Anything bad to say about this?
2
  • pearsall001
    pearsall001 Posts: 5,294
    edited October 2009
    Pycroft wrote: »
    Hi all...
    Just sold my AVR, and am about to purchase another. I've heard many positive things about the company but I'd like to hear some negatives too. Here's the possible setup:
    Harman Kardon AVR 354
    RTA 11TL's
    CS400
    Monitor 30's
    Def. Tech Prosub 800.
    I will be using it for 60% movies, 40% music. The reason I'm thinking of this AVR is because it reviewed VERY well for 2 channel listening, has what many have said is a very warm, musical sound, and does well with Movies as well. Also, I wanted one with preouts, so I can add an amp at a later time. The idea is eventually to add a 3-5 channel amp (Probably 3 for money reasons) to power the fronts, and let the AVR do the rest.
    Please let me knwo if you have anything negative to say about this setup, specifically focusing on the AVR (I know the subwoofer can get better, the rears, etc...but mainly focusing on the combination of the AVR and speakers, and the overall quality fo the AVR).
    If you have positive things to say about it, feel free as well, but looking for the possible downsides fo choosing the HK354.
    Thanks,
    James
    I think you're safe with using the HK for both HT & 2 channel listening. Give it an honest listen & if it meets your listening criteria then your home free. If not try a separate pre to achieve a different sound. I ventured down the separate's road (preamp w/ HT bypass) after listening to all the hullabalou about how much improvement I'd experience. Well, it just didn't happen for me... & I had 2 pretty good pre's, a CJ tube pre & a Krell SS pre.
    What I did get was nothing audibly better than what I already had (and was quite pleased with). If anything, I preceived somewhat of a different sound. But different has nothing to do with being better, I repeat...different has nothing to do with better! To my ears my NAD AVR won out & I sold them both. So, don't fall into the trap that just because you spend more $$$$ on anything audio related that it automatically equates to better sound. Nothing could be farther from the truth.
  • Pycroft
    Pycroft Posts: 1,961
    edited October 2009
    Thanks again to all...I still haven't received an answer to one thing.
    On the 354 - is it possible to plug a preamp with HT bypass AND an amp, or not? It has preouts but I'm not sure how it works to be honest.
    Thanks bunches, and good conversation...I've heard some kickin two channel systems - I mean really kickin - but I don' thave the cash for that...again, in the future, who knows :)
    James
    2 Channel/HT:
    Sony SS-M9 P's (ES version)
    Sony SS-M1CN Center Channel
    Polk RT800 Surround Speakers
    Odyssey Stratos Dual Mono Amplifiers
    TAD 150 Signature Tube Preamp
    Harman Kardon HK354
    Sony SACD Player
  • PSOVLSK
    PSOVLSK Posts: 5,382
    edited October 2009
    steveinaz wrote: »
    We have to remember that not everyone is into hi-fi to the "nth" degree. Some people just want a good solid system without being an audiophile.
    I have to disagree strongly with the notion that a receiver is not "suitable" for serious music listening. Some people enjoy music, and some enjoy the equipment; there's a place in the hobby for both.
    Agreed.
    I've owned three H/K AVR's and have loved the sound quality of each one matched with Polk speakers. A negative would be the build quality. Of the 3 H/K units I've owned: one had to be replaced, another is having a few issues (but it is 10-15 years old), and my current one has a problem with the digital inputs.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited October 2009
    Pycroft wrote: »
    James
    It is possibe but without the HT by-pass those musical signal degrading parts found in all AVR's will still be present doing there thing and it can actually sound worse, the idea with the by-pass is to share one nice amplifier for the entire system. Buy the best you can. In the end you will spend more time enjoying your rig and less money overall.
    Have fun. I have owned both of those H&K's, both are gone, well, my son had one, so I guess technically it was still in the family, he dug it, he ought to, it was free (he did though take it to a pawn shop when he needed dough). They each sounded pretty much the same to me with the older Polk Monitor, RTA, SDA and RTi. I liked a NAD 1130, a Marantz 730 2-ch receiver, and a little Dodd Audio ELP (it had a by-pass, someone in this Club has it now, I think??)to name some I have experience with better than both H&K's for music, the AVR was better for mulit-channel HT so since your going to do HT no matter what you need an AVR so no waste in getting one.
    RT1
  • Pycroft
    edited October 2009
    PVOLSK - You say you've had problems with some HK's...have you had problems with the HK 354? And RT1 - you say you've owned (or at least it was in the family) the 354? Did you have any problems with it? To be honest, I am choosing this based on reviews and suggestions. I have about 350 bucks to spend, and can get a refurbished one from the HK store on ebay. I don't think I can do any better for the buck...true?
