SVS Subs
Ok, I am a die hard polk fan, but I love to try different things...I was originally sold on getting a Micro Pro 4000, but then happened upon SVS's website and I've gotta tell you, for the money, they look like REALLY nice subs and have great reviews. I am really interested in the new PB12 Plus in rosewood to match my RTI A9's cherry finish. Anyone have some real experience with these subs?
Main System:
Sony DA6400ES Receiver, Sony BDPS500ES Blu-Ray
Denon DRS810 3 Head Cassette Deck, Sony KDA60ES3000 60" HDTV ,Emotiva XPA 2 Powering the A9's, Monster Power HDP 2550, Monster Power AVS 2000 SS Voltage Stabilizer, Direct TV HDTV Receiver,Polk RTIA9 Towers:D, Polk CSIA4 Center:D, Klipsch RC51 Surrounds, SVS PB13 Ultra Sub, Monster Cables HDMI 1000 Cables, Monster Cables M Series Speaker Cables
Post edited by bartimus on
«134
  • kuntasensei
    kuntasensei Posts: 3,263
    edited February 2009
    I've been using a SVS 20-39CS+ for a few years now, and recently upgraded the woofer to the dB12.3. Couldn't be happier with it, and I would never go back to a Polk sub after hearing/feeling my SVS. You'll see a lot of hype for them (which, much like you'll see Emotiva treated on these forums, drives the haters nuts), and though they are by no means the second coming, they are an excellent value for the money and will handily trounce most consumer grade subwoofers. Plus, with their excellent return policy, you won't be out much money if you get one and don't like it. They also have some of the best customer support you'll ever deal with, in case you have any problems or setup issues.
    Still, if you see someone who's so evangelical that it's hard to believe, take it with a giant grain of salt. That said, compared to the Klipsch in your sig, I think a SVS would put a big-**** grin on your face. I know mine had that effect on me.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • pearsall001
    pearsall001 Posts: 5,359
    SVS makes excellent subs...as do other companies.
  • MikeC78
    MikeC78 Posts: 2,315
    I'd also check out HSU, they have veneered subs too. The ULS-15 comes to mind.
    If you are not to worried about trying to match the finish, check out Epik or ED. Epik came out with a new interesting line here recently. The 18" sealed "dragon" is definetly an eye opener for me.
    However, you can't go wrong with the SVS, they make great subs at a great price point.
  • shack
    shack Posts: 11,154
    SVS makes some nice subs at nice prices. I've had the opportunity to hear several of them in different systems and have always liked what I heard. In the past Polk has not had the reputation for good subs. That has changed with the DSW microPRO line of subs. I was able to listen to the DSW microPRO 4000 sub (and its smaller siblings) at Polk HQ last fall. I would not hesitate to put it up against a comparable SVS offering and would put one in my rig in a heartbeat. It is a great sub IMO!
  • MikeC78
    shack wrote: »
    Shack,
    What would you say the Polk would compare to in the SVS lineup? It's really hard to beat pure size for HT. I'd put it up against the SB12, which I'd believe the 4000 might out do(purely subjective), but the price is also twice as much.
    The only issue with the Polk and the ID companies is the price differential. The microPRO is one pricey sub compared to the others. I've never heard the microPRO but I am sure it sounds good, and it better for the price tag that goes along with them.
  • shack
    shack Posts: 11,154
    MikeC78 wrote: »
    Shack,
    I would think it would easitly be on par with (or better than) the PB12-Plus in terms of performance. Double the amp output. A 12" powered woofer plus a 12"x12" passive radiator and the ability or electronicly tune the sub for room optimizaton. It would be interesting to see how it compares to the Ultra (my guess is it would do well). There is also the advantage of size. I believe this particular design can acomplish what the SVS does in a smaller and lighter box. Bigger is not always better. SVS may have a price advantage but the Polk deserves consideration because it does lots of things right.
