Replacing driver advice...
esowden
esowden Posts: 55
edited February 2010 in Troubleshooting
When replacing a driver - which wire connects to the terminal with the red dot?
Den
Parasound 2100
Parasound 2125
Denon DCM-390
LG BD390V
Martin Logan Preface(x2)
Denon AH-D2000
Bedroom
Adcom GTP-350
Parasound HCA-800II
Panasonic DVD-S54
Denon AH-2000
Polk S4(x4)
ಠ_ಠ
Post edited by esowden on
  • ben62670
    ben62670 Posts: 15,969
    Which speaker? Polk uses mainly Black on the positive.
    Ben
  • sandworms
    sandworms Posts: 1,043
    aren't the terminals different sizes?
    Samsung pn64f8500
    Sonus faber venere 2.5
    Sf venere center
    Oppo 105d
    Squeezebox touch
    Parasound hca1500a
    Apc power filter
    Audioquest cables asst
    Polk rtia3 SB
    Polk fxia6 sl,sr
    Dual hsu vtf3 mk3
    Toolfan66 Posts: 18,189
    sandworms wrote: »
    The drivers have the same size, most of polk's tweeters do as well.
  • kcoc321
    kcoc321 Posts: 1,788
    ben62670 wrote: »
    Like Ben said, First identify your speakers. Then you or someone can look at the wiring diagrams. They will tell you, or someone that has the same speakers can.
  • esowden
    esowden Posts: 55
    Thanks for the replies.
    They are S4 speakers.
    According to the online schematic - Polk denotes the black wire to the mid-range driver as positive. The schematic doesn't have anything in it's notes concerning which speaker terminal is marked. Some speaker companies mark their negative terminals and some mark their positive.
    I realized that all I had to do was pull a driver from another S4 to see how it was wired. Next time - I'll leave the bad driver connected instead of committing things to memory. :D
    Den
    Parasound 2100
    Parasound 2125
    Denon DCM-390
    LG BD390V
    Denon AH-D2000
    Bedroom
    Adcom GTP-350
    Parasound HCA-800II
    Panasonic DVD-S54
    Denon AH-2000
    Polk S4(x4)
    ಠ_ಠ
