Opinion: A respectable starter speaker cable
Igo
Igo Posts: 411
edited December 2008 in 2 Channel Audio
I’ve really enjoyed the high end “Best Speaker Cable to date” thread in this forum. It has me surfing all over the web researching speaker cabling but my little ‘ol rig does not justify $250 speaker cable runs and my wallet can’t go that either. So…
What is a respectable starter speaker cable? (I can terminate) I’m not talking audio nirvana, just the first thing readily available that truly might make a difference. As you can see in my sig, my rig is the first leap above buying a receiver at Best Buy and I’ve made an entry level effort to clean up power with a Panamax Line Conditioner. Now, what’s the first real leap in speaker cabling? I'm betting that this leap will make a huge difference over leftover Rockford Fosgate wire from my car install.
Thanks a bunch in advance.
...Link to my System Showcase...
"ES - Kind'a simple but I like it"
Sony ES STR-DA4300ES 7.1
Sony ES SACD SCD-C2000ES
Sony 400 Disc CD CDP-CX455
Infinity BU-2 Sub-Woofer
Polk Audio RT800i Towers
Polk Audio CS400i Center
Polk Audio FXiA6 Surrounds
Sennheiser HD 280 Pro Headphones
DH-Labs T-14 Speaker Cables
Panamax Max 500 DBS Line Conditioner
Panasonic TH-50PZ85U 50'-Plasma
Play Station III - BluRay
Logitech Harmony 550 Remote
Logitech diNovo Mini Keyboard
Post edited by Igo on
  • george daniel
    george daniel Posts: 12,096
    I like Signal Cable,,you could do alot worse,, plus when you're ready to move on,,they are easy to sell.Good Luck
  • Hawkeye
    Hawkeye Posts: 1,313
    I'd honestly try some 12 guage speaker wire from Home Depot or Lowes. It is cheap enough to discard if you don't care for it.
    Gordon
    2 Channel -
    Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
    heiney9 Posts: 25,436
    Canare 4S11 "star quad" is a great starter cable and easy to work with. Terminate how you like.
    This is a great company to buy from also.
    http://www.performanceaudio.com/cgi/search.cgi?search_for=canare
  • janmike
    janmike Posts: 6,146
    Grab some used cables here from respectable forum members. There are lots of good choices that fall into your price range. Good luck.
    Michael ;)
    NORTH of 60°
  • dkg999
    dkg999 Posts: 5,647
    +1 on the Canare 4S11 Star Quad recommendation.
    DKG999
  • NJPOLKER
    NJPOLKER Posts: 3,474
    Igo,
    Let me tell ya, I ran regular ole speaker wire for a a long time. I bought a pair of Audioquest Type 4's and a set of Morrow audio cables/wires. As I remember I paid $60. for the Type 4's and $130. for the Morrows. Both are a HUGE improvement over the 16 guage wire. Anyone who tries to dispute wire/cable performance is a fool. Now for the costs!! Keep searching for deals here and Audiogon you'll find them eventually.
    I'll save my thoughts as to which one performs better for another thread but one does out perform the other by a wide margin IMO
    Drew
  • mantis
    mantis Posts: 17,394
    My wire of the year on a budget and I have proved it right in my own system is the Audioquest Flex series in wall rated 14-2. Currently I have my mains(Dynaudio Audience 82's) wired with it and I use them for 2 channel music. I have used it on the job and found it to be a really good sounding or non sounding cable. I like it a lot.
    I found it at Crutchfield for sale and that price is awesome. I challenge any bulk cable at or slighty above hell go a lot higher and you'll be hard pressed to beat this wire.
    http://www.crutchfield.com/p_703142250I/AudioQuest-FLX-14-2-14-Gauge-In-Wall-Speaker-Cable-250-feet.html?tp=1432
    Dan
  • Gadabout
    Gadabout Posts: 1,072
    +2 on Canare 4S11 for a starter cable.
    The place quoted above is cheaper than buying bulk from Blue Jeans Cable ($0.96 vs $1.05)
    You might also look at Signal Cable's Ultra's - http://signalcable.com/ultraspeaker.html
    If you want to terminate your own, look at DH Labs - T-14 cable. It is available in bulk for $5.50 a foot. http://www.silversonic.com/docs/products/T14.html
    Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid. ..... Frank Zappa
  • cfrizz
    cfrizz Posts: 13,415
    Blue Jeans Cable, Monoprice, will get you started at a reasonable price.
    You might also want to check out Cambridge SoundWorks.
  • beardog03
    beardog03 Posts: 5,550
    AQ Type 4...
