Speaker cable size
acmf74
acmf74 Posts: 937
I will be setting up my first HT very soon. My concern is on the gauge of wire I should use. Should I use the same gauge all around or does it even matter? Thanks.
Post edited by acmf74 on
«13
  • jgido759
    jgido759 Posts: 572
    edited March 2010
    I'm sure a lot of others more knowledgable than I will chime in here, but you should be safe with either 14 or 12 gauge wire, depending on the length of the run. From what I have seen, most on this board prefer 12 gauge.
    Oh, you hate your job? Why didn't you say so? There's a support
    group for that. It's called EVERYBODY, and they meet at the bar.
    -Drew Carey
    There is a very fine line between "hobby" and "mental illness."
    -Unknown
    My DVD Collection
  • John K.
    John K. Posts: 822
    edited March 2010
    AC, an excellent source of information on speaker wire gauges and the wiring in general is found here . Because of the differences in the length of the runs 18ga would often be fine for the mains while 14ga might be a good choice for distant surrounds. As a practical matter, however, buying a larger quantity of a single gauge may be more convenient and cost-effective. For example, many years ago I bought a large quantity of 16ga lamp cord at a very good price and which I continue to use for all my setups.
    F1nut Posts: 51,725
    edited March 2010
    acmf74, you would be well advised to ignore the link posted above, it is a terrible source of information. The author rails against high end cable, yet turns around and uses Cardas wire in his speakers. Can you say hypocrite!?!
  • Zitro
    Zitro Posts: 864
    edited March 2010
    Play it safe, buy a spool of 14 gauge wire, call it a day and start enjoying the sound of movies and music.
    - Jeremy
    Amps: Jolida FX-10, NAD 3045, NAD C320BEE, Sansui G-9700
    Speakers: Polk Monitor 7A's, KEF Reference 104aB
    Sources: ProJect Debut Carbon, Sonos streaming FLAC
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited March 2010
    12-14 AWG from Monoprice.com or Bluejeanscable.com will suit you just fine. Good luck.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited March 2010
    John K. wrote: »
    How many times must that link be posted?:rolleyes:
    +1
    I've always used 14awg in my HT, and I've never had any problems with it.
    As far as my 2 channel speaker cables go...I don't even know what gauge they are. That's not what I was considering when I bought them.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • EdDinIL
    EdDinIL Posts: 5
    edited March 2010
    As a relative noob to HT, I went along with similar suggestions a month ago and bought a 300 ft. spool of 14 ga. speaker wire from Monoprice, along with enough banana plugs to handle 7 speakers. I didn't feel the need to spend the extra $$ on 12 ga. wire, and I wanted the extra footage because I'm a firm believer in measure once, cut twice. ;) I feel I made the right choice.
  • mantis
    mantis Posts: 17,337
    edited March 2010
    With 4 ohm load speakers I would not use anything less then 14g wire. Use good quality cable like Liberty , Audioquest , Beldon . All these companies make custom In wall design wire you can buy a spool of. It's fantastic quality and you can pretty much use any speakers with it in a tipical sized theater room with runs under 50 feet. 12g will cost you a bit more and add no benefit in short runs. If your rear speakers are over 50 ft runs then step up to a spool of 12g otherwise go 14g.
    Dan
  • Hillbilly61
    Hillbilly61 Posts: 702
    edited March 2010
    It is because the table is sound from an engineering perspective.
    While others may refer to the web poster as a hypocrite, the science behind the posting remains sound from a wire size/current supplied standpoint.
    You can be dumb and run the largest diameter speaker cable with good results or want to be smart and investigate nuances ... including the benefits provided by Blue Jean and other high end cable companies. Most of the "superior" cables are shielded and are of large diameter.
  • tbui2007
    tbui2007 Posts: 128
    edited March 2010
    i bought the 12ga from monoprice for my rear and surrounds and it sounds great
    LSI15 Front LSIC Center Lsi7 Rears Lsi7 Sides DSW600
    Sony S560 Blu-Ray DVD
    Sony 46W5100
    Monster HTS-3600
    Sunfire TGP-401 Pre
    Sunfire Grand 200x7
  • acmf74
    acmf74 Posts: 937
    edited March 2010
    tbui2007 wrote: »
    just ordered a roll of the 12awg and a optical (toslink) cable
  • packetjones
    packetjones Posts: 1,059
    edited March 2010
    Good call on the wire. It will work great for you. You will be happy with it for a long time to come. As you continue to upgrade your gear you can look at getting some higher quality wire and see if it makes a difference to you. Some people hear and some people do not. It is all up to you if it is worth it or not.
