Looking for Misc Audio Deals of the Day? Updated info here!
1…7273757778…359
  • hearingimpared
    hearingimpared Posts: 21,136
    edited March 2010
    Amherst wrote: »
    The unit has the UL 1449 second edition listing that I understand is very important.
    I expect build quality to be at least as good as Monster. My experience with other Niles stuff is that it is on a more professional level than most monster products.The unit has some serious power filtering specs also. Comes with a built in 12v trigger.
    Should have mine next week if you want to wait. I'll post a first impression.
    Stu, any idea as to how much current limiting they use?
  • Amherst
    Amherst Posts: 695
    edited March 2010
    Hi Joe.
    Are we talking total current through the unit? It has a 15A circuit breaker built into the rear of the unit. Some other specs are over voltage and under voltage protection. Niles claims the unit also beats the UL spec (<300v) for capturing spikes, one of only a few on the market to have the ability.
    Parasound C1, T3, HCA-3500, HCA-2205A, P/DD1550, Pioneer DV-79avi, Oppo BDP-83, WD Media Server W/HDD,
    Dynaudio Contour 3.3, Dynaudio Contour T2.1, Polk OWM3, Polk DSW micropro 1000 (x2),
    Pioneer Kuro 50" Plasma, Phillips Pronto Control w/Niles HT-MSU.
  • hearingimpared
    edited March 2010
    Amherst wrote: »
    Hi Joe.
    No Stu, I referring to the outlets of the power conditioners. For instance, my Monster HTS 5100 MKII (now dead) unit had specific outlets for specific pieces of gear i.e., digital outlets for CDPs, outlets for preamps, outlets for power amps etc. The power amp outlets were no good because they had current limiting circuitry which would limit the current drawn by the power amp. This would interfere with the dynamic demand for current on let's say heavy bass draws or just increases needed to complete dynamic range necessities changes.
    I believe my amp has filter circuits to clean up the power thus I plug it directly into the wall to avoid the current limiting circuitry in the power conditioners.
  • sandworms
    sandworms Posts: 1,043
    edited March 2010
    Samsung pn64f8500
    Sonus faber venere 2.5
    Sf venere center
    Oppo 105d
    Squeezebox touch
    Parasound hca1500a
    Apc power filter
    Audioquest cables asst
    Polk rtia3 SB
    Polk fxia6 sl,sr
    Dual hsu vtf3 mk3
  • Amherst
    Amherst Posts: 695
    edited March 2010
    Joe, I don't see a spec in the manual for an individual outlet rating.
    Some manufacturers units provide surge protection by using "sacrificial" technology, this unit does not. This makes me think there may not be a restriction inline with the 15A breaker rating. Am looking into this further. The fleabay guy also has a 6 outlet unit available with the same technology for really cheap and it may be better suited to use for amp line filtering/circuit protection.
  • hearingimpared
    edited March 2010
    Thanks you Sir!
  • sandworms
    edited March 2010
    Samsung pn64f8500
    Sf venere center
    Oppo 105d
    Squeezebox touch
    Parasound hca1500a
    Apc power filter
    Polk rtia3 SB
    Polk fxia6 sl,sr
    Dual hsu vtf3 mk3
  • Conradicles
    Conradicles Posts: 6,437
    edited March 2010
    VMPS sub in Denver for $150...I'd jump all over that but I'm in NC:
    http://denver.craigslist.org/ele/1641595747.html
  • sandworms
    edited March 2010
    more subage no affl with any of these, just bored and shopping around
    http://orlando.craigslist.org/ele/1597849668.html
    Samsung pn64f8500
    Sf venere center
    Oppo 105d
    Squeezebox touch
    Parasound hca1500a
    Apc power filter
    Polk rtia3 SB
    Polk fxia6 sl,sr
    Dual hsu vtf3 mk3
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited March 2010
    That's a great price. Wish I was closer.
  • sandworms
    edited March 2010
    Samsung pn64f8500
    Sf venere center
    Oppo 105d
    Squeezebox touch
    Parasound hca1500a
    Apc power filter
    Polk rtia3 SB
    Polk fxia6 sl,sr
    Dual hsu vtf3 mk3
  • lectronicjunkie
    lectronicjunkie Posts: 299
    edited March 2010
    sandworms wrote: »
    Wow!! You and me both. :D
    It's all in the detail.
    :cool:
    HT Setup:
    Samsung PN50D550
    Onkyo TX-SR805
    Samsung BD-D6700
    Fronts: RTi10's
    Center: CSi5
    Side surrounds: RC65i's
    Rear surrounds: FXiA4's
    Sub: Velodyne CT120
    Outdoor: Atrium 45's
    Pictures here
  • coolsax
    coolsax Posts: 1,826
    edited March 2010
    Main 2ch -
    BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
    TT - Pro-ject Classic SB with Sumiko Bluepoint.
