Looking for Misc Audio Deals of the Day? Updated info here!
The unit has the UL 1449 second edition listing that I understand is very important.
I expect build quality to be at least as good as Monster. My experience with other Niles stuff is that it is on a more professional level than most monster products.The unit has some serious power filtering specs also. Comes with a built in 12v trigger.
Should have mine next week if you want to wait. I'll post a first impression.
Stu, any idea as to how much current limiting they use? -
Hi Joe.
Are we talking total current through the unit? It has a 15A circuit breaker built into the rear of the unit. Some other specs are over voltage and under voltage protection. Niles claims the unit also beats the UL spec (<300v) for capturing spikes, one of only a few on the market to have the ability.Parasound C1, T3, HCA-3500, HCA-2205A, P/DD1550, Pioneer DV-79avi, Oppo BDP-83, WD Media Server W/HDD,
Dynaudio Contour 3.3, Dynaudio Contour T2.1, Polk OWM3, Polk DSW micropro 1000 (x2),
Pioneer Kuro 50" Plasma, Phillips Pronto Control w/Niles HT-MSU. -
Hi Joe.
No Stu, I referring to the outlets of the power conditioners. For instance, my Monster HTS 5100 MKII (now dead) unit had specific outlets for specific pieces of gear i.e., digital outlets for CDPs, outlets for preamps, outlets for power amps etc. The power amp outlets were no good because they had current limiting circuitry which would limit the current drawn by the power amp. This would interfere with the dynamic demand for current on let's say heavy bass draws or just increases needed to complete dynamic range necessities changes.
I believe my amp has filter circuits to clean up the power thus I plug it directly into the wall to avoid the current limiting circuitry in the power conditioners. -
Samsung pn64f8500
Sonus faber venere 2.5
Sf venere center
Oppo 105d
Squeezebox touch
Parasound hca1500a
Apc power filter
Audioquest cables asst
Polk rtia3 SB
Polk fxia6 sl,sr
Dual hsu vtf3 mk3 -
hearingimpared wrote: »No Stu, I referring to the outlets of the power conditioners. For instance, my Monster HTS 5100 MKII (now dead) unit had specific outlets for specific pieces of gear i.e., digital outlets for CDPs, outlets for preamps, outlets for power amps etc. The power amp outlets were no good because they had current limiting circuitry which would limit the current drawn by the power amp. This would interfere with the dynamic demand for current on let's say heavy bass draws or just increases needed to complete dynamic range necessities changes.
Joe, I don't see a spec in the manual for an individual outlet rating.
Some manufacturers units provide surge protection by using "sacrificial" technology, this unit does not. This makes me think there may not be a restriction inline with the 15A breaker rating. Am looking into this further. The fleabay guy also has a 6 outlet unit available with the same technology for really cheap and it may be better suited to use for amp line filtering/circuit protection.Parasound C1, T3, HCA-3500, HCA-2205A, P/DD1550, Pioneer DV-79avi, Oppo BDP-83, WD Media Server W/HDD,
Thanks you Sir!
Samsung pn64f8500
Sf venere center
Oppo 105d
Squeezebox touch
Parasound hca1500a
Apc power filter
Polk rtia3 SB
Polk fxia6 sl,sr
Dual hsu vtf3 mk3 -
VMPS sub in Denver for $150...I'd jump all over that but I'm in NC:
http://denver.craigslist.org/ele/1641595747.html -
more subage no affl with any of these, just bored and shopping around
http://orlando.craigslist.org/ele/1597849668.htmlSamsung pn64f8500
Sf venere center
Oppo 105d
Squeezebox touch
Parasound hca1500a
Apc power filter
Polk rtia3 SB
Polk fxia6 sl,sr
Dual hsu vtf3 mk3 -
Conradicles wrote: »VMPS sub in Denver for $150...I'd jump all over that but I'm in NC:
That's a great price. Wish I was closer. -
hmmm, wish I was in cali
http://cgi.videogon.com/cgi-bin/cl.pl?ampsmisc&1273456252&&&/Polk-RTi-CSiSamsung pn64f8500
Sf venere center
Oppo 105d
Squeezebox touch
Parasound hca1500a
Apc power filter
Polk rtia3 SB
Polk fxia6 sl,sr
Dual hsu vtf3 mk3 -
Wow!! You and me both.
It's all in the detail.
:cool:
HT Setup:
Samsung PN50D550
Onkyo TX-SR805
Samsung BD-D6700
Fronts: RTi10's
Center: CSi5
Side surrounds: RC65i's
Rear surrounds: FXiA4's
Sub: Velodyne CT120
Outdoor: Atrium 45's
Pictures here -
marantz and paradigm in austin, no afill
http://austin.craigslist.org/ele/1642761771.html
http://austin.craigslist.org/ele/1642745679.htmlMain 2ch -
BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
TT - Pro-ject Classic SB with Sumiko Bluepoint.