    Enjoy
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • ikolbyi
    ikolbyi Posts: 77
    edited March 2010
    14 guage "in-wall" otherwise known as plenum rated wire is good enough for runs as long as 200 feet without signal degregation. You can pick up a spool at Home Depot very inexpensive.
    http://www.homedepot.com/h_d1/N-5yc1vZ1xqd/R-100001123/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
    This wire can also be used outdoor.
    Don't waste your money on brand-name "speaker wire".
    Zone 1
    (5.1 Setup)
    -- VM 20 (L/R)
    -- RM 8 Center (center)
    -- VM 10 (S.L/R)
    -- DSW microPRO 1000 (LFE)
    Zone 2
    -- Atrium 45
    Denon AVR-2809
    (7.1 Setup)
    -- RM 6600 (L/R + center + S.L/R)
    -- RM 7 (SB.L/R)
    -- PSW 350 (LFE)
    Denon AVR-1909
  • concealer404
    concealer404 Posts: 7,440
    edited March 2010
    kolbtod wrote: »
    My quality of life plummets when people tell me that i wasted money on my brand-name speaker wire. Please think of what impact your comments have on a person's self-esteem.
  • mikedup2003
    mikedup2003 Posts: 42
    edited March 2010
    14g monoprice and never look back. Trust me I researched this to death
    Polk monitor 70's- front
    Polk cs2- center
    Polk monitor 30's- surround
    SVS PB-13 ULTRA- SUB :D
    Pioneer ELITE vsx-21- AV reciever
    Pannisonic G10 50" - Display
    PS3- Does everything :)
    Monoprice for all my wires
  • concealer404
    edited March 2010
    How much listening did your research include? What else have you compared it to?
  • zingo
    zingo Posts: 11,258
    edited March 2010
    acmf74 wrote: »
    Bingo. :)
  • skipf
    skipf Posts: 694
    edited March 2010
    :DI'm another of those fools that uses something other than zip cord wire. At least it's nice to know I have company.
  • concealer404
    edited March 2010
    skipf wrote: »
    You've got a LOT of company in this crowd. It's good for the ol' self-esteem. ;)
  • cnoat
    cnoat Posts: 315
    edited March 2010
    High Quality = Better Quality
    Get what you pay for.
    Nice Setup don't cheese now
    Parasound Avc-1800
    Mains-Rti 12 -Parasound 1500a
    Center-Csi5-Parasound 1000a
    Rears-Rti 8-Parasound 750a
    Sub SVS Ultra Tv 12
    Diamondback and King Cobra IC's
    AQ T4 SC
  • Zitro
    Zitro Posts: 864
    edited March 2010
    cnoat wrote: »
    huh? lol
    - Jeremy
  • mikedup2003
    edited March 2010
    copper is copper. last time i checked high priced speakers didn't use golden wires. why pay more?
    Polk cs2- center
  • Zitro
    Zitro Posts: 864
    edited March 2010
    Popcorn, anyone?
    - Jeremy
  • concealer404
    edited March 2010
    Right-o, sport.
  • ben62670
    ben62670 Posts: 15,969
    edited March 2010
    Home depot wire suck. Well unless you like your wire to turn green.
    Ben
  • Knucklehead
    Knucklehead Posts: 3,602
    edited March 2010
    I really hope nobody gets banned because of this thread.:o
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • Zitro
    Zitro Posts: 864
    edited March 2010
    ben62670 wrote: »
    Mine did, after only 1.5 months. I was amazed at how crappy the wires were lol. So glad Conradicles hooked me up with something better; thanks again man if you read this!
    - Jeremy
  • Zitro
    Zitro Posts: 864
    edited March 2010
    I think it's inevitable with cable threads.
    - Jeremy
  • ben62670
    edited March 2010
    So there are no different grades of copper? The is no difference in the dielectric constrains of the insulation? There is no difference in how the cable is manufactured?
    Thanks for your insight and experiences.
    Ben
    Ben
  • kevhed72
    kevhed72 Posts: 5,139
    edited March 2010
    I use 10 awg for my surrounds...just because it was I had on hand.
    I wonder if this is too-high.....:rolleyes:
    (It did sound pretty crappy with my fronts though)