  • MKZ
    MKZ Posts: 1,068
    I like my Velodyne SPL 8" over SVS SB12+. They are as tight as drums IMO.
  • Ron Temple
    Ron Temple Posts: 3,212
    Has anyone run the numbers on the MicroPro 4000? I'd love to see some graphs.
    I'd think comparing a small high powered PR sub to a large ported sub would be apples to oranges in capability, as well as, design goals. I have no doubt the new Polks are great subs within their limits, just as are the SVS subs, but each have different strengths and limitations.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • shack
    shack Posts: 11,154
    From what I heard...there is little difference it the capabilities of the big SVS vs the Polk. IMO either one will pressurize a room and get down to 20hz with no distortion. I think Polk has figured out how to get rid any sort of distortion at levels that are very impressive. No graphs...just my physical listening. Someone at Polk might be willing to provide that info because I know they are proud of the results.
  • speakergeek
    speakergeek Posts: 555
    PB13-Ultra=one awesome sub...period. One thing the larger subs have over the micros is low end extension which is a plus for HT.
  • shack
    shack Posts: 11,154
    That is not a problem for the microPRO 4000. It has plenty of low end extention. While it is a "smaller" sub it is not mini/micro by any stretch of the imagination. It still weights 60 lbs and is a 17" x 17" cube.
  • speakergeek
    shack wrote: »
    That is not a problem for the microPRO 4000. It has plenty of low end extention. While it is a "smaller" sub it is not mini/micro by any stretch of the imagination. It still weights 60 lbs and is a 16" x 16" cube.
    It's -3dB at 21 Hz. THe Ultra is - 3dB at 14 Hz in 15 Hz tune. The Ultra driver alone weighs 60 lbs...:)
  • leroyjr1
    leroyjr1 Posts: 8,785
    Ron Temple wrote: »
    I'd love to see some graphs on the 4000 also.
  • shack
    shack Posts: 11,154
    As I said earlier. I have heard a PB12 and believe the Polk is as good or better than that sub. I have never heard the 13 but I believe the Polk would hold its own in most cirucmstances. Have you heard the Polk?
    And not everyone wants (or needs) a 130-150 lb sub.
  • speakergeek
    But my point is that the micro pro is limited due to it's size and will never be able to go very deep as the large subs can. I don't doubt it's loud, but it's small size will limit how low it can go.
  • shack
    shack Posts: 11,154
    -3dB at 21 Hz is pretty low and more than enough in most applications and it is not that small.
  • mantis
    mantis Posts: 17,607
    Personally I don't care for SVS subs. I have set up a few of them with less then my desired results. I have had customers return them and buy different subs.
    Music ability I feel they are not quick enough. I can localize the sub where ever it is in the room. This is a failure in my book. If I can hear the sub then It's beat.
    I like a sub that is gone in the room, you have no idea where the bass is coming from and it fools you to believe it's coming from the movie or music or even right out of the speakers themselves.
    Dan
    Dan
  • Ron Temple
    mantis wrote: »
    Dan
    I'm not going to be an apologist for earlier revs of SVS subs, but the new Plus has been redesigned to offer a sealed-like overdamped sound with stellar output. The Ultra13 is arguably the best in it's class for features and sound quality. Compare them to smaller subs and you get into tradeoffs. If you're looking for a smaller footprint then you'll have to pay more and still not get the same linear FR. You still might prefer the smaller subs SQ, that's subjective, but you won't get the subsonic visceral response (arguably, something that not everyone wants or needs). I'm not talking about the superiority of one design or the other...they are different.
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • kuntasensei
    I had to do careful integration and tweaking with my old 12.1 driver in my SVS, so I can understand what Mantis means. With the 12.3 driver, it's less of an issue and music is much tighter. But hey, to each his own.
    Equipment list:
    Emotiva XPA-3 amp
  • donedroolin
    donedroolin Posts: 225
    VELODYNE!!!!!!!!!!, VELODYNE all the way. Check them out AWSOME subs.
