Major Upgrade My 2 Channel System
1235»
  • AudioFilet
    AudioFilet Posts: 235
    edited February 2010
    Which platter do you have on it?
    BTW a better reflex clamp other than what comes with the MMF5.1 will make a big improvement also. If you have the coin I highly recommend the following;
    http://store.acousticsounds.com/d/36249/Clearaudio-Twister_Clamp-Record_Mats_and_Clamps
    If you decide to get it I can send you some delrin shims that will improve and stregthen the reflex action and it will wow you on depth of bass response, lowering the noise floor thus improving imaging, inner detail, bloom and decay etc.
    It has the stock platter on it. I was unaware of a platter upgrade.
    As for the clamp, coin is no problem there, but it's backordered. What is a "reflex clamp" & how does it work?
    2 Channel rig:
    LSi9"s (modified xover's) & HSU Sub
    Harman Kardon HK 990 Amp
    Onkyo C-S5VL SACD
    Music Hall MMF 5.1
    Furman Elite 15
    HT rig:
    HK AVR-745 & Polk Monitor Series
  • hearingimpared
    hearingimpared Posts: 21,136
    AudioFilet wrote: »
    Is it glass or acrylic?
    AudioFilet wrote: »
    You can get that clamp from;
    http://www.audioadvisor.com/prodinfo.asp?number=CLTWICL
    or
    http://www.needledoctor.com/Clearaudio-Twister
    I believe both have them in stock.
    A reflex clamp forces the record to make intimate contact with the platter from the label all the way out to the lead in bead. With the shims I told you about it literally forces the record (safely) to take the shape of the platter thus removing warps and causing mucho damping in that the stylus sees an inch thick platter instead of a thin record. It dampens stylus vibrations, footfalls as well as airborne vibrations. This clamp has a delrin base. Delrin is a first cousin to the vinyl used in records and is a better impedance match than any other material thus improving the dampening power even better. With the shims, you have the versatility to use different thicknesses to remove stubborn warps or provide more down pressure needed on 180 & 200 gm records.
    If you have an acrylic platter you will get even more damping improvement as vinyl, acrylic and delrin are all first cousins and have less impedance interacting with each other.
    Don't just take my word for it, post a new thread about reflex clamps and you will see how many people use them and how effective they are. They dramatically improve the sound of your turntable.
    Hope this helps.
  • hearingimpared
    BlueFox wrote: »
    Damn. That sounds like something Pierre would say. :D
    http://shop.mapleshadestore.com/products.asp?dept=117
    I found that out in 1984 when I researched and developed my own clamp and sold hundreds over the years. I think Pierre stole my mantra!:D
  • hearingimpared
    BlueFox wrote: »
    That inglorious basterd!!!
    LMAO!!! I think the whole concept of impedance matching vinyl has been around for a long, long time. That's why a lot of TT manufacturers went with acrylic and delrin platters and some form of delrin/acrylic hybrids on their clamps in the late '70s - early '80s.
    The same goes for brass having a better impedance match to stainless steel. That's why I used a brass collet in my clamp vs a stainless steel collet which just reflected the vibrations back to the record out to the stylus. Brass also has excellent dampening properties as you well know.
  • AudioFilet
    Hope this helps.
    Wow. Never knew any of that.
    The platter on this thing appears to be metal of some sort. The spindle is about an inch high, and is threaded on the end for the clamp that comes with it. This platter rests on top of a "sub-platter" (probably delrin, acrylic, or something along those lines). The drive belt goes around this "sub-platter" and the motor spindle. The specs for the TT say the platter is "dynamically balanced alloy". Will that clamp work with this thing??
    2 Channel rig:
    Onkyo C-S5VL SACD
    Music Hall MMF 5.1
    Furman Elite 15
    HT rig:
  • AudioFilet
    There is an acrylic platter upgrade for this TT. Thing is, most indications are that you normally use an acrylic platter without a mat. True?
    2 Channel rig:
    Onkyo C-S5VL SACD
    Music Hall MMF 5.1
    Furman Elite 15
    HT rig:
  • hearingimpared
    AudioFilet wrote: »
    Yes it will.
  • hearingimpared
    AudioFilet wrote: »
    That is very true. I would look into the acrylic upgrade as it will really improve the sound of the table even more in that you will be coupling the record directly to the platter. Plus acrylic is very easy to maintain. Harry Weisfeld, owner of VPI, recommends using plain Windex on his delrin & acrylic platters. That's what I use on mine . . . no muss, no fuss, no residue.
    You can always resell the Herbie's mat here as people are always asking about it and it is a very good mat.
  • george daniel
    george daniel Posts: 12,096
    Hey Joe,, where you goin' with that clamp in your hand?
    Seriously,, for my education please give me your personal opinion/rating--the Clearaudio twister,,or the VPI stainless/delrin clamp for a VPI scout,please sir.
  • hearingimpared
    George, I would go with the Twister clamp as you have more control over the down pressure and adjustment for warp removal and better intimate contact with the platter. With the VPI you're simply **** it down and frankly screw down clamps don't work as well as a clamp with a grabbing collet. The collet pulls up on the spindle while the twist top exerts down pressure on the base so you get a two fold action. Plus IIRC the Twister clamp has more delrin mass to it than the VPI. You know how much I love VPI products but in this case the Clearaudio Twister is better choice and uses the same basic principles that my clamp was designed to do. Plus you get better impedance matching with the delrin base to record and the brass collet to stainless steel spindle.
    heiney9 Posts: 25,421
    Audiofilet, listen to Hearingimpaired he really knows what he's talking about when it come to vinyl and the TT clamp. Huge improvements can be gained by using an excellent clamp, platter and mat, etc.
  • hearingimpared
    Thanks for the kind words Brock. I'm humbled by your confidence.