TV 3.1 system -
Denon 3500 -> Dynaudio Excite 32/22 -
Main 2ch -
TV 3.1 system -
"Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
Polk Audio Monitor Series Tower speakers. Amazing sound quality and solid construction in these tower speakers. I have a pair for sale for $100. They are made of a 10" woofer, two 7" midrange speakers and a 1" tweeter on each pair. I would estimate the weight of each tower speaker at about 40 lbs- they are VERY solidly constructed. They measure 28" high 11.5" deep and 16" wide.
Towers????
Twenty-eight inches high does not a tower make. -
cruising ebay, found these ls50's
http://cgi.ebay.com/POLK-AUDIO-LS50-LS-50-FLOOR-STANDING-SPEAKERS-ROSEWOOD_W0QQitemZ130373360407QQcmdZViewItemQQptZSpeakers_Subwoofers?hash=item1e5adb9b17
looks like they need some tlc, but seems a good price to me. no affiliation -
Newegg.com has the Monitor 40's on sale for $119.99 w/ free shipping. Promo code EMCYPZT58.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=140391567043&ssPageName=STRK:MESELX:IT
Nice system on ebayOnkyo Tx Nr 5007
Integra NAS 2.3 audio serv
Intergra DHS 8.8 HD-DVD
Integra NVS 7.7 Home Theater Media Compt
Anthem MCA 20
Integra 70.1 9 channel amp
OPPO 93 BLU RAY
Monster HDP-2400 power cond
Panamax M5300 PM
Monster HtS-2600 Power cond
Samsung 8000 series e64 plasma
Polk LSI 25
Polk LSI center
Polk LSI 9
Polk LSI 7
Polk LSIM702 fx
Boston Acoustic in ceil #'s ???
Definitive tech sub
Nordost Blue Heaven Rev2 BI wire(great cords)
2 other systems master and pool area -
Newegg has the Cherry Monitor 70's on sale for $169.99 w/ free shipping. Promo code EMCYPZW34. Also, on a side note, the Cherry CS1 is on sale for $67.99 w/ free shipping. Promo code EMCYPZW35. I know the Cherry ones aren't as sought after as the Black ones, but still one hell of a deal.
-JeffHT Rig
Blu-Ray- 80 GB PS3
deletedMain 2ch -
TV 3.1 system -
I guess you gotta be leery with no pics but I guess you can always ask the seller to email some.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=230450106239I love animals, they're delicious! -
Never heard Jamo stuff, but not a bad price for a pair of what could be high quality bookshelf speakers
http://www.amazon.com/Jamo-cherry-Concert-bookshelf-speaker/dp/B00389JOZM/ref=pd_bxgy_e_text_b- Jeremy
Amps: Jolida FX-10, NAD 3045, NAD C320BEE, Sansui G-9700
Speakers: Polk Monitor 7A's, KEF Reference 104aB
Sources: ProJect Debut Carbon, Sonos streaming FLAC -
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=260568318150&ssPageName=STRK:MEWAX:IT
this sounds goodSamsung pn64f8500
Sf venere center
Oppo 105d
Squeezebox touch
Parasound hca1500a
Apc power filter
Polk rtia3 SB
Polk fxia6 sl,sr
Dual hsu vtf3 mk3 -
Check this out on Craigslist, wow I wish I had the room for all of these. 9 Polk Speakers total. (2) RT5, (2) RT55, (2) RT35i, (2) RT55i, and (1) PSW202 SubWoofer. Oh yeah and an Onkyo receiver.
http://washingtondc.craigslist.org/mld/ele/1652452416.html -
I actually got those last week.. Really nice and more bass extension than you would think for the size. compared to my 60s I had never heard a more natural piano sound. I was really surprised at how well they fill the room. they will be used a tv only set of stereo speakers with occasional 2 channel use of cable music channels.. all i need now is an integrated and looking to pickup the Cambridge 340 from audioadvisor when i get the cash. For just 80 bucks for the pair they are a stealMain 2ch -
TV 3.1 system -
Magneplanar on ebay with 49.99 starting bid?:eek: The real deal??
http://cgi.ebay.com/MAGNEPLANAR-MG-II-Floor-Standing-Speakers_W0QQitemZ320505087404QQcmdZViewItemQQptZSpeakers_Subwoofers?hash=item4a9f9785acI love animals, they're delicious! -
greyford1979 wrote: »Magneplanar on ebay with 49.99 starting bid?:eek: The real deal??
I have two pairs of these.. they are amazing!Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
I'm sure with the amount of time left on the auction these will get some bids eventually...I would imagine even if somebody had these shipped it would still be worth it if they truly are in this great of condition.I love animals, they're delicious! -
Main 2ch -
TV 3.1 system -
