what would you buy
glemay
what would you buy if you were in canada?
-SVS 20-39PCi
-SVS PB1 ISD
-Paradigm PDR 12
-Paradigm PS-1200
-Paradigm PW-2200
-Paradigm PS-1000
-Paradigm PW-2100
-Velodyne CHT-12
I want the sub that will perform the best with music and ht
I have a room that is 20 feet by 13 feet with a 7 foot ceiling.
My system consist of:
Mains: RTi70
Center: Paradigm CC-170
Surrounds: Paradigm Micro
Receiver: Denon AVR-1803
DVD Player: Toshiba SD-2900
thanks
-SVS 20-39PCi
-SVS PB1 ISD
-Paradigm PDR 12
-Paradigm PS-1200
-Paradigm PW-2200
-Paradigm PS-1000
-Paradigm PW-2100
-Velodyne CHT-12
Mains: RTi70
thanks
Main System:
Denon AVR-2805, Polk Audio RTi70's, Polk Audio CSi40, Polk Audio FXi50, Paradigm PW-2200 v.2, Toshiba 42XV545U HDTV
Second System:
Denon AVR-1705, Polk Audio R40, Polk Audio CS245i, Polk Audio R15, Paradigm PS-1200a
Second System:
Post edited by glemay on
None of the above.
I'd go the passive SVS route with a separate amp.
Cheers,
Russ
SEVEN foot ceiling? Did I read that right?Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
a SEVEN foot ceiling? Jeeze, I'd be claustrophobic.
russman
you read it right, 7 foot ceiling. I got my system in my bedroom which is on the third floor which is like an attic with the sloped ceilings. go to the system showcase and look at glemay, you will see what I mean.Main System:
Second System:
Denon AVR-1705, Polk Audio R40, Polk Audio CS245i, Polk Audio R15, Paradigm PS-1200a -
troy d,
it's not bad, seeing as am only 15 and 5 foot 9 inches. I banged my head a few times:rolleyes:Main System:
Second System:
I would pick the SVS PB-ISD, but I think all the choices are very nice.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
dorokusai,
why would you say i live in a hobbit house?
Main System:
Second System:
That was before I noticed the attic comment, sorry. The short ceiling height is what I was originally refrring to, I was only kidding.
CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
dorokusai,
what kind of sub do you have? What do you think of SVS cylinders?Main System:
Second System:
doro and his sub, "don't count" Next question......... Oh that was cold.. sorry doro ol bud!
Kidding, he can help with most any other questions you may have though...
MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
is there a huge diffrence in performance between the PCi 20-39 and the PCi Plus 20-39?Main System:
Second System:
Where's the HSU VTF-2?
My 7.1 setup consists of:
Denon 3803
Panasonic DVD
RTi70s front
CSi40 front center
RTi28s side surround
FXi30s back surround
PSW202 Subwoofer - Hey, it's my first sub!
RCA 46" 4:3 RPTV -
glemay,
I'm going to quote Doc from an early post I had which addressed the same question, and was enough for me to get the 20-39 PC+. From Doc...
The 20-39PC+ has about a 5-6 dB performance advantage below 30 Hz over the 20-39PCi. It also has somewhat less distortion, but both are remarkably low anyway.
You also get:
- the triple flared ports and port plugs for variable tuning (20, 16, 12), although the stock tune works the best
- 0-180 continuously variable phase control
- 4 position (25, 20, 16, 12) SS filter
- 525 watt BASH amp
The PC+ advantage will probably be most noticeable in a larger room. If you have never bottomed out the PCi and you play it as loud as you want, then I don't see the need.
From a FR and extension standpoint, they will measure almost identically in stock tune. The PC+ can be tuned deeper but it's not muh of a benefit since in stock tune its flat to about 18 Hz in room. I always ran mine in stock tune unless I was **** around running sweeps or experimenting, etc.
========================Mains: polkaudio RTi70's (bi-wired)
Center: polkaudio CSi40 (bi-wired)
Surrounds: polkaudio FXi30's
Rear Center: polkaudio CSi30
Sub: SVS 20-39 PC+
Receiver: ONKYO TX-SR600
Display: JVC HD-56G786
DVD Player: SONY DVP-CX985V
DVD Player: OPPO DV-981HD 1080p High Definition Up-Converting Universal DVD Player with HDMI
Remote: Logitech Harmony H688 -
kberg,
Thanks for the information. I e-mailed SVS to see what they would recommend.