    TV- 52 inch LCD SONY BRAVIA XBR6
    TV- 42 inch PLASMA HITACHI ULTRA VISION
    AMP- PARASOUND HALO A-51
    CONTROLLER- PARASOUND HALO C-2
    FRONT SPEAKERS- LSi15's and LSiC
    REAR SPEAKERS- LSi7's
    SUBWOOFER- VELODYNE DD15
    BLU RAY- LG SUPER BLU BH200
    BLU RAY- SONY BDPS350
    GAME SYSTEM- NINTENDO Wii
    MONSTER POWER CONDITIONER
    WIRES- AUDIO QUEST and MONSTER
  • pearsall001
    Now there's a man that knows what he's talking about. There's Velodyne...then there's Velodyne wanna be's!!
  • MikeC78
    Then there are Velodyne fanboi's.:p Glad you guys are enjoying them, that's all that matters.
    All those subs above are good subs, SVS, Velodyne, etc.
    But the big news is that with the 4000 Polk has really caught up. I've heard this sub demoed and it's pretty much targeted at those guys above and guess what. It succeeds! Kudos to Polk on finally taking the sub by its woofers?
    cnh
  • hockeyboy
    hockeyboy Posts: 1,428
    Velodyne is great if you can afford it. You can buy 2 slamming SVS subs for the price of a single Velo.
    My Main Gear
    Mitsu HC5000 (Proj.)
    Marantz SR8001 (AVR)
    Sunfire TGA7200 (AMP)
    Marantz DV7001 (SACD)
    Samsung BD-P1500 Blu-Ray
    LSi 15's (Front)
    LSiC (Center)
    LSiFx (Surrounds)
    DUAL SVS 20-39 CS Plus
    (Passive Subs)
    Marantz IS201 I-Pod Dock[/SIZE]
    Panamax M5300EX
    Carada Criterion 106" Brightwhite Screen
    Sunfire TGA 5200 & (4) B&W 605's in the party room
  • speakergeek
    For the price of the micro, there's much more to choose from than just SVS, although it's at the very top. Don't for get the HSU ULS-15...
  • comfortablycurt
    comfortablycurt Posts: 6,745
    hockeyboy wrote: »
    That's why I'm leaning towards SVS. To get an equivalent sub from Velodyne, it would cost damn near twice as much money.
    Some of the new Epik's are looking pretty damn nice too, and they won't completely drain your bank account.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • thsmith
    thsmith Posts: 6,082
    MY advice for anyone buying a sub to know your room cubic feet, purpose of having a sub and customer service/product track record of vendor.
    I spent a lot time and money chasing the sub perfromance I wanted/needed. Spent a lot time EQing, room placement adding tricks like external EQing, test equipment, mid bass modules and mulitple subs.
    I definately learned alot and once I found the right sub for me, set it up, EQed and have not touched it since and have not once wanted more that what I have now.
    On a side note I like what Epik is now offering but the jury is still out. I wanted their conquest but lack of customer service drove me to something in the end I feel is better.
    YMMV
  • speakergeek
    thsmith wrote: »
    YMMV
    Agreed! You made a very good sub choice!
  • Ron Temple
    thsmith wrote: »
    YMMV
    You made a good choice and a safe decision based upon what could be guessed about the player's at that time. Epik's subs from all reports exceed expectation, but the company lacks the infrastructure to compete outside it's word of mouth sales channel. The new line looks very interesting and competitive. It's streamlined (interchangeable amps and drivers), less confusing and best yet, smaller (except for the Dynasty). It's going to be awhile before they can take on SVS head to head as a business model, but I do feel they are making a superior product (not necessarily better than, just very well built, outstanding performance and reliable) that's aimed at establishing their own niche. You just know going in that you won't get the same level of support, though Epik is trying hard to change that.
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • thsmith
    At this point it would be good to see some evidence from owners. Only time will tell.
