Lsim 703 or 702 for heights or rears?
afterburnt
afterburnt Posts: 7,892
Working on a 7.2 plus? Setup. Kind of debating if I should use the 702 or 703 for heights/Atmos, the others will end up being rears. Wut says yooz?
  • afterburnt
    How Polked am I? 9 LSiM's 3 Rti's, Monitors 70's x2 60's x4 40's x4 30's x2 CSI,20,15,11.AND 2 SUBS. gave a bunch of these away.
  • Mikey081057
    Mikey081057 Posts: 7,127
    Look into SVS for rears, heights and others.... the fronts and center should all be matched ... the rest are secondary and the SVS stuff is solid....
    Garage | Polk Monitor 5B's
  • afterburnt
    I have the speakers already just wondering how to arrange them.
  • Mikey081057
    Tinker around .. I have the 703's as surrounds and the 702's as rear surrounds....
  • Inspector 24
    Inspector 24 Posts: 1,308
    What fits best in your room? Which speakers will be the easiest to place? 702's are wide but lower profile for wall mounting, but not very aim-able. 703's stick out further but narrower width may fit on a shelf better and/or using a wall mount bracket can more easily aim them toward the sweet spot.
    I haven't hooked my 702 rears up yet and I don't have 703's but past experience with similarly laid out speakers suggests the 702's would have a wider more dispersed sound filed where the 703 would be more localized and direct. In my room dispersed is better as they're only about 6-8' behind and above my head. In a larger room where the rears are futher back it may help to have a more directed sound from a 703 tweeter pointing at you.
    Ultimately, what others said, experiment. :)
    Up
    LSi15 LSiC - RX-V3000
    Down
    Sim2 D60 - Dragonfly 106" Panny 500
  • afterburnt
    Unfortunately expermentation requires holes in the walls. Probably the most practical thing to do is use the 703's for heights. I will have 702's for surrounds and rears, should be interesting.
  • Inspector 24
    Get creative. Use a couple ladders, tall furniture, something to place them roughly in the spots you want. No drilling necessary.
    Up
    Down
  • afterburnt
    edited March 2020
    What do yooz say is the optimum height for 702's?
  • Mikey081057
    Tweeters at 2' above ear level.
  • Mikey081057
  • afterburnt
    Too low, I will bump into them like I bumped into the air conditioner.
  • Inspector 24
    No hard and fast rules with placement, rarely does a perfect room with no compromise exist. If they're somewhere behind and to the sides of you it will work, then let auto calibration do the rest. Don't overthink the surrounds. Worry more about your front stage placement. ;)
    Up
    Down
  • mantis
    mantis Posts: 17,455
    Surround placement can make or break the surround experience especially if there is more then one person listening.
    So for the surround speakers Ideally the Tweeter should be as close to 72 inches off he floor as possible. This gives you the best overall experience with generations of movie soundtracks. Today Atmos tries to tell you just above ear level and at one point at ear level. Well that doesn't work at all as if someone on the left side close to the speaker their head blocks some of the sound. Who the hell wants that?
    Surround back placement should be about 4 feet or so apart and at the exact same height as the surrounds. This gives you the best movement and realism. You can go wider depending on your room. The Dolby guides are close to right here.
    Dan
  • Inspector 24
    No doubt, I got lucky, my speakers are in near perfect positions and I get to sit smack in the middle of them. It's amazing. Blows away every theater I've been in.
    Afterburnt, if you're stuck between a rock and a hard place when it comes to placement you'll be forced to compromise somewhere. You'll either have to run wires in a difficult spot, rearrange the room, get different speakers, or put up with less than optimal placement and compromise with auto calibration. Pick the compromise that fits/sounds best. Otherwise build a room, longer than it is wide, and put the screen/front stage on the narrow end, and pre-wire for everything and then some. :D
    But really, don't overthink it. ;)
    Up
    Down
  • afterburnt
    mantis wrote: »
    Is there much detriment to raising the rears a bit higher, just so I don't bump into them with my shoulders and should the surrounds be at the same height?
    pitdogg2 Posts: 27,072
    afterburnt wrote: »
    mantis wrote: »
    I do not think so. My rears (JBL610) were placed at 7'5" on my back wall angled down.
  • afterburnt
    The 702's don't lend themselves to aiming.
  • Inspector 24
    So if you need to aim them the 703 is your answer. :)
    Up
    Down
  • afterburnt
    After staring at the ceiling for days, I now see that I have no choice but to use the 703's for heights, besides they probably won't stay there anyway. Kind of a waste of 703's.
