Help R50s
hydrostream
Hi my R50s sound like crap lately.
I think the tweeters are blown
what should i do?
About a year old from FRYS
jerry
what should i do?
jerry
Main- GTP-500II,GDC-600,GFA-555II and energy C-500s
Basement-Audiosource pre/tuner,GFA-545,Onkyo
DX-1400 and RTI10s
Garage-GTP-450,onkyo M-282 and R50s with RTi55
drivers and X-overs.
My baby 18' V-king Mod VP with a merc 2.4 BP.
KTM 620 Supermoto
DX-1400 and RTI10s
KTM 620 Supermoto
Post edited by hydrostream on
Call polk customer service and order a new pair. You get a slight discount and free shipping for being a Club Polk member so be sure and mention that as well.
Good luck and once you get the new tweeters, turn the volume down a little...
You can check the tweeters using an old kitchen roll tube to isolate the sound from the drivers. Carefully position one end of the tube around the tweeter and the other end at your ear.Alea jacta est!
Turn the volume down?
Do you think thats why they blew?
I used a set of R300s before the 50s
and never had a problem and i still
crank them in the basement.
jerryMain- GTP-500II,GDC-600,GFA-555II and energy C-500s
DX-1400 and RTI10s
KTM 620 Supermoto -
If the tweeters are blown (please check them), then usually it means your AVR was unable to produce the output being demanded of it, creating a "clipped" signal and distorted sound: the usual cause for blown tweeters.Alea jacta est!
I hooked them back up and nothing coming
from the tweeters.
DX-1400 and RTI10s
KTM 620 Supermoto -
hydrostream wrote: »I hooked them back up and nothing coming
from the tweeters.
jerry
You would probably know yourself if you have played them loud enough to have blown the tweeters and I would not expect this type of misuse would not be covered under warranty. What type of receiver were you using and how high do you think you played them?Alea jacta est! -
I have a onkyo HT-r540.
I started with a set of R300s then i got the
R50s.
I think that from the start the 300s sounded
better.
Maybe my AVR but i would think it should
power the speakers just fine.(110 watts per channel)
I'm sure thats over rated.
I just removed a tweeter from the 300 to try
in the 50 and it works.
Checking to see if it was a bad connection
or crossover.
DX-1400 and RTI10s
KTM 620 Supermoto -
I did a little searching for polk tweeters and
it looks like it would be cheaper to buy
2 new complete speakers.
DX-1400 and RTI10s
KTM 620 Supermoto -
Hello Jerry,
Those speakers have a five year warranty, all you have to do is remove the tweeter and send it to the address they give in the warranty section of the owner's manual. I think you need to include a copy of your sales receipt. Polk will send you a replacement at no charge.
Jed -
Thanks will look into it.
DX-1400 and RTI10s
KTM 620 Supermoto -
No problem, Jerry, Polk will keep you flying!
Maybe the least expensive solution - in Indianapolis FRY's had R50's for $99 / pair
How the heck do people manage to blow tweeters on the R series?
I just listened to / watched the "nine inch nails - Live - Beside You In Time" DVD @ over 100db w/ my HT.
R15's as mains and surrounds. CSi25 Center Channel. SVS 20-39 PCi sub. HK 340 AVR driving everything except the SVS.
Sounded Great - like being at the concert.
The HK got really hot but I didn't blow any tweeters.Audio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
HT: Samsung QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
Howdy,
Most speaker problems are more related to what's driving the speakers rather than the speakers themselves. Receivers have no dynamic headroom and poor ability to deal with real world speaker loads. Also, a great deal of popular music contains so much built-in distortion that it masks any problems the receiver might be having.
JL -
I think when someone says... " I wasn't playing them that loud", is a dead give away.. really, anything electrical over driven beyond what it's build to handle will at some point die. esp given the cheap amp's in most receivers.
some of my friends hear the distortion when they play their music loud, but just think that their receiver is fine.. that it's a problem with THE speakers and not their cheap $99 receiver.
I've never blown a tweeter from distortion... and I crank it now and then. My ears would bleed before a tweeter would get fried.PolkFest 2012, who's going>?
I called and they are going to ship 2 new tweeters
out.
Go polk
thanks jerryMain- GTP-500II,GDC-600,GFA-555II and energy C-500s
DX-1400 and RTI10s
KTM 620 Supermoto
