Power Conditioner Failure... twice?
I sent you a PM, hope it's of some use to you.So, are you willing to put forth a little effort or are you happy sitting in your skeptical poo pile?
http://audiomilitia.proboards.com/ -
Thanks, I guess someone called already.
The voltage magically dropped to 118V.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
That's because everyone is using their A/C today.
Why don't you use a UPS for your HT gear and plug your receiver into the wall, or go with some sort of passive surge protection for the receiver."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I want to try a Panamax 5100 for the receiver and UPS for the other gear that have hard drives, etc. That would be the HTPC, DVR, Xbox 360 and projector.
I'm going back to APC for the UPS though - my experience with the Monster was poor. It made everything sound dynamically compressed and terrible sounding.polkaudio RT35 Bookshelves
