Preamp vs Amplifier...Whats the difference?
DannyD
Can someone explian to me the difference between an amplifier and a preamp?
I'm confused over the responsibility of a preamp in HT system. Do you have to have both for one to work or are they independant of eachother? If you had both, doesthat mean you would no longer need a receiver? Please help...my head hurts it's so confusing. All I want is to blow my windows out with soundwaves...is that to much to ask?
Fronts: RTI10's
Center: CSIA6
Rears: RTIA3's
Sub: 15" Velodyne DLS5000R x2 Stacked:D:D:D
Amp: Marantz MM-9000 150wpc (bi-amped for RTI10's) and CSIA6
Blu-Ray: PS3
Harman Kardon AVR247
Monster Cables
Signal Analog II IC's
Panamax MP-5300 Power Conditioner
Center: CSIA6
Rears: RTIA3's
Blu-Ray: PS3
Monster Cables
Post edited by DannyD on
I'll take a shot.
Preamp is like the brains, controls everything.....u use it as a control center for what u want to do...play music, watch tv, just like u do with your AVr
Amplifier is like the heart, or muscles, or balls
whichever you relate to best.....it doesn't have to think, just pass a nice clean amplified signal to the speakers. TV...............Hitachi 42hdS52a plasma (sexy one with the swival)
Pre/Processor - Emotiva MMC
Seven Ch AMP - Emotiva LPA
Fronts - Tyler Acoustics 7U's
Center - Polk LSIC
Sub - DSWPRO600
DAC - Music Hall 25.3CD - Marantz cc4001
Blue Ray - PS3
Speaker cables - Audioquest cv4 dbs
Interconnects - MIT AVT1's
Power Filter....Monster HTS 3500 MKII -
(Over-simplified) An amp and preamp combo replaces a receiver, so it is either one or the other. A receiver is cheaper and all inclusive. An amp and preamp combo will cost you more, but produces better sound because the amps tend to be more powerful and the preamps sound better because they have good decoders and processors. Basicly, the amp/preamp combo is more specialized then a receiver, so has the opportunity to be better. As far as HT goes, a preamp processor (prepro) is required. This is because the signal needs to be split and processed into your 5.1 or 7.1 system. It also provides you lots of control over the entire system. You could in theory run a 2 channel off of two speakers, an amp, and an iPod, although not recommended.
HK are very quality receivers that most people on this forum respect when it comes to HT. Obviously, they are not an amp/prepro combo, but better than a lot of stuff out there. The AVR247 isn't high power, but has all the decoders and should sound good. -
Wow! What was so confusing earlier is so clear now. Thanks for the explanations guys. I think I'm going to purchase a emotiva amplifier in the near future. Any thoughts on this company? How much power should I be looking for for a 5-7 channel amp? I want it to last for years and not have to worry about upgrading again.Fronts: RTI10's
Center: CSIA6
Rears: RTIA3's
Blu-Ray: PS3
Monster Cables
Panamax MP-5300 Power Conditioner -
amp last for year and hardly ever get outdated, unlike pre amps.. which do get outdated, esp home theater pre amps. 2 ch pre amps don't get out dated like home theater ones do.PolkFest 2012, who's going>?
Emotiva is good stuff and a few people on here own them. If you can afford it, I would look for about 150-200 wpc. It will hold you over no matter what speakers come and go.
If your heart is set on an Emotiva Amp, I think it would be a good long term purchase. Amps in general depreciate very slowly and many last 20+ years with no degradation in sound / quality. It wil have slightly more headroom than the HK leading to a more dynamic music/movie experience.
However, if you are looking for the best bang for your buck / instant gratification, spend some money and get a better subwoofer. I know that's not what you asked for, but while the amplifier would make a noticeable difference for movies and music, a good sub would make a huge difference for movies and a noticeable addition for music.
The PSW10 may as well be renamed the POS10 in my opinion, especially since your other speakers are good-very good. It's a decent little sub for the price, but it won't do justice for movies and barely plausible for music. I had one for about 2 days once. There's a reason they give them away
Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
You know now that you mention it, there are times when I have to get up to see if my sub is working or not cause sometimes I barely notice it. What sub do you recommend? I was in terested in the PSW505. What do you think?Fronts: RTI10's
Center: CSIA6
Rears: RTIA3's
Blu-Ray: PS3
Monster Cables
Take a look at svs sound. If you can afford it will be worth it. You can also find some of there models used also.
http://www.svsound.com/ -
An amplifier takes the source signal and turns it into a speaker signal.
A pre-amplifier takes the source signal and either:
a) turns it down a little with resistive elements (attenuates).
b) turns it up a little with small amplification elements (gain) - but, remains a source signal.
c) doesn't disturb the signal at all (unity gain).
d) often acts as a switching device between multiple source signals. A gate-keeper for the amplifier.
