what would you buy
13»
  • glemay
    glemay Posts: 574
    edited October 2003
    Will I hear a BIG diffrence between a SVS PCi 20-39 and my current Sound Dynamics THS-3000. It is a 12" downfiring subwoofer with a 150 watt Mosfet Amp capable of 100 watts RMS. The box is sealed and the specs I found said it could play down to 25Hz.
    Remember that my room is about 20x13x7 and the sub is in a corner.
    What do you guys think?
    I want a SVS but don't feel like spending the money.
    Gerald Lemay
    Main System:
    Denon AVR-2805, Polk Audio RTi70's, Polk Audio CSi40, Polk Audio FXi50, Paradigm PW-2200 v.2, Toshiba 42XV545U HDTV
    Second System:
    Denon AVR-1705, Polk Audio R40, Polk Audio CS245i, Polk Audio R15, Paradigm PS-1200a
  • Dr. Spec
    Dr. Spec Posts: 3,780
    edited October 2003
    The sound so far without calibrating is first rate and has a sonic presence that has no equal as far as I'm concerned.
    No one wants to spend money on gear, but with SVS you get MORE than you pay for. Kberg didn't want to pony up for the PC+ and 10 minutes after hearing it, wondered why he didn't do it sooner.
    SVS
  • kberg
    kberg Posts: 974
    edited October 2003
    Ya got that right. And glemay, after a bit of time, you or your significant other (if you have one) won't care. And in my case, over time, my SVS has kept reminding me of how smart I was to spend the extra bones for the 20-39 PC+. :)
    Mains: polkaudio RTi70's (bi-wired)
    Center: polkaudio CSi40 (bi-wired)
    Surrounds: polkaudio FXi30's
    Rear Center: polkaudio CSi30
    Sub: SVS 20-39 PC+
    Receiver: ONKYO TX-SR600
    Display: JVC HD-56G786
    DVD Player: SONY DVP-CX985V
    DVD Player: OPPO DV-981HD 1080p High Definition Up-Converting Universal DVD Player with HDMI
    Remote: Logitech Harmony H688
  • glemay
    glemay Posts: 574
    edited October 2003
    Thanks Kberg, but I don't have to worry about the "significant other" since I'm only 15.
    Were you initially planning on buying the PC PLUS 20-39?
    How do you think a Paradigm subwoofer in the same price range as the PCi 20-39 would perform?
    GLemay
    Main System:
    Second System:
  • Airplay355
    Airplay355 Posts: 4,298
    edited October 2003
    dude unless u wanna build ur own sub, just buy the svs
  • dave shepard
    dave shepard Posts: 1,334
    edited October 2003
    You can end up spending far more money buying and trying to find a good enough sub not to mention all the running around you will do, SVS is the only choice you'll need to make and they are only a phone call away (not a drive). As the old saying goes "how can so many people be so wrong".
    Dave