    James
    2 Channel/HT:
    Harman Kardon HK354
    Sony SACD Player
  • RandyBox
    RandyBox Posts: 125
    edited October 2009
    Pycroft wrote: »
    James
    For $350, you can't go wrong with the 354, IMO...
    Regards,
    Randy
  • Pycroft
    edited October 2009
    Here is a picture of the back of the HK354. I've never used an amp with an AVR. What kind of connections does it have? The preouts seem to have 7 RCA type plugs (one for a subwoofer). How many plugs are used for an amp? Is it one per amp channel (5 channel uses 5, 3 channel uses 3, etc.). If so, is it possible to use a 3 channel and a 2 channel seperately...and if so, is it better to do that or to buy one 5 channel? Also, how would a possible preamp with HT passthrough plug in, and how many of those 7 free plugs would be used.
    Thanks for the patience!
    James
    BACK.gif 155.9K
    2 Channel/HT:
    Harman Kardon HK354
    Sony SACD Player
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    edited October 2009
    The pre-out's are labled on the back of the AVR and you need only one interconnect cable to connect each channel on an external amp. For the pre-amp i think you would need 2 interconnect's going from the pre-amp (1 left + 1 right) to the input's on the backside of the AVR :o
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
  • apphd
    apphd Posts: 1,514
    edited October 2009
    Pycroft wrote: »
    And...my other AVR was the Onkyo 606. I wanted to get one with Preouts so I can add amplification to make my speakers sound better - they are very nice speakers IMO, that I was told would come alive with a dedicated amp. I also felt the ONkyo didn't make the music sound great, and figured with the HK AVR, and an amp, it would improve everything.
    James
    Ok From the 606 you will be gaining the pre outs and a warmer sound, which if I'm following you is what you are trying for. As far as overall qual. http://www.avsforum.com/avs-vb/showthread.php?t=1053202
    http://www.avsforum.com/avs-vb/showthread.php?t=1043407
    Lots to read there, keep in mind from my experience unhappy people are more likely to take the time to publish their opinion than happy people are. You will need to decide for yourself what the risk level is.
    Pycroft wrote: »
    Thanks all for the advice. I figure I'm 31 years old, I have plenty of time to keep going. Just to get this straight in my head, I CAN plug both a preamp and an amp into an AVR and use both at the same time, to mimic a straight 2 channel? A previous poster was right...I have very good speakers, but can't afford to hvae what I have, and buy two more front speakers, and all the goodies that go along for a strict 2 channel setup. Maybe the best would be the AVR, then an amp and preamp (If I CAN plug both in). Does anyone see anythign wrong with the receiver/speaker combo. I was told that the HK is known to be warm, and I belive my speaker combo also has a warm sound...is there too much warmth? :)
    Thanks,
    James
    You have the right process in mind here. If the HK issues do not scare you off (I think a lot of them depend on what sources are being used) and you go with it. I say give it a shot by itself, it has very respectable power, and may not need an amp right away. After you give it a listen shop for an amp, after having the AVR for a while with out an amp you will have a better idea if you want to go with a 2 - 3 - or 5 ch. amp. After this then decide if you still feel you may want to try a 2 ch pre with HT bypass.
  • Pycroft
    edited October 2009
    Apphd -
    I will NOT read that thread, as it would take me a week. I have had a number fo discussions and was told that the problems have pretty much been fixed with firmware updates, etc. The HK I would be getting is refurbished, but has a 1 year warranty, so I hope that makes me safe. Any ideas if the HK still has handshake issues, or any other issues that have NOT been dealt with through updates?
    Thanks,
    James
    2 Channel/HT:
    Harman Kardon HK354
    Sony SACD Player
  • apphd
    apphd Posts: 1,514
    edited October 2009
    James, sorry but no I do not know if handshake issue still exist, and I am not interested in reading through that thread ether.
    There have been recent posts by some new owners here in CP that are having no issues. Like I said I think many of the handshake issues are related to what it is hooked up to (just my opinion).
    Not sure what I would do in your shoes, the 354 looks to be perfect for what you are looking for. You could try some searches to see if all the updates addressed all/most of the issues. Personally I think I would give it a shot, but I would try (try meaning I probably would not read it all) going through the AVS thread first.
