand 200x7 -
just ordered a roll of the 12awg and a optical (toslink) cable
Good call on the wire. It will work great for you. You will be happy with it for a long time to come. As you continue to upgrade your gear you can look at getting some higher quality wire and see if it makes a difference to you. Some people hear and some people do not. It is all up to you if it is worth it or not.
EnjoyFront - RTiA5's
Rear - RTiA3's
Center - CSiA4
Sub - PSW110 -
14 guage "in-wall" otherwise known as plenum rated wire is good enough for runs as long as 200 feet without signal degregation. You can pick up a spool at Home Depot very inexpensive.
http://www.homedepot.com/h_d1/N-5yc1vZ1xqd/R-100001123/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
This wire can also be used outdoor.
Don't waste your money on brand-name "speaker wire".Zone 1
(5.1 Setup)
-- VM 20 (L/R)
-- RM 8 Center (center)
-- VM 10 (S.L/R)
-- DSW microPRO 1000 (LFE)
Zone 2
-- Atrium 45
Denon AVR-2809
(7.1 Setup)
-- RM 6600 (L/R + center + S.L/R)
-- RM 7 (SB.L/R)
-- PSW 350 (LFE)
Denon AVR-1909 -
My quality of life plummets when people tell me that i wasted money on my brand-name speaker wire. Please think of what impact your comments have on a person's self-esteem.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
14g monoprice and never look back. Trust me I researched this to deathPolk monitor 70's- front
Polk cs2- center
Polk monitor 30's- surround
SVS PB-13 ULTRA- SUB
Pioneer ELITE vsx-21- AV reciever
Pannisonic G10 50" - Display
PS3- Does everything
Monoprice for all my wires -
mikedup2003 wrote: »14g monoprice and never look back. Trust me I researched this to death
How much listening did your research include? What else have you compared it to?I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
concealer404 wrote: »My quality of life plummets when people tell me that i wasted money on my brand-name speaker wire. Please think of what impact your comments have on a person's self-esteem.
:DI'm another of those fools that uses something other than zip cord wire. At least it's nice to know I have company. -
You've got a LOT of company in this crowd. It's good for the ol' self-esteem.
High Quality = Better Quality
Get what you pay for.
Nice Setup don't cheese nowParasound Avc-1800
Mains-Rti 12 -Parasound 1500a
Center-Csi5-Parasound 1000a
Rears-Rti 8-Parasound 750a
Sub SVS Ultra Tv 12
Diamondback and King Cobra IC's
AQ T4 SC -
huh? lol- Jeremy
copper is copper. last time i checked high priced speakers didn't use golden wires. why pay more?Polk monitor 70's- front
Polk cs2- center
mikedup2003 wrote: »copper is copper. last time i checked high priced speakers didn't use golden wires. why pay more?
Popcorn, anyone?- Jeremy
Right-o, sport.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
Home depot wire suck. Well unless you like your wire to turn green.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I really hope nobody gets banned because of this thread.:oPolk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
Mine did, after only 1.5 months. I was amazed at how crappy the wires were lol. So glad Conradicles hooked me up with something better; thanks again man if you read this!- Jeremy
Knucklehead wrote: »I really hope nobody gets banned because of this thread.:o
I think it's inevitable with cable threads.- Jeremy
So there are no different grades of copper? The is no difference in the dielectric constrains of the insulation? There is no difference in how the cable is manufactured?
Thanks for your insight and experiences.
Ben -
I use 10 awg for my surrounds...just because it was I had on hand.
I wonder if this is too-high.....:rolleyes:
(It did sound pretty crappy with my fronts though)
