Whats with all the talk about Oppo BDP-83 ?
1234579
  • Ron Temple
    Ron Temple Posts: 3,212
    edited June 2009
    dpowell wrote: »
    YES! The wife gave me one today for Father's Day / Wedding Anniversary. Breaking it in now with Prince Caspian in 7.1 DTS Master Audio. Fantastic picture and sound!
    I haven't done 2-channel audio yet with it but right now the Denon 3910 is not in the rack and it may not make it back in there......I guess only time will tell.
    Congrats...I think it's a toss up on whether you prefer the 3910 for 2 channel or not. There are those on both side of that fence from what I've read. I did some 2 channel listening last night, player to Luxman pre to amp. The 2 channel DACs output a higher voltage than the MCH. I'm not clear on what that does, but I notice quite a bit more kick at lower volumes. Bass is extremely punchy and at 9:30 on the gain, my drivers and PRs are dancing. Used to go to 11 or 11:30 to get that kind of response, though the volume isn't as loud. I'm probably somewhere in the low 90s. Frankly, I'm not sure if I don't prefer 2 channel from the MCH outs though it could have been the material I was playing. Still, both are very good.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • digitalvideo
    digitalvideo Posts: 983
    edited June 2009
    Ron Temple wrote: »
    1080P/24 is only a BR setting and only is applicable for TVs that can display it, mine can. I have it set at Auto. SD DVDs will be upscaled to the resolution you have the TV and player set too. That's 1080p for me, but it's not at 24fps, it's 60hz. TV is not effected at all. If you have a 5.1 setup, then use 5.1 not 7.1. If you have a 7.1 rig, keep it set at 7.1...you won't lose anything if you're correctly configured. If you have a 5.1 setup and you do have the Oppo set to 7.1 and you happen to play a disk that's encoded 7.1 (very few) then you might be losing the back 2 channels. If you have a 7.1 setup and you play a 5.1 encoded disk, then the back to channels are downmixed by the Oppo...no worries.
    I have my Oppo hooked up to a Pioneer SC-05 reciever, all through HDMI wiring. This reciever also has the option to let you set it to 1080p or Auto. Which should I set the Oppo and SC-05 to get the best picture quality from tv/sports and movies?
  • Sherardp
    Sherardp Posts: 8,038
    edited June 2009
    I suggest you set it to your displays native resolution. So I would set it to 1080p, and if your set supports 24hz then turn that on as well.
  • Ron Temple
    edited June 2009
    I was wrong...if your display supports 24hz then DVD or BDs will be fine. Set it to Auto, if it doesn't display then you'll need to check another option. As far as the Pio AVR, I don't know the setup nomenclature, but my choice would be a direct pass through from the player, no conversion at the AVR. It's likely a higher end chipset that's doing upconversion on the Oppo and you don't want another layer of processing in the signal. Let it go native, 1080p/auto.
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • digitalvideo
    edited June 2009
    Ron Temple wrote: »
    So set both the Oppo and Pioneer reciever both to 'Auto' and it will upconvert regular dvd's to 1080i or 1080p and show the full affects of BD's as well? So 'Auto' is the optimum setting to get the most out of dvd's and BD's?
    The Pioneer SC-05 has a Faroudja DCDi video processor provides the deinterlacing and scaling of analog inputs. Pioneer decided not to process any HDMI signals, instead these signals are passed through the unit untouched. The composite, S-video, and component inputs can be transcoded to HDMI and output at resolutions up to 1080p/60, which means you only have to run one cable from the AVR to the display
    My display is a Pioneer Elite Kuro Pro-111fd plasma.
  • Sherardp
    edited June 2009
    If you have the Oppo hooked up to the SC-05, the Pioneer will pass it through untouched via HDMI as you mentioned, so set the Oppo to do 1080p, turn 24hz option on for BD. For SD DVD I have the 24hz option turned off. For SD DVD you will want to set the Oppo to do 1080p also. From there you should be fine, this is how I have mine paired up with the SC-07 and JVC RS10 projector.
  • digitalvideo
    edited June 2009
    I contacted Oppo about this topic to see what they say and they responded back with:
    "We would recommend setting the player to 1080p and ensuring that HDMI is set to "Bit Stream" (Audio Setup). These will be the optimal settings for your BDP-83.
    Best Regards,
    Customer Service
    OPPO Digital, Inc.
    2629B Terminal Blvd.
    Mountain View, CA 94043
    Service@oppodigital.com
    Tel: 650-961-1118
    Fax: 650-961-1119
    I now know where to set the Oppo thanks to you guys and Oppo customer service, I'm still just a little confused about where to set the SC-05 reciever to, it has the option to be set to 'Auto' or '1080p' as well.
  • Sherardp
    edited June 2009
    Best Regards,
    Customer Service
    OPPO Digital, Inc.
    Tel: 650-961-1118
    Fax: 650-961-1119
    Why the confusion? The SC-05 will pass any signal via HDMI untouched, so it set it to Auto or 1080p, doesnt matter.
  • WilliamM2
    WilliamM2 Posts: 4,806
    edited June 2009
    I would set the SC-05 to "pass through". Let the Oppo do the processing.
  • Danny Tse
    Danny Tse Posts: 5,206
    edited June 2009
    The Oppo BDP-83 is now available to everyone at $499.00 (as of this post)
  • kolyan2k
    kolyan2k Posts: 259
    edited June 2009
    Danny Tse wrote: »
    cool......too bad i love my ps3 :)
  • HHStuart
    HHStuart Posts: 263
    edited June 2009
    Danny Tse wrote: »
    Thank you for posting this. I am definitely thinking of buying it. If I buy it, can someone tell me how would I get updates? Can I download it to my PC, burn a CD and load it on the player? Any help would be appreciated.