  • Ron Temple
    Ron Temple Posts: 3,212
    edited October 2009
    I still use the HK245 as a pre for HT and when I'm feeling lazy for music. It's not bad at all. There's no HT bypass. When I'm in the 2 channel mood, I hook a Luxman TP-114. It's a definite uptick. I just disconnect the front amp pre-outs from the HK, connect them to the pre and connect my player, BD83 through it's dedicated 2 channel outs to the Lux. Takes about a minute. The Luxman pre was a nice piece of midfi gear from the early 90s that streeted for $7-800. It was given to me, but they can be found for ~ $100. You can enjoy the best of both worlds fairly cheaply getting started.
    As far as the HK goes...I've recommended them to you privately, so nothing new. However, for piece of mind's sake, get one from HK Direct. Any warranty issues are a snap. They just swap out your unit no questions asked, for the 2 year period. If you buy one retail, you get snagged into the retailers service network, big delays and no guarantee that your problem is fixed...much simpler to plug in a new refurb.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • Pycroft
    edited October 2009
    Ron...
    Yes, you were the first who mentioned HK to me. HK direct is my plan. I hope to be getting one this weekend. I'll keep everyone updated. Thanks again for all the help.
    James
    2 Channel/HT:
    Harman Kardon HK354
    Sony SACD Player
  • Pycroft
    edited October 2009
    DAMNIT EBAY, STOP $*%&#(ing with me! The 354 last week was going for 315-335...within budget. This week 355-390. I've bid on 3 a day for almost a week now. I guess I'll have to wait for it to cool down a bit. I'm without a receiver for almost 2 weeks and it's hurting :(
    2 Channel/HT:
    Harman Kardon HK354
    Sony SACD Player
    tonyb Posts: 33,072
    edited October 2009
    steveinaz wrote: »
    Ahmen brotha.
  • George Grand
    George Grand Posts: 12,258
    edited October 2009
    James,
    I think you're going about things the correct way. I can't guide you around the various HT receivers the way these guys can, cause I don't have too much experience with them. But you're doing this in stages, as part of a long, learning trip, and that's good. Stepping up from the Onk to the HK would probably be a noticeable improvement in itself. Adding a separate power amp to the equation is a sure-fire sonic improvement. But why not just listen to the H-K for a week or two before you add the power amp and really do it in stages?
    With your ear, and that the fact that you listen to live, amplified and non-amplified music on a daily basis, you have the edge over a lot of people here. You'll be giving out advice soon.
    My daughter has some kind of Onkyo TX-701 or something like that in her room. I'm not impressed with it from a music standpoint. It sounded real bad with original Advent's but a pair of AR-302's toned it down a little, so I left those in there. It's pretty shrill that receiver.
    If you need an interim receiver, stop by. I have some kind of Marantz Dolby Digital thing that's pretty nice looking and sounded okay when I was jacking around with it, but it has no remote. Use it till you don't need it anymore. SR-4300 is the name I think.
  • superjunior
    superjunior Posts: 1,632
    edited October 2009
    don't most receivers have a pure direct mode which bypasses all the digital processing in the avr? My avr/amp combo sounds fantastic in pure direct for music listening. am I missing out not having a pre?
    panasonic th-50pz85u
    pioneer elite vsx-92txh
    pioneer elite bdp-05fd
    emotiva xpa-3
    monster power hdp 2550
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    surrounds - fxi a6's
    sub - polk dsw pro 600
    harmony one
  • kawizx9r
    kawizx9r Posts: 5,150
    edited October 2009
    I loved the Pure Direct mode in the Denon AVR2805 I was running, but you can do much better with a separate. Now that my tube pre came in, I like it much better than the AVR so I won't feel as bad shipping it out once it's sold.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • Pycroft
    edited October 2009
    George - Thanks so much for the offer. I don't think I'll need a replacement...I'm just getting a bit jumpy because I took the time to price out the receivers, and all of a sudden they are 20-50 dollars higher for the last 2 weeks. I'm hoping I didn't price it at the wrong time. I know some may say it's only 20-50 bucks, but I'm reaching as it is. And trust me...I will be waiting a while to buy an external amp...mostly because of money as well. I've just been doing research and looking at prices. Once I get everything setup with the HK, and save up some more $$$ I'm sure I'll be posting another message asking for more advice. And the journey continues...
    James
    2 Channel/HT:
    Harman Kardon HK354
    Sony SACD Player
  • George Grand
    edited October 2009
    You're going about it the correct way.
