Does anyone use equalizers anymore?
    heiney9 Posts: 25,711
    edited April 2009
    Hope you guys have fun!! As usual a few n00b's want to hear themselves talk. I've stated my opinion and I'm done here........other than making some popcorn and watching from the side lines enjoying my tubed office rig with no tone controls.
    Let's see if you n00b's can get another thread closed and post the typical worthless information.
    edited April 2009
    jinjuku wrote: »
    Try posting that on some other well know audio forums like AVSForum, Audioholics, or Hometheatershack.
    Wouldn't be caught dead over in those forums. Talk about a sheeeepppp mentality.
  • megasat16
    megasat16 Posts: 3,521
    edited April 2009
    No! No Equalizer anymore! But I have a parametric and graphics EQ in standby for really bad recordings.
    It's not the equipments that needs help. It's the bad recordings that needs help from EQ.
    Also, no Tone Control and no bass boost or any kind of flavor added unless absolutely necessary. Again, there are tons of bad recordings that needs help with Tone Control in Pre-amp.
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited April 2009
    Well it was only a matter of time before the outing with the references to the vastly superior knowledge available at other forums, the inevitable links to follow.
    Turn out the lights and close the door, the eggs are cooling, the jello is jiggling and the butter's getting hard.
    Designate as Officially P'wned.
    RT1--out
  • jinjuku
    jinjuku Posts: 1,523
    edited April 2009
    heiney9 wrote: »
    Or a thread that has open minded information and not a bunch of snobs driving a set of $2000 Polks with $5000 worth of gear.
    A thread where it's: give it a shot, if you don't like it don't do it. Instead we get I have a 2 channel tube setup that smells of Chanel No5 with silver and hemp pleated interconnects with a beryllium coated tip.
    There is a real reason why you can't hang on the other boards. Any one that would rather invest in interconnects for tone controls than something like an EQ... Nothing worse than a person that thinks they know what they don't know. I guess that would be an old noob.
  • blakeh
    blakeh Posts: 491
    edited April 2009
    Sometimes, when I have no other choice, I do use the equalizer...
    Robert McCall is always there when no one else can help.
  • blakeh
    blakeh Posts: 491
    edited April 2009
    Keep spreading that open mindedness you're preaching. I bet it'll catch on fast!
  • reeltrouble1
    edited April 2009
    GV#27 wrote: »
    I wouldn't dare add one of those noise generating,detail obscuring thingies to my my full range signal path.It would defeat entirely the purpose of using a minimalist single ended preamp if I were to add a box with multiple cheap opamps, pots and switches etc.
    one smart Canadian, I see you have been dodging those icicles G.
    RT1
  • jinjuku
    edited April 2009
    GV#27 wrote: »
    I use a single band of parametric EQ on my subwoofers to notch out a nasty 50hz room mode.I wouldn't dare add one of those noise generating,detail obscuring thingies to my my full range signal path.It would defeat entirely the purpose of using a minimalist single ended preamp if I were to add a box with multiple cheap opamps, pots and switches etc.
    You made a great point. No one is saying that you have to correct 15 different bands... It still stands that an EQ can make a difference.
  • megasat16
    edited April 2009
    jinjuku wrote: »
    Actually, you don't want to use EQ at all if it sounds good on it's own. The EQ is totally removed till there is some bad recordings you need to listen to it. But since it's been removed from my rigs, I haven't used the EQ in the past 10+ years. I still have it and keep them just in case I need to listen to some bad recordings.
    But EQ is a necessary evil if you listen to lower quality mp3 (128kbps or less sampling digitized) streams from the Internet or your media server.
    Now, I only use SMS-1 to correct room acoustics for my subs in the HT area. It's a kind of parametric EQ but only for around 20Hz-50Hz region for HT.
    No SMS-1 or subs needed in the stereo rigs.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited April 2009
    Curt, he has an axe to grind with Ted that he won't let go . . . just ignore him.
    Apparently so. I won't be losing any sleep over it.
    Yet another stupid thread...I'm done with this one. Have fun guys, I'll be reading from the sidelines.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • jinjuku
    edited April 2009
    blakeh wrote: »
    Oh, so others can make blanket statements like 'eq's aren't needed, buy better gear' are open minded? But I make a statement about people buying cables as a method of tone control and I'm not?
    Pot meet kettle indeed. Again, go to another popular forum and try posting the 'just get better gear in place of eq argument'. Oh, I forgot, only the Polk forums have people that know what they are doing. Doesn't matter what the other forums are because you have a convenient argument of "they are all sheeple".
  • Systems
    Systems Posts: 14,872
    edited April 2009
    jinjuku wrote: »
    The circuitry for each band is still in the signal path even when the gain/cut control is in the middle position.
    Sure it will make a difference, but I contend that if the goal is extracting and resolving as much information and detail from a recording as possible,it's addition will be counterproductive.
    Testing
    Testing
    Testing
  • jinjuku
    edited April 2009
    megasat16 wrote: »
    Thanks, this is the real kind of information that needs to come out in these threads. It's just sad that you have know-it-all's that are hell bent on only pushing their viewpoint.
