Looking for SDA's? Updated info here!
SDA 1C, SDA 2A, SDA SRS 2, CMT-340SE, Swan M200MKII, Swan D1080MKII, Behringer MS40
Outlaw Audio M2200 x2, GFA 555 II, BGW 750C
GDA 700, Outlaw Audio Model 990, Sansa Fuze, X-Fi Platinum Fatality -
No affliation (but I wish)...Here are some local 1.2 that have been for sale for a long time and he recently reduced the price...
http://charlotte.craigslist.org/ele/1235230323.html -
IIRC,, those have been around for a year or so,,at least it seems that way.JC approves....he told me so. (F-1 nut)
Conradicles wrote: »No affliation (but I wish)...Here are some local 1.2 that have been for sale for a long time and he recently reduced the price...
Those look like the 1.2tl's, if so somebody needs to go get those. -
I wish I was closer I'd grab them in a heart beat. -
I can assist in getting them and delivering them to Polkfest...just a thought.:) -
I would like to be in line on these , but don't want to cut anyone off...Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Was that his dog on top of one of the speakers?:eek:
Nick -
I also remember those pictures from last year.george daniel wrote: »IIRC,, those have been around for a year or so,,at least it seems that way."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
yep,, the dog was the tipoff
JC approves....he told me so. (F-1 nut) -
Conradicles wrote: »I can assist in getting them and delivering them to Polkfest...just a thought.:)
When and where is Polkfest? -
There is a thread in the gathering forum, I think it will be in Fayetville NC in Oct. Not sure if the dates are firm yet. -
TOOLFORLIFEFAN wrote: »Those look like the 1.2tl's, if so somebody needs to go get those.
How can you tell a 1.2 from a 1.2TL?? I know nothing about these as you can tell....Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Maybe the tweeters
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
The tweeters. the 1.2's have a clear dome SL2000, the 1.2tls have a gold looking ring around the dome SL3000. I also think some had a silver looking ring, same tweeter though SL3000.
The replacement tweeters that polk sells for the SDA's the 194's and the 198's all look the same from the outside. the only way to tell these apart is by pulling the tweeter out and looking at the terminals, the 198's will have one wide terminal.
To me the best way to tell if the SDA's are tl's is to pull a couple of drivers (this is if the drivers are original) and look on the back of them. but if the tweeters are original they can be a dead give away. -
TOOLFORLIFEFAN wrote: »The tweeters. the 1.2's have a clear dome SL2000, the 1.2tls have a gold looking ring around the dome SL3000. I also think some had a silver looking ring, same tweeter though SL3000.
The replacement tweeters that polk sells for the SDA's the 194's and the 198's all look the same from the outside. the only way to tell these apart is by pulling the tweeter out and looking at the terminals, the 194's will have one wide terminal.
Can you tell from the photos which these are??
http://charlotte.craigslist.org/ele/1235230323.htmlPio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
They look like tl's to me, and they look like they have the replacement tweeters to me now that i look at it again. also the serial # is also telling me they are the tl's. But the best way is to pull one driver and look on the back side it should say 1.2tl. you could also pull one tweeter and if one terminal is wide and one is slim they are 1.2tl's
EDIT: the 1.2tl's will have one wide terminal and one slim sorry for the confusion. I did edit my post's -
I will put money on it that these are the tl version.
TOOLFORLIFEFAN wrote: »They look like tl's to me, and they look like they have the replacement tweeters to me now that i look at it again. also the serial # is also telling me they are the tl's. But the best way is to pull one driver and look on the back side it should say 1.2tl. you could also pull one tweeter and if both terminals are slim and look like the same size they are 1.2tl's
Well I bought these today and have a road trip coming up on Friday...about 550 miles each way. Is there anything special I need to look for besides what you have listed?? He told me the drivers we kind of sticky to the touch...is that normal, good or bad?? I don't want to end up unhappy...that would be very bad after such a drive...
Are TL's a lot better?? I have had some tell me the originals were best?? I have heard so much about these things that I have to try a set...hopefully the right set the first time.
Thanks to everyone for all the help!!!Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
The tl's are better, and the drivers should be sticky to the touch, it is normal.
also you can push the drivers in (LIGHTLY) they should move in and out smoothly. I would also lay them on there back if at all possibile. you may want to pull the passive radiators for their long trip home, some say it is better on the drivers.
Congrats, you got a great buy. also keep us informed if they are the tl's.
Larry. -
Some do like the originals better, but i just think we all fall in love with what we have when it comes to the SDA's. I have had my ears on the 2.3's and the 2.3tl's, the tl's won hands down IMHO.
I also just upgraded my 1.2's to 1.2tl's. -
tha SN on the back indicates only that they are 1.2's and not TL's. Regardless they were a good buy! Congrats and welcome to the 'Go Big Club!"The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
nooshinjohn wrote: »tha SN on the back indicates only that they are 1.2's and not TL's. Regardless they were a good buy! Congrats and welcome to the 'Go Big Club!"
John i really think these are the tl's, my 1.2's don't even say 1.2's in the SN.
I could be wrong but my gut says tl.
The SN could mean nothing when it comes to polk SDA's we have seen how they used what they had to keep the product moving. what should have been a pin/blade they had a blade/blade, we have also seen where a 1.2 or 1.2tl don't remember which but they had the SDA SRS original crossover plates. -
They were never very good about keeping serial numbers straight... the tweets do appear to be TL's.... will be interesting to find out.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
TOOLFORLIFEFAN wrote: »John i really think these are the tl's, my 1.2's don't even say 1.2's in the SN.
The SN could mean nothing when it comes to polk SDA's we have seen how they used what they had to keep the product moving. what should have been a pin/blade they had a blade/blade, we have also seen where a 1.2 or 1.2tl don't remember which but they had the SDA SRS original crossover plates.nooshinjohn wrote: »They were never very good about keeping serial numbers straight... the tweets do appear to be TL's.... will be interesting to find out.
I will certainly provide the needed information to you so we will all know what they are. I am very anxious to hear them...
I plan to bi-amp them with my Sunfire Signature 405 X 5...Do you think that will be a good combination?? I certainly can't afford another amp at the moment...
Thanks for all the help!!Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Congrats and I expect a 5% finders fee...
Just kidding. Enjoy! -
Conradicles wrote: »Congrats and I expect a 5% finders fee...
You should have already received it???
:DMany, Many thanks for posting this!!!:D
By the way, aren't finders supposed to deliver?????:eek:Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Okay, I can't leave this thread stuck on #666......
Going to pick up the speakers tommorrow...Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404