  • gdb
    gdb Posts: 6,012
    edited October 2009
    One of the Sunfire receivers will do HT and 2ch. music very well, with power to spare.(200x7) There's one on ebay:
    http://cgi.ebay.com/Sunfire-Ultimate-Receiver_W0QQitemZ330370196064QQcmdZViewItemQQptZReceivers_Tuners?hash=item4ceb992260
  • Pycroft
    edited October 2009
    GBD -
    That looks like a beautiful AVR, but unfortunately, way out of my price range. I'm still waiting to get the HK354 for 350, because I cannot afford 360 :) That baby sure is expensive (My child that is, not the HK). Thanks so much for looking out! You're the man!
    James
    2 Channel/HT:
    Harman Kardon HK354
    Sony SACD Player
    edited October 2009
    That's a great price for a Sunfire, Pycroft. But the HK should do you fine. I sent you a PM on your Denon question...but realize after reading this thread that you've already decided on the HK. I like HKs as well. And I'm with cfrizz and others above.
    YEAH! An AVR can't do music quite as well as separates...but you'd be SURPRISED how much BETTER and AVR WILL sound with a good power amp!!!
    And, AVRs do add their 'signature' sound to almost any AMP..but there is also the question of synergy, i.e., how the AVR pre-amp will play with the power amp and what the the qualities of the power amp are as well.
    In general though...most GOOD power amps are pretty neutral and so the AVR will usually determine what direction the sound takes! As HKs are generally 'warmer' sounding they should be pretty 'good' with music...can you have too much warm...ASK THE TUBE BOYS about that?
    They ain't tubes for sure! But then again, on a limited budget as George says above, you're doing the right thing!
    cnh
  • Pycroft
    edited October 2009
    I got my HK 354 yesterday, and my initial impressions are very good. I have not yet calibrated the speakers, but was able to listen to a CD, listen to some digital music through the IPod connector, and both sounded WAY better than the Onkyo setup. I noticed that HK is quite a bit heavier, and just seems well built. I will be calibrating the speakers either tonight, or tomorrow, and throwing in a reference quality BD, and see what I think. I am also expecting my first 2 channel amp to be arriving tomorrow, so that should change things as well. The only concern I am noticing is heat. I wasn't aware that heat was a problem, but it seems it got quite hot after only a little time listening. I did purchase a new audio rack, so the back, front, and sides are open, but there is only about an inch open on top. Maybe I should move the AVR to the top of the rack so it is totally open? Not sure that will look so good :( Anyone else with a similar HK AVR find that it heats up?
    Thanks for the advice everyone.
    James
    2 Channel/HT:
    Harman Kardon HK354
    Sony SACD Player
  • w_coyote
    w_coyote Posts: 66
    edited October 2009
    Heat is not good. It will slowly kill your electronics. You need to move it to a place that is well ventilatated so it can get it can get rid of it. Heat is pretty common and not a problem as long as it has somewhere to go. I don't have a hk but I do have a denon avr and a adcom amp and both get alittle warm so I bought a 20" box fan that blows on them and keeps them cool. The only problem is dust but I get some of that canned air and blow them out about once a month or so. Do whatever you need to do so your avr and also your amp can get rid of the heat. They wont ever be compleatly cool unless they are off but shouldn't be hot either.
  • apphd
    apphd Posts: 1,514
    edited October 2009
    Glad you are enjoying it. Can't comment on the HK in particular, but most AVRs do get warm. Driving the 11TLs with the 2 ch amp may cool it a little, but I would not think they would tax the 354 that much. But I think I would move it to the top and give it all the free air flow I could.
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited October 2009
    Pycroft wrote: »
    Thanks for the advice everyone. Pycroft :)
    James
    Congrats and enjoy
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • Krazyz1
    Krazyz1 Posts: 256
    edited October 2009
    IF you compare H.K. to yamaha or pioneer feature 4 feature and power output for the money , the whole H.K. line up looking pretty sweet.
  • sTiLlLeArNiNg
    edited October 2009
    Congrat's on your purchase OP! :)
    I thought once i added a separate amp that the yammy would run cooler but alas it still pump's out the heat :( FWIW i run a 5ch amp for my F/C/S and only use the AVR to power my SB which are FXiA 6's....
    Krazyz1 wrote: »
    I'm sorry but i would have to politely disagree with you. Personally i find that Pioneer would have the most "bang" for buck and Yamaha include's a buttload of feature's, i think their top end model's have more feature's than any other AVR but i could be wrong. After all i am only human :o I'm not saying that the HK is not a good AVR just that from what i have seen you can get more feature's with the pio/yammy :o HK do underrate their power output though ;)
    Media Room 7.1
    HTPC
  • apphd
    apphd Posts: 1,514
    edited October 2009
    .................. HK do underrate their power output though ;)
    I don't think they under rate their power at all. They just honestly rate their power;)
