Want to try new IC's
Serendipity
Serendipity Posts: 6,975
edited November 2008 in Wanted (WTB) Classifieds
So - I've experimented with swapping RCA cables but didn't hear much of a difference. I've tried Radio Shack Gold Series, Monster II, and Straight Wire Analog IC's. However, I haven't heard much of a difference between what I tried so far.
What would you guys recommend for me to try? The Straight Wire cables were 3X the price of the Monster and the difference was small. So what would be the next step up?
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Post edited by Serendipity on
«134
  • janmike
    janmike Posts: 6,146
    Between what devices are you swapping cables?
    Michael ;)
    NORTH of 60°
  • ajcllc
    ajcllc Posts: 138
    appadv wrote: »
    These are really good for the money:
    http://zebracables.com/1505.html
  • Serendipity
    CD Player and AVR.
  • Kex
    Kex Posts: 5,205
    Why not go with BW Audio Concepts (ben)? There are some in the Flea Market right now (used), or check ben's Silver IC for sale thread (new). A lot of people use them here.
    Alea jacta est!
  • Serendipity
    Kex wrote: »
    Will I hear a difference? Ben's cables seem to be more expensive than the Monster but lower priced compared to the Straight Wire cables I had.
  • McLoki
    McLoki Posts: 5,231
    appadv wrote: »
    If it helps with the sound, he is considering raising his prices..... :p;)
  • Serendipity
    Seriously, I haven't heard much of a difference between swapping cables.
  • McLoki
    McLoki Posts: 5,231
    any other Polkies live close to you? Maybe you can make a day of testing out some different cables and or equipment...
  • Serendipity
    Yeah, I should do so.
    But why am I *not* hearing much of a difference between cables?
  • McLoki
    McLoki Posts: 5,231
    appadv wrote: »
    Not sure - could be a number of things - maybe cables are not the weak link in your system. Could also look at source, preamp, amp, speakers, room treatments, etc....
    I would try and figure out the weak link and spend the money solving that. Eventually cables will be the weak link, but it does not sound like that is the case right now.
  • Serendipity
    Hmm, I can barely hear the difference between CD players!! A while back I met up with a bunch of Polkies and put my $150 CDP up against a $1k Sony ES and the two sounded similar.
  • ben62670
    ben62670 Posts: 15,969
    OK I really hate to plug my own cables, but you have been here for a while. If you system sounds flat at all, and needs more life my cables will definitely boost it. If you have an overly bright system you will not enjoy my cables. Just read some reviews. This is a rare exception to the rule I have about plugging my cables. Get a set from Dave(I am plugging Dave the trader now:p(just kidding Dave:))), and if you don't like them you will be able to sell them. They are not for every system, but do get along with most. I had Kimber PBJ's and karma-ed them. I had Straight Wire EncoreII's, and karma-ed them. I had a bunch of other stuff like MC, and Rat Shack they are all gone now;) Like I have stated before MIT's, and Goertz are the ones mine lose out to. They cost a lot more, but they beat mine;)
    Enjoy
    Ben
    Ben
  • McLoki
    McLoki Posts: 5,231
    ok, so mark source off your list - whats next in the chain?
  • Serendipity
    McLoki wrote: »
    Onkyo 702, then Definitive BP10B.
    This is odd - I should be able to hear small changes in the sound, as I was a concert pianist for years, competed all over, and even won the Carnegie Hall Young Artists' Showcase piano competition - and performed there.
    So its definitely not my hearing.
  • ben62670
    appadv wrote: »
    Sorry to be blunt, but crap IC's, or crap speaker cables will hinder the performance of the other. Good IC's, and ghetto speaker cable equals ghetto sound. Good speaker cables, and cheap IC's equals not so good either. Have decent cables on both, and you are deaf if you don't get goose bumps from the awakening:D Seriously if you are ready to go to the next step get some used AQ type 4's, and a pair of IC's from Dave.
    Ben
    Ben
  • McLoki
    McLoki Posts: 5,231
    In the tests we were doing over the weekend, with some cables (or some sources) it was very hard to hear other changes in the system. (We did not try changing amps or preamps this go round)
    You might shoot Sid a PM as he is very familar with the definitives and might be able to tell you what to change in your system to get maximum bang for the buck.
    What are you trying to correct? Does anything sound wrong now? What do you want out of the change (any change that you make)?
    (what ben says above is very true - that was one of the things that we changed that made other changes hard to hear - bad interconnects made speaker wires and cd players sound similar. Bad speaker wires made interconnects sound similar....)
  • Serendipity
    ben62670 wrote: »
    Ben
    Changing speaker cables didn't make much of a difference on my system either, even when combined with the Straight Wire Analog IC's (expensive)!
  • Serendipity
    McLoki wrote: »
    Wait a second - when I did the CDP comparison ($150 Onkyo vs. $1k Sony ES), the Polkie had Ben's silver IC's in his system AND very expensive speaker cables. Most agreed that the Onkyo sounded better.
  • McLoki
    McLoki Posts: 5,231
    And that is one reason that many say you cannot compare audio based on price. Trust your ears and if they sound very similar - go with the less expensive option and do not feel guilty about it.
  • ben62670
    I am not an optical player expert:)
    Ben
  • Serendipity
    Ben - I tried to PM this to you but couldn't figure it out:
  • McLoki
    McLoki Posts: 5,231
    Where are you located? (state will be close enough....)
  • Serendipity
    Did you not see the pics from above?
    Location is right in the first pic :)
  • ben62670
    I need to start a cable swap program for Polkies that stick around...
    Ben
  • McLoki
    McLoki Posts: 5,231
    Sorry, I assumed people travel to play at Carnigie Hall. I was unaware it was a locals only event.... :p
  • Serendipity
    That would be NY.
  • McLoki
    McLoki Posts: 5,231
    You should have lots of Polkies you could hook up with. I would highly recommend trying it and getting your ears on some different gear and cables. (maybe bring your cables along and compare them to whatever they have)
  • Serendipity
    Yeah, I should.
  • gdb
    gdb Posts: 6,012
    Maybe I'm just biased, but I've never thought that even the more expensive AV receivers could "hold a candle" to the sound produced by a good quality 2channel preamp/power amp set-up. For movies,great! You have a Steinway?? I like F.Chopin and Jellyroll Morton and everyone in between. If you haven't seen a flic called-The Legend of 1900, you owe it to yourself to check it out! :) Geoff
  • Serendipity
    I don't have a Steinway but I'd like to own one one day :)
