Bi-Wire yes or no
sTiLlLeArNiNg wrote: »lol Just like an Emotiva amp!
Buy decent cable's and be done with it :cool: The Canare 4s11 is a great option at a great price as is the Belden 5000
Better cable's does = better sound but i think once you get into the $200+ PER cable realm you get to the point of diminishing return's and great marketing
Just my $0.02
PS That's a Canadian $0.02 hehehe
You get to the point of diminishing returns the second you hook up ANY system, even if it's pure crap with radioshack cables.
You just went from NO music, to music. Anything else from there will not garner the same improvement, at any price.
It's up to you how far you want to go. As heiny9 said, it's subjective. If you can't afford an upgrade, then you can't afford an upgrade, so you won't see a return.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
Like virtually all manufacturers do. However, some hype borders on science fiction while some hype is based upon more objective points.
I have no issue with the hype. My problem is with outright lies.
And you determined they were outright lies how? -
hearingimpared wrote: »It is not hype, it is personal experience of which you haven't provided any insight into yours. You just keep bashing better speaker wire. What rig are your running? What ICs and speaker wire have you tried? I'm betting you are buying into the "hype" that Rodger Russel spews.
Cogito why aren't you answering the above questions. -
Experiment time.
Today I am upgrading my HT from Orchard Supply Hardware 12 gauge copper twisted to Mapleshade Clearview Double Helix with Plus upgrade speaker cables. This will be a good experiment for two reasons. First, some people say multi-channel HT does not matter for good sound. Two, some people say wire does not make any difference.
So, if later tonight I hear a difference then two misconceptions will be put to rest, or I will have spent $1100 on 5 speaker cables for no reason.
To be honest, I know these cables work since I had a pair on my 2 channel system, and they made an incredible improvement over the hardware store copper, and I expect to hear the same improvement in the HT. So, yes, there is a bit of built-in bias in this experiment, but it is a bias based on experience, and not based on reading an article from the Internet. The only question is the amount of improvement that will result.
I recently upgraded the 5 analog ICs between the pre/pro and the amp, and that upgrade resulted in more detail being heard in areas such as leaves rustling, glass breaking, footsteps, etc. Hopefully, the speaker cables will expand on that, and more.
This is also a Polk Audio experiment since the HT has 4 LSi15s, and a PSB Synchrony One center. The PSW1000 sub runs off the front L/R pre-outs via Radio Shack RCAs.
http://www.mapleshaderecords.com/audioproducts/doublehelixspeakercable.phpLumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
So, what are you listening to again? What gear and wire are you using? What experience are speaking from?
You are a complete bag of wind to me until you post your system specs.
Why can't/won't you do that?
Simple question. Can you accommodate?-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
Muscial Fidelity M1 DAC
VTL 2.5
McIntosh 2205 (refurbed)
B&W 801's
Transparent IC's -
IC's make more of a difference than speaker cables. My buddy and I used some AR IC's and we thought something was very wrong. I put my cables in the loop and the SDA came back, and the highs returned.
+2 ICs suffer from noise and need proper shielding, speaker wire are not. -
So what actually happens during this burn-in? Do different cables require different burn in methods or time? Do you use music, test tones, white noise, etc?
during the burn-in outer shield of the cables burns ? no ? or maybe time after time your copper cables release some sort of chemical compound that makes speakers sound better.........
i cant believe suckers fall for this myth....who ever thinks that cables burn-in must be stupid as a rat........oh wait......rats are actually smart. -
^^^ Ah, Troll Camp must have just graduated some new idiots!"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | Holo Audio Cyan 2 Dac | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
Oh FFS, not THAT site again.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
One day,the wife asked me to re-arange the room, I had my favorite speaker cable,Reality cables hooked up to my Focus 20/20's, but they were too short for the new arrangment. Went to Home depot to grab a spool of 12 ga. After the first 60 seconds I realized what a waste of money I just spent, soundstage shrunk,highs were shrill,low end not even close and the mids were soft...
The only pure objective way to determine the problem was only the cables would have been:
1. Test the Reality Cable with the same room arrangement (except, as mentioned, the cables were too short).
2. Test the Home Depot cable with the room reverted back to the old arrangement.
Otherwise, the room rearrangement could have been a problem, but the only cable used to determine there was a problem was the Home Depot cable. -
oh the other hand scratch that.........
new business in town.....I will burn your cables for you the professional way for $20 bucks a set. sorry no website yet, but i do have paypal ! -
Thanks Tom. -
I can read too. I can also try different cables and dicern the difference between the cable being burned in over time. It's a shame that you are suckered in by what other people opinions are on the subject without trying it on your own. Sheep! -
Why would I pay you when I can do it myself? I'll pay myself $20.
Nice try though :rolleyes:
No thanks you won't do it right because of an internet article. You will probably just send them back just as you received them. -
hearingimpared wrote: »No thanks you won't do it right because of an internet article. You will probably just send them back just as you received them.
but thanks to a thing called "placebo effect" i can assure you that most people will be 100% satisfied -
Wow you read about that too. What a genius. -
80% of the time it works every time?
Where's the post where you tell ME that I won't be able to hear a difference in a double blind test on MY system?I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
concealer404 wrote: »Where's the post where you tell ME that I won't be able to hear a difference in a double blind test on MY system?
It's coming.............some people can Google faster than others.
Wait for a link..............it'll be here soon from K
^ nothing is coming i am done wasting time. always the same people in all thread across the forum advocate cable myth bull.
Thank goodness the air will cool off now. -
Well i'll beat him to the punch.
K, you're more than welcome to come out here, or fly me wherever to perform a cable double blind test on me. But you won't take action on that. Because you don't want your precious double blind test to prove you wrong, since you believe that test to be the last word.
Damn... looks like i was late.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
It goes both ways. It's always the same thing with the naysayers as well. However, only one group actually knows and enjoys the audible truth.....Always the same people in all thread across the forum advocate cable myth bull.
Everyday.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
and ps......no offense. everyone is entitled to his own believes.
I'm sorry... does it harm you personally that i hear a difference?
I don't give a crap if you hear a difference yourself or not, but don't even try to come in here and tell me that i don't hear a difference. You can **** to your little placebo effect and Roger Russel all you want. I really don't care. You aren't going to convert anyone.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
Yeah right and I paraphrase, " all suckers," "dumb as rats!" -
That's "beliefs" there big guy. I thought you were done with this thread? You know, wasting time and all that?and ps......no offense. everyone is entitled to his own believes.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
I think you mean "beliefs" and you called anyone who believed in cable burn in and other cable properties "suckers and are as dumb as rats"
Nice back peddle, but you can STFU!
