Preamp vs Amplifier...Whats the difference?
DannyD
DannyD Posts: 133
edited January 2008 in Troubleshooting
Can someone explian to me the difference between an amplifier and a preamp?
I'm confused over the responsibility of a preamp in HT system. Do you have to have both for one to work or are they independant of eachother? If you had both, doesthat mean you would no longer need a receiver? Please help...my head hurts it's so confusing. All I want is to blow my windows out with soundwaves...is that to much to ask?
Fronts: RTI10's
Center: CSIA6
Rears: RTIA3's
Sub: 15" Velodyne DLS5000R x2 Stacked:D:D:D
Amp: Marantz MM-9000 150wpc (bi-amped for RTI10's) and CSIA6
Blu-Ray: PS3
Harman Kardon AVR247
Monster Cables
Signal Analog II IC's
Panamax MP-5300 Power Conditioner
Post edited by DannyD on
  • jabrax
    jabrax Posts: 315
    edited January 2008
    I'll take a shot.
    Preamp is like the brains, controls everything.....u use it as a control center for what u want to do...play music, watch tv, just like u do with your AVr
    Amplifier is like the heart, or muscles, or balls :) whichever you relate to best.....it doesn't have to think, just pass a nice clean amplified signal to the speakers.
    TV...............Hitachi 42hdS52a plasma (sexy one with the swival)
    Pre/Processor - Emotiva MMC
    Seven Ch AMP - Emotiva LPA
    Fronts - Tyler Acoustics 7U's
    Center - Polk LSIC
    Sub - DSWPRO600
    DAC - Music Hall 25.3CD - Marantz cc4001
    Blue Ray - PS3
    Speaker cables - Audioquest cv4 dbs
    Interconnects - MIT AVT1's
    Power Filter....Monster HTS 3500 MKII
  • zingo
    zingo Posts: 11,258
    edited January 2008
    (Over-simplified) An amp and preamp combo replaces a receiver, so it is either one or the other. A receiver is cheaper and all inclusive. An amp and preamp combo will cost you more, but produces better sound because the amps tend to be more powerful and the preamps sound better because they have good decoders and processors. Basicly, the amp/preamp combo is more specialized then a receiver, so has the opportunity to be better. As far as HT goes, a preamp processor (prepro) is required. This is because the signal needs to be split and processed into your 5.1 or 7.1 system. It also provides you lots of control over the entire system. You could in theory run a 2 channel off of two speakers, an amp, and an iPod, although not recommended.
    HK are very quality receivers that most people on this forum respect when it comes to HT. Obviously, they are not an amp/prepro combo, but better than a lot of stuff out there. The AVR247 isn't high power, but has all the decoders and should sound good.
  • DannyD
    DannyD Posts: 133
    edited January 2008
    Wow! What was so confusing earlier is so clear now. Thanks for the explanations guys. I think I'm going to purchase a emotiva amplifier in the near future. Any thoughts on this company? How much power should I be looking for for a 5-7 channel amp? I want it to last for years and not have to worry about upgrading again.
    Fronts: RTI10's
    Center: CSIA6
    Rears: RTIA3's
    Blu-Ray: PS3
    Monster Cables
  • danger boy
    danger boy Posts: 15,722
    edited January 2008
    amp last for year and hardly ever get outdated, unlike pre amps.. which do get outdated, esp home theater pre amps. 2 ch pre amps don't get out dated like home theater ones do.
    PolkFest 2012, who's going>?
  • zingo
    zingo Posts: 11,258
    edited January 2008
    Emotiva is good stuff and a few people on here own them. If you can afford it, I would look for about 150-200 wpc. It will hold you over no matter what speakers come and go.
  • AndyGwis
    AndyGwis Posts: 3,655
    edited January 2008
    If your heart is set on an Emotiva Amp, I think it would be a good long term purchase. Amps in general depreciate very slowly and many last 20+ years with no degradation in sound / quality. It wil have slightly more headroom than the HK leading to a more dynamic music/movie experience.
    However, if you are looking for the best bang for your buck / instant gratification, spend some money and get a better subwoofer. I know that's not what you asked for, but while the amplifier would make a noticeable difference for movies and music, a good sub would make a huge difference for movies and a noticeable addition for music.
    The PSW10 may as well be renamed the POS10 in my opinion, especially since your other speakers are good-very good. It's a decent little sub for the price, but it won't do justice for movies and barely plausible for music. I had one for about 2 days once. There's a reason they give them away :)
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • DannyD
    DannyD Posts: 133
    edited January 2008
    You know now that you mention it, there are times when I have to get up to see if my sub is working or not cause sometimes I barely notice it. What sub do you recommend? I was in terested in the PSW505. What do you think?
    Fronts: RTI10's
    Center: CSIA6
    Rears: RTIA3's
    Blu-Ray: PS3
    Monster Cables
  • nikolas812
    nikolas812 Posts: 2,915
    edited January 2008
    Take a look at svs sound. If you can afford it will be worth it. You can also find some of there models used also.
    http://www.svsound.com/
  • rskarvan
    rskarvan Posts: 2,374
    edited January 2008
    An amplifier takes the source signal and turns it into a speaker signal.
    A pre-amplifier takes the source signal and either:
    a) turns it down a little with resistive elements (attenuates).
    b) turns it up a little with small amplification elements (gain) - but, remains a source signal.
    c) doesn't disturb the signal at all (unity gain).
    d) often acts as a switching device between multiple source signals. A gate-keeper for the amplifier.
