No tubes in my system--am I missing out?
cstpeter
cstpeter Posts: 387
edited May 2007 in 2 Channel Audio
Damn, I've got the upgrade itch. Although I love the synergy of my system, I can't help but think I'm really missing out by not having tubes in the system.
I like keeping my system clean and simple, so I'd probably just replace my PS Audio GCC-250 with a tube integrated. Then again, going to tubes will likely negate the "keeping it simple" part.
Any thoughts? Is going tubular really the religious experience some claim it to be? Should I make the plunge?
Thanks.
Von Schweikert VR4-jr
Valve Audio Predator
Denon DVD-2900
PS Audio Digital Link III w/Cullen Level IV Mods
Pro-Ject Xpression w/Blue Point No. 2
Graham Slee Special Edition 2
PS Audio UPC-200
Post edited by cstpeter on
«13
  • Early B.
    Early B. Posts: 7,900
    edited May 2007
    Hell, yeah, you should make the plunge. If you're currently using a Denon 2900 as your source for music, consider getting a tube CDP. You'll get a much better quality of sound, IMO.
    "God grooves with tubes."
  • cstpeter
    cstpeter Posts: 387
    edited May 2007
    I'm using the 2900 as a transport only; I have the new PS Audio DAC, which I love. If I go tubes, it'll just be the amp.
    Denon DVD-2900
    PS Audio UPC-200
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited May 2007
    Your system is fine, you said yourself that it has synergy.
    Cheers,
    Russ
  • engtaz
    engtaz Posts: 7,669
    edited May 2007
    add a record player(Teres Audio Model 255 turntable), tube amp for 2 channel listening.
    engtaz
  • Early B.
    edited May 2007
    cstpeter wrote: »
    Oh, then forget about it. I wouldn't change out the amp just to experiment with tubes. You may want to try a tube buffer to see if you like it. If not, you can always sell it for what you paid.
  • venomclan
    venomclan Posts: 2,467
    edited May 2007
    Hi Peter,
    I am in the same boat as you with the same transport. As I also do not want to change out any of my main gear, I have been thinking about a tube buffer as Early suggests, used in conjunction with my dac. I have not pulled the trigger yet.
    Let us know what you decide.
    v
  • outlander
    outlander Posts: 218
    edited May 2007
    Go for it! I have no regrets going from SS to tubes whatsoever. I have a CJ pre with a pair of AES mono block amps and it is much more enjoyable to me than the Adcom combo I was using before. To me comparing tubes to SS is like comparing a real dog to a stuffed animal. IMO the tubes are much more life like.
    O
  • madmax
    madmax Posts: 12,434
    edited May 2007
    Pick up a nice used unit, try it, re-sell for the same price if it doesn't do it for you. Tube amps are awesome!
    madmax
    Vinyl, the final frontier...
  • candyliquor35m
    candyliquor35m Posts: 2,267
    edited May 2007
    Tubes are magical and should be on everyone's list of things to try in their lifetime like someone said about the carver amazings. I still listen to my ss system more than my tube rig mostly out of convenience, easy on and off, no tubes to warm up or burn out although my tube rig has been very reliable with only 1 tube going bad in 1-2 years of light use and that was a problem with the amp itself which I believe has been fixed.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited May 2007
    scratch it. there is nothing else to say.
    except
    TUBES RULE!!!!!!!!!!!!!!!:D
    RT1
  • Ricardo
    Ricardo Posts: 10,636
    edited May 2007
    A tube amp that would make justice to your VR4's will cost you more than what you'd probably be willing to pay just for "testing". You say you're happy with your system...but that "itch" won't go away...decisions...decisions...
    SOPA
  • Shizelbs
    Shizelbs Posts: 7,433
    edited May 2007
    I'd say buy something tubey to try out with the intentions of selling once your demo is done. Don't do it if you have to sell part of your system that you are happy with.
  • WilliamM2
    WilliamM2 Posts: 4,806
    edited May 2007
    I don't think you are missing out, but then, I don't like the sound of tubes.
    See if you can listen to a tube setup somewhere, and see if you like it before wasting any cash.
  • jm1
    jm1 Posts: 618
    edited May 2007
    outlander wrote: »
    O
    I would consider this an upgrade from the Adcom components you previously enjoyed.
    I have listened to several systems with both SS and tube pre/power amps. I always preferred the systems when the SS components (Ayre, Classe and Simaudio) have been reintroduced.