    Front - Polk LSiM 705, Center - Polk LSiM 704c, Rear - Polk LSi 7
    Subwoofer - Epik Legend
    Receiver (as Preamp) - Sony STR-DA3400 ES
    Amplifier - Outlaw 7125
    Television - 58" Samsung Plasma PN58B860
    Blu Ray - OPPO BDP 83
  • danz1906
    danz1906 Posts: 5,144
    edited June 2009
    Danny Tse wrote: »
    Great news!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • dpowell
    dpowell Posts: 3,081
    edited June 2009
    HHStuart wrote: »
    This has an network interface on the back so you can connect it directly to your home network. If you have DHCP enabled, the player will grab an IP address automatically and be connected to the Internet. No downloading and burning to CD necessary.
  • Ron Temple
    edited June 2009
    dpowell wrote: »
    That feature hasn't been enabled yet. I read the reasoning and agreed with it, but I don't remember what it was :D. Right now firmware can be downloaded, burned to CD or flashed to a USB drive or memory stick. They issued 2 updates since I purchased the player.
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • HHStuart
    HHStuart Posts: 263
    edited June 2009
    Ron Temple wrote: »
    Thanks for the info. I would rather not fuss with hooking it up to my network. Not to mention the possibility of malware at some point.
    I think I am going to pull the trigger on the BDP-83.
  • dpowell
    edited June 2009
    Can someone speak to whether or not this player would truly be vulnerable to malware? It is Java based so surely the capability is not out of the realm of possibility but if it is on a private network behind a firewall, it is not directly pingable from the outside. If the player is designed to only grab firmware updates from the mothership, it seems to me that the only two methods someone has of hacking the unit is to be on the private network and know the IP of the player or to hack Oppo's download site and place a hacked firmware update in place of the real update.
  • Ron Temple
    edited June 2009
    dpowell wrote: »
    That's a good question. I'd take it to Oppo or to the EAP thread at AVS. I'm sure neuromancer or wmmclain can answer. They've done most of the troubleshooting posts in that 15K+ post thread.
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • snow
    snow Posts: 4,358
    edited July 2009
    Danny Tse wrote: »
    Now on Amazon with free shipping also. http://www.amazon.com/OPPO-BDP-83-Blu-ray-Player-DVD-Audio/dp/B002EEP3MK/ref=sr_1_4?ie=UTF8&s=electronics&qid=1246399266&sr=8-4
    REGARDS SNOW
  • danz1906
    edited July 2009
    Now thats what Im talking about! Thanks for the link.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited July 2009
    I pulled the trigger and ordered mine from Oppo directly...should be here early next week!
    I plan on doing some serious comparisons of the BD83 and my Cambridge 640C V2, and AVR for best DAC performance for CDs....maybe the BD83 will be my 'do everything' player - as I can even dabble w/ SACDs!
    Let the sonic goodness begin....:p
  • Ron Temple
    edited July 2009
    Erik Tracy wrote: »
    I'd be interested in that comparison. MCH is very good through my HK in 6/8 Channel Direct mode. 2 channel is too, but it's much better when I take the HK out of the loop and use my Luxman pre. Also, I prefer 2 channel through the MCH outputs over the dedicated 2 channel outs on the player. That just could be me. The dedicated 2 channel outs have an upgraded DAC and associated OP amps, resistors, etc., but the higher output voltage isn't playing as nice with the Luxman...not noisy, just sounds over(d)amped. Bass hits astoundinly hard and sounds out of balance. I suppose I could just turn it down :D. I really need to experiment some more and give it a chance.
    Anyway, good pickup. I'll be interested in your thoughts.
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • vmaxer
    vmaxer Posts: 5,120
    edited July 2009
    Ron Temple wrote: »
    I like using the multi channel for 2 channel listening also!!
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Erik Tracy
    edited July 2009
    For those that already have the Oppo BD83.....how warm/hot does it run?
    I have a spot in my AV cabinet, but can also put it on top for full open air circulation - if it does run hot.
    Does it run hotter when upconverting DVDs?
    Thanks,
    Erik
  • dpowell
    edited July 2009
    My unit runs quite cool. I would say lukewarm at best. I do currently have a few inches of clearance on top of it and it also sets on a shelf directly above the AVR.
  • Ron Temple
    edited July 2009
    I've read posts all over the place on this question. There's been more than one complaint about fan noise and excessive heat. I've never had the fan kick on with mine and it's normally cool, but I did notice some heat after a full day/night of music and BDs I think it varies with your situation, in a hot room, with poor ventilation...heat...if you're setup like me or dpowell...not so much.
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • nebborjk
    nebborjk Posts: 425
    edited July 2009
    I had mine on for about 5 hours straight last weekend and never heard a peep out of it. I have about 3" on top and 1" side clearances. Dead quite.
    Proud SOPA Member since 2005!
  • danz1906
    edited July 2009
    Does anyone use the 7.1 analog outputs for Hi-Rez sound? My Anthem AVM-30
    doesnt have HDMI inputs. I would have to use the player to decode and send thru
    the 5.1 input of the Anthem.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  • Ron Temple
    edited July 2009
    danz1906 wrote: »
    Yep, works great. The player decodes and sends as LPCM over analog.
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • danz1906
    edited July 2009
    Ron Temple wrote: »
    Thanks, How does the Hi-rez sound compared to the regular DTS/DD?
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