JerryMain System:
Second System:
By the way Kberg,
How big is your room and how do you like the sub?
JerryMain System:
Second System:
-SVS 20-39PCi
-SVS PB1 ISD
-Paradigm PDR 12
-Paradigm PS-1200
-Paradigm PW-2200
-Paradigm PS-1000
-Paradigm PW-2100
-Velodyne CHT-12
Mains: RTi70
thanks
glemay, what the ? of what would I buy if in Canada? I'd buy those ones that I liked even if in the US or Mexico.
BTW i'm very happy with my SVS 20-39PCi. I haven't heard the other ones before. SVS mates well with Polk fronts.PolkFest 2012, who's going>?
dorokusai,
FYI i do indeed live in a hobbit house. Alll my ceilings in the upstairs of my house are all 7' high. luckily i'm only 3'4" tall. :eek:
seriously, it's an unusual house. the first floor all have 8 ft ceilings, but not the second.PolkFest 2012, who's going>?
glemay, for 15 here's the deal, you are probably going to take this sub to college, and so the tube just makes more sense because its easier to carry and lighter than the box. Having people help you move your stereo stuff is usually annoying.
that's true. the only part of my system I would let any of my family or friends move for me would be the cables and wires. otherwise keep your paws off my electonics. sorry i'm so anal about this. but i spent to much (hard earned) money on components to let someone drop my DAC or receiver. ugh... shudder the thought.PolkFest 2012, who's going>?
Faster - I'll get you! Damn, you busted on my lil' 202....wait till I let him know about that
Glemay - I just have the cheapy. I have squared away other parts of my HT first...the sub will be the very last item. SVS really has a large following, and is known in the audio community as a Giant killer.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
I've been talking to Tom at SVS and he suggested the PB2 PLUS. The sad thing is I can't afford it, so I asked him to look for an alternative route.Main System:
Second System:
damn the pb2 plus?
im 16 and my room is 15x12xlike 7 1/2 ( its not quite 8 ft) and im gonna get the svs 20 -39 pci. i think being that i just turned 16 and want a car, $550 is the most i really want to spend on a subwoofer. your room is just alittle bit bigger then mine though lol. oh well, i think that you will be happy with any svs you get. -
By the way Kberg,
Jerry
20' x 14.5' x 8.5' - and the SVS is incredible, to say the least.Mains: polkaudio RTi70's (bi-wired)
Sub: SVS 20-39 PC+
airplay
I am pretty well in the same situation as you. I dont really want to spend more than 1000 dollars canadian on a sub. I will probably get the PCi 20-39 or the PC plus 20-39 or somewhere in that price range.Main System:
Second System:
kberg how loud do you listen to your music/dvd? does the PC plus 20-39 keep up without a problem?Main System:
Second System:
u could always buy a polk sub
airplay
I already have a polk PSW202 hooked up to my computer. I have a Sound Dynamics THS-3000 hook up to my ht system, but I don't like it.Main System:
Second System:
unlesss you have a really large open and airy room... I would think the 20-39PCi or PCi Plus would work pretty good for most people... as long as you're in the market for a cylinder sub. So far i don't think i've run into anyone that has hated their SVS sub, whether it was the box or cylinder sub.
i was joking about the polk sub...thats what the
was there for. you sound very serious for being 15. just get the svs 20-39 pci or the plus, you wont be disappointed, and if you are doc will probably pay the shipping cost to send it back. ( as long as its under $35) -
Airplay,
Ya I'm pretty serious about this audio thing. I really enjoy excellent sound in music and movies. The only people that don't really care for it are my parents and my 3 sisters, oh well:D. I will probably end up with a PCi 20-39 or something around there. Just hope my parents will let me buy it. When will you be getting your Airplay? Let me know what you think!
JerryMain System:
Second System:
Same boat as you dude. 14 years old. similar rig.
I just don't have the full surround sound (YET).
I have the RTi70 with the RT35i stacked on top of it for mains.
I to plan to purchase the 20-39 PCi around Christmas time. Bring on the rumble!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