    As is has been mentioned before in the forum, its unfortunate high end SS components are included with mainstream SS components when comparisons to tubes are made. Personally, I prefer the lack of sonic characteristics of the above mentioned SS components over other SS or tube components I have heard.
    I don't think you are missing anything by not having tubes in the mix. If any of the local audio shops have tubes, arrange to have a listen to see what you think so you can satisfy your curiosity.
    All truth passes through three stages. First, it is ridiculed, second it is violently opposed and third, it is accepted as self evident.
    Arthur Schopenhauer
  • cstpeter
    cstpeter Posts: 387
    edited May 2007
    Thanks for the input guys. I've heard tube systems before, but it's just so hard to compare when I don't hear them on my system and in my listening room. But maybe I'll head to the local Von Schweikert dealer and get a listen to tubes driving the VR4jr.
    Shizelbs, I like your suggestion:
    Shizelbs wrote: »
    Denon DVD-2900
    PS Audio UPC-200
  • dorokusai
    dorokusai Posts: 25,576
    edited May 2007
    Enjoy what you own....the rest is trivial.
  • Joey_V
    Joey_V Posts: 8,600
    edited May 2007
    Chris,
    You can come over and borrow my Cary for a few days...
  • cstpeter
    cstpeter Posts: 387
    edited May 2007
    Joey_V wrote: »
    Chris,
    Now there's an idea. Thanks man!
    Denon DVD-2900
    PS Audio UPC-200
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited May 2007
    cstpeter wrote: »
    Why do you think you are missing out? More importantly, what exactly are you missing out on? What are you lacking now that you expect the introduction of tubed components to satisfy?
    cstpeter wrote: »
    OK. Again we need to go back to establishing an audio performance goal. When you make the switch, what are your expectations for improved performance?
    cstpeter wrote: »
    Absoulutely...for some people. Some people rave that the practice of Buddism is the ultimate religious experience...and it is...for some people. Don't get caught up in other people's "feelings". Determine what your audio needs (goals) are and select equipment accordingly. Take the "religious experiences" of others with a grain of salt. Do these other people have the same musical tastes as yours? Have these other people introduced tubes into systems similar to yours with good results? If so, then you can use their experiences as benchmarks with which to begin your search for greater audio satisfaction.
    cstpeter wrote: »
    Sure...if an appropriate amount of research and personal experience demonstrates that your audio life will be improved by the introduction of tubed components.
    Good luck.
  • madmax
    edited May 2007
    Come on, just give it a try. A little won't hurt you.
    We are pushers as a majority. :)
    madmax
  • Joey_V
    Joey_V Posts: 8,600
    edited May 2007
    cstpeter wrote: »
    Sweetness... I'll loan it to you for 2 weeks... I'm going on vacation in 3 weeks, you can have it then. If you want the Plinius too... just ask, bro. ;)
    Joey :)
    F1nut Posts: 51,721
    edited May 2007
    Yes.
  • cfrizz
    cfrizz Posts: 13,415
    edited May 2007
    Great post DK!
    Cstpeter you in your own words, "love the synergy of my system" So if it's not broke don't fix it.
    Go buy some new music/movies with that itch money. Too many people let themselves be influenced by all the ranting & raving of other people.
    treitz3 Posts: 19,966
    edited May 2007
    What you want to do is up to you, but I will say this......I don't have tubes in my rig. I do, however, have a Carver amp that sounds, or is emulated to sound like a tube amp.
    Now that I have heard the "sound" of tubes I will never look back. I can't stand SS any longer. Next in my audio journey comes a tube front end [Jolida baby!]. So long as the sound doesn't get too tubey, I'll be in heaven.
    My 2 cents......
  • WilliamM2
    edited May 2007
    Well put.
    edited May 2007
    WilliamM2 wrote: »
    Well put.
    But if [in general] we all hear things the same way, are we really ranting? Or are we spreading the word of truth thru experience?
  • RuSsMaN
    edited May 2007
    There are very few truths in audio.
    edited May 2007
    True.
  • WilliamM2
    edited May 2007
    We don't all hear things the same way. Like I said above, I prefer SS to tubes, always have. I'm not the only one either...
  • hearingimpared
    hearingimpared Posts: 21,136
    edited May 2007
    engtaz wrote: »
    Have you ever heard a Teres Audio Model 255 turntable?