    Audio Advisor has some good deals going on right now also..
    Just my .02
    "Cary" on
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • Igo
    Igo Posts: 411
    Mr Daniel, I beleive I might can go the price of these entry level Signal Cables. I have a Sony ES Receiver with the typical binders/connectors on back. Do spade terminations connect to these? Just by looking at them I'd have to say this is the direction I want to take. I have been using 12 and 14 awg Monster wire (just straned spool wire) for many many years as I did learn 20 or 30 years ago this was a huge step up from 22 awg radio shack wire.
  • Igo
    Igo Posts: 411
    Thank you Hawkeye but I'm on 14 awg Monster now and you are right. It is better than lamp cord for sure.
  • Igo
    Igo Posts: 411
    Now this looks like a price I can work with. Do you know if there is an article someplace about properly terminating this 4 strand wire? I am an industrial Maintinance tec and I ain't skeerd.
  • Igo
    Igo Posts: 411
    janmike wrote: »
    LOL. I seem to be about one post too slow everytime an offering comes up. Cable gets snatched up quickly.
  • Igo
    Igo Posts: 411
    NJPOLKER wrote: »
    Igo,
    Drew
    Mr. NJ, I keep seeing the Audioquest 4's posted here but when I look for them, they are $125 for an 8 ft pair. That's tall for an ES but I could go the price at the $60 you mention if I can find them. The ES I use is a very nice 7.1 receiver but I sudo bi-amp the front mains with the rear surrounds in a 5.1 configuration. It helps my justify using 5 speakers instead of 7. : ) but then I have to make two run each to the front pairs and I'll do the same for the center. Music is more important to me so the rears will continue to make due with 14awg Monster stranded wire.
  • Igo
    Igo Posts: 411
    beardog03 wrote: »
    AQ Type 4...
    Just my .02
    "Cary" on
    beardog, gotta link for me on that? <as mastercard trimbles in tightly clinched fist>
  • beardog03
    www.audioadvisor.com
    800-942-0220
    hope this helps
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • Igo
    Igo Posts: 411
    Thanks BD. I was there, just didn't find the sale. I'll look a little harder.
  • beardog03
    I have the catalog that they send through the mail, and found that sometimes the deals in the book don`t show up online
    Pg.69 in the catalog has the type 4, and Slates on sale.....slates up to 51% off, and the 4`s are on sale.
    no frills cables in type 4 start at $89.95 (6 ft) to $$199 (20ft)
    Slates ....$129 to $335 for cable pairs......Single cables are half that.......bi-wire sart at $144.99 to $360
    they can do speacial runs also
    no affil., of course
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • MLZ
    MLZ Posts: 214
    Igo wrote: »
    For Canare i followed http://www.audiokarma.org/forums/showthread.php?t=94203
    FYI: 25 feet of 3/8 inch techflex covered about 21 feet of Canare (Techflex was just for looks but I liked it for $12.00)
  • beardog03
    very interesting !
    Thanks for the link
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    you should get Signal Cables, nice build quality.
    RT1
  • TNRabbit
    TNRabbit Posts: 2,168
    Blue Jeans is very good. If you're looking for cheap cheap, try www.monoprice.com
    They sell some 12 guage that is decent.
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • wizzy
    wizzy Posts: 867
    The best place I know of to get the Canare 4S11 is Westlake Electronics
    $0.80/foot
    http://www.westlake-electronic.com/item_detail/CAN10043/index.htm
  • wizzy
    wizzy Posts: 867
  • steveinaz
    steveinaz Posts: 19,545
    I would look into the following; they all offer a good product at a reasonable price:
    - Signal cable
    - Blue Jeans Cable
    - Monoprice
  • marvda1
    marvda1 Posts: 4,950
    here's some great prices on discontinued audioquest cables.
    http://www.hcmaudio.com/hcm.asp
    Puritan PSM156
  • markmarc
    markmarc Posts: 2,309
    Several quality value brands:
    Zebra Cables
    AudioArt
    My Audio Cables
    Blue Jean Cables
    Plus a few forum members sell cables they build as well
    Former Staff Member TONEAudio
    2 Ch. System
  • Igo
    Igo Posts: 411
    Way better responce than I thought I'd get. I have many great starting places.
    The last time I looked into cables I didn't have a really very good income. Up until this point I have done with the 14 awg Monster and it has served me well but I remember how much difference it made over the lamp cord stuff. I have to work many hours this week but I can't wait to siv through this stuff this weekend. Thanks so much everybody. I will look into everyone of these recomendations and I'll let you know what I go with and why I went that way and how it turned out.