    TV 3.1 system -
    Denon 3500 -> Dynaudio Excite 32/22
  • coolsax
    edited March 2010
    beresford DAC in Austin no afill
    http://austin.craigslist.org/ele/1644487086.html
    Main 2ch -
    TV 3.1 system -
  • seeclear
    seeclear Posts: 1,244
    edited March 2010
    Monitor 10's (? I think) for $100 Denver Co area
    http://denver.craigslist.org/ele/1645425647.html
    "Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
  • hearingimpared
    edited March 2010
    seeclear wrote: »
    Polk Audio Monitor Series Tower speakers. Amazing sound quality and solid construction in these tower speakers. I have a pair for sale for $100. They are made of a 10" woofer, two 7" midrange speakers and a 1" tweeter on each pair. I would estimate the weight of each tower speaker at about 40 lbs- they are VERY solidly constructed. They measure 28" high 11.5" deep and 16" wide.
    Towers????:confused::confused::confused: Twenty-eight inches high does not a tower make.
  • j allen
    j allen Posts: 363
    edited March 2010
    cruising ebay, found these ls50's
    http://cgi.ebay.com/POLK-AUDIO-LS50-LS-50-FLOOR-STANDING-SPEAKERS-ROSEWOOD_W0QQitemZ130373360407QQcmdZViewItemQQptZSpeakers_Subwoofers?hash=item1e5adb9b17
    looks like they need some tlc, but seems a good price to me. no affiliation
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited March 2010
    Newegg.com has the Monitor 40's on sale for $119.99 w/ free shipping. Promo code EMCYPZT58.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • jparker82
    jparker82 Posts: 54
    edited March 2010
    Onkyo Tx Nr 5007
    Integra NAS 2.3 audio serv
    Intergra DHS 8.8 HD-DVD
    Integra NVS 7.7 Home Theater Media Compt
    Anthem MCA 20
    Integra 70.1 9 channel amp
    OPPO 93 BLU RAY
    Monster HDP-2400 power cond
    Panamax M5300 PM
    Monster HtS-2600 Power cond
    Samsung 8000 series e64 plasma
    Polk LSI 25
    Polk LSI center
    Polk LSI 9
    Polk LSI 7
    Polk LSIM702 fx
    Boston Acoustic in ceil #'s ???
    Definitive tech sub
    Nordost Blue Heaven Rev2 BI wire(great cords)
    2 other systems master and pool area
  • wutadumsn23
    edited March 2010
    Newegg has the Cherry Monitor 70's on sale for $169.99 w/ free shipping. Promo code EMCYPZW34. Also, on a side note, the Cherry CS1 is on sale for $67.99 w/ free shipping. Promo code EMCYPZW35. I know the Cherry ones aren't as sought after as the Black ones, but still one hell of a deal.
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
  • coolsax
    edited March 2010
    deleted
    Main 2ch -
    TV 3.1 system -
  • greyford1979
    greyford1979 Posts: 749
    edited March 2010
    I guess you gotta be leery with no pics but I guess you can always ask the seller to email some.
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=230450106239
    I love animals, they're delicious!
  • Zitro
    Zitro Posts: 864
    edited March 2010
    Never heard Jamo stuff, but not a bad price for a pair of what could be high quality bookshelf speakers
    http://www.amazon.com/Jamo-cherry-Concert-bookshelf-speaker/dp/B00389JOZM/ref=pd_bxgy_e_text_b
    - Jeremy
    Amps: Jolida FX-10, NAD 3045, NAD C320BEE, Sansui G-9700
    Speakers: Polk Monitor 7A's, KEF Reference 104aB
    Sources: ProJect Debut Carbon, Sonos streaming FLAC
  • sandworms
    edited March 2010
    Samsung pn64f8500
    Sf venere center
    Oppo 105d
    Squeezebox touch
    Parasound hca1500a
    Apc power filter
    Polk rtia3 SB
    Polk fxia6 sl,sr
    Dual hsu vtf3 mk3
  • slvbeard
    slvbeard Posts: 6
    edited March 2010
    Check this out on Craigslist, wow I wish I had the room for all of these. 9 Polk Speakers total. (2) RT5, (2) RT55, (2) RT35i, (2) RT55i, and (1) PSW202 SubWoofer. Oh yeah and an Onkyo receiver.
    http://washingtondc.craigslist.org/mld/ele/1652452416.html
  • coolsax
    edited March 2010
    Zitro wrote: »
    I actually got those last week.. Really nice and more bass extension than you would think for the size. compared to my 60s I had never heard a more natural piano sound. I was really surprised at how well they fill the room. they will be used a tv only set of stereo speakers with occasional 2 channel use of cable music channels.. all i need now is an integrated and looking to pickup the Cambridge 340 from audioadvisor when i get the cash. For just 80 bucks for the pair they are a steal
    Main 2ch -
    TV 3.1 system -
  • greyford1979
    edited March 2010
  • ViperZ
    ViperZ Posts: 2,046
    edited March 2010
    I have two pairs of these.. they are amazing!
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • greyford1979
    edited March 2010
    ViperZ wrote: »
    I'm sure with the amount of time left on the auction these will get some bids eventually...I would imagine even if somebody had these shipped it would still be worth it if they truly are in this great of condition.
  • coolsax
    edited March 2010
    nice integrated in austin
    no affill
    http://austin.craigslist.org/ele/1656636975.html
    Main 2ch -
    TV 3.1 system -
