Replacing driver advice...
esowden
When replacing a driver - which wire connects to the terminal with the red dot?
Den
Parasound 2100
Parasound 2125
Denon DCM-390
LG BD390V
Martin Logan Preface(x2)
Denon AH-D2000
Bedroom
Adcom GTP-350
Parasound HCA-800II
Panasonic DVD-S54
Denon AH-2000
Polk S4(x4)
ಠ_ಠ
Parasound 2100
Parasound 2125
Denon DCM-390
LG BD390V
Denon AH-D2000
Bedroom
Adcom GTP-350
Parasound HCA-800II
Panasonic DVD-S54
Denon AH-2000
Polk S4(x4)
ಠ_ಠ
Post edited by esowden on
Which speaker? Polk uses mainly Black on the positive.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
aren't the terminals different sizes?Samsung pn64f8500
Sonus faber venere 2.5
Sf venere center
Oppo 105d
Squeezebox touch
Parasound hca1500a
Apc power filter
Audioquest cables asst
Polk rtia3 SB
Polk fxia6 sl,sr
Dual hsu vtf3 mk3 -
The drivers have the same size, most of polk's tweeters do as well. -
Like Ben said, First identify your speakers. Then you or someone can look at the wiring diagrams. They will tell you, or someone that has the same speakers can. -
Thanks for the replies.
They are S4 speakers.
According to the online schematic - Polk denotes the black wire to the mid-range driver as positive. The schematic doesn't have anything in it's notes concerning which speaker terminal is marked. Some speaker companies mark their negative terminals and some mark their positive.
I realized that all I had to do was pull a driver from another S4 to see how it was wired. Next time - I'll leave the bad driver connected instead of committing things to memory.
Den
Parasound 2100
Parasound 2125
Denon DCM-390
LG BD390V
Denon AH-D2000
Bedroom
Adcom GTP-350
Parasound HCA-800II
Panasonic DVD-S54
Denon AH-2000
Polk S4(x4)
ಠ_ಠ