    The OP asked a really good question. If you look at his signature he has primarily and HT setup. Companies like Pioneer/Onkyo(Integra)/Denon/Yamaha/Sony/JVC/Sherwood/NAD/Outlaw/Emotiva/Cary... (the list goes on) all have some form of EQ included in their product. Are they all making crap components. Is it possible they don't know you really don't need an EQ?
    Again, what are everyone's goals here? I stated mine early and up front.
  • jinjuku
    edited April 2009
    GV#27 wrote: »
    The circuitry for each band is still in the signal path even when the gain/cut control is in the middle position. Sure it will makes a difference, but I contend that if the goal is extracting and resolving as much information and detail from a the recording as possible,it's addition will be counterproductive.
    But you are making a BLANKET statement about your setup and what it does for you. Don't want an EQ in the mix, great, don't EQ.
    Have a sub with a nasty 50Hz hump in the listening environment that you want to smooth out? then either try relocating the sub. If that fails then try to EQ.
    Can anyone find a post where I said to apply the EQ to your entire range?
    I even stated that there is not a lot to EQ in a two channel setup. There are some 'purists' that get way to worked up over things that were never even said.
  • Matt34
    Matt34 Posts: 318
    edited April 2009
    One of the reasons to use an EQ IMO is to try and minimize some of the room's unwanted contributions to the overall sound, so that you hear less of your listening space and more of what's actually in the recording itself. The overall goal being to preserve what was recorded by correcting room induced problems.
    Three steps to achieving that IMO are:
    1. Speaker/sub placement relative to listening position. This should be optimized first.
    2. Room acoustic treatments. This should be optimized second.
    3. EQ to "tweak" the final response and ideally only frequencies 80hz and below as they are the least affected by room treatments.
  • Conradicles
    Conradicles Posts: 6,434
    edited April 2009
    strider wrote: »
    on top of my VCR now.
    Dude...you are one of the 6 people left on earth with a VCR. You go bro!!!:D
  • comfortablycurt
    edited April 2009
    I guess I'm one of the other 5 people then. Who are the other 4 besides Strider and myself?...lol
    I still use my VCR pretty regularly, the DVD player gets a lot more use, but I still have my collection of about 200 VHS tapes. I'm not going to stop watching them just because they're outdated.
  • Conradicles
    edited April 2009
    Sidelines huh...
  • Systems
    edited April 2009
    jinjuku wrote: »
    The original question was asked does anyone use EQ and I gave the reason for my limited usage of it.Others are free to agree or disagree.
    My placement options are limited and the final locations worked best despite the 50hz issue.Other locations had other problems that were not as easily solvable with one band of EQ.
    Testing
    Testing
    Testing
  • Conradicles
    edited April 2009
    EQ's rule guys. Go buy one with snake oil in the LED lights.
  • jinjuku
    edited April 2009
    GV#27 wrote: »
    Exactly, agree or disagree. Not start preaching the gospel 'No EQ is ever needed, you just have junk audio components'.
    Is that really the image that some Polksters want to project? Just put a big sign up saying "Polk forums, exclusive club. Lesser audio beings need not apply'.
    The difference is: I am not patently saying you HAVE to use an EQ, while others are patently saying don't.
    I am saying use your ears. Others are saying don't bother. I don't know what axe some here have to grind but it is misleading to someone just getting into audio. I want them to be able to buy a product like Polk and come here and discover what else there is. Fine if they can hear a rational argument for the pro/cons of something.
  • lightman1
    lightman1 Posts: 10,803
    edited April 2009
    He has a good point. I would not dare use my H/T AVR without the EQ. Sounds horrible.
    For 2-channel I don't need one.
    But you got to admit some of them look really cool. The lights man, the lights! (not lightman)
    Don't drag me into this. I'm in enough trouble already.
    Hacks.
  • lightman1
    edited April 2009
    What happened to the pre-edit statement???? I saw it.
  • comfortablycurt
    edited April 2009
    Sidelines huh...
    Ehh...it wasn't related to the topic at hand, so it's still the sideline. I just felt like promoting the usage of VCR's.;)
    I'm still saying this from the sideline just FYI...lol
  • Conradicles
    edited April 2009
    lightman1 wrote: »
    VCR's are to video...as...EQ's are to audio
    VCR's suck out loud so...:D
  • Conradicles
    edited April 2009
    lightman1 wrote: »
    Did hims get sent to the corner?:(
    F1nut Posts: 52,406
    edited April 2009
    I have a VCR too, a very nice one at that and I use it regularly. :D
    Granted, an EQ device/program seems to be needed for HT set ups.....should tell you something about HT, eh?
    Interesting that you bring them into the conversation as they are well known for thinking everything sounds the same. Hmmmm.......makes one wonder why they would need an EQ or perhaps that is the reason everything sounds the same to them.
  • lightman1
    edited April 2009
    I have Touretts. And I know where you live.
    You 2ch in the GARAGE! no sound stagin' 14 kids runnin' around the house Yayhoo!
    Yep. I did.:o
  • Conradicles
    edited April 2009
    Ban him!
