New internal hook up wire for speakers
If someone was to install new internal hook up wire for the speakers you think something like this would work very well ? My thoughts is to use red and black twisted together and white and green twisted together for positive and negative tabs on the drivers. I was pretty sure DK Raife used Audioquest but do not remember which I'm pretty sure this was not one he tried in his.
Thoughts ?
https://www.ebay.com/itm/Audioquest-SP-16-4-16-AWG-bulk-Speaker-cable-sold-by-the-foot-unterminated/162082841562?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649
    EndersShadow Posts: 17,719
    Thoughts ?
    Ray @DarqueKnight used pricier cable, but it was Audioquest. I've used FLX 14/4 many times for bi-wiring or just regular speaker wire with great success.
    The "other Dan" @mantis can likely tell you more about this stuff, but I think its just a spool of their installer grade in-wall speaker wire (see link). Should be decent...
    Otherwise Dougs got similar cable for not too bad a price either plus our discount. If I had to guess I'd say Furez is equivalent to Audioquest in this instance.
  • Malbec
    Malbec Posts: 558
    Ray used AudioQuest GO-4 15 AWG Hyper-Litz.
    He also used Cardas Litz 9.5AWG on a couple projects if I'm not mistaken.
  • I first rewired my SDA 1.2TL's with Cardas 9.5 AWG, then replaced that with AudioQuest GO-4.
    All my other SDAs and my LSi speakers were rewired with Cardas 9.5 AWG.
    pitdogg2 Posts: 27,239
    I was hoping you would see this and chime in
    Thanks Raife
    Thanks Mr. Skip
  • AudioQuest sells a few of their cable models unterminated. Refer to pages 36 and 37 of the current (June 1, 2016) pricebook, which can be downloaded from their website (scrool all the way to the bottom).
    Any AudioQuest dealer can order this for you. Shop around for the best deal. I ordered an 80 foot spool from Audio Advisor.
    Below is my thread about the GO-4 rewire. Sorry about the missing pics. Send any complaints to the shakedown artists at Ph0t0$uckit.
    http://forum.polkaudio.com/discussion/141258/audioquest-go-4-internal-wire-replacement-for-the-sda-srs-1-2tl/p1
  • mantis
    mantis Posts: 17,557
    I think using FLX or SLP from Audio quest in a 14-4 or even 16-4 configuration for internal wiring would be excellent.
    Dan
    mantis wrote: »
    You have a great can't be beat price per foot there Dan? I'd lean to the 14-4 twisting two together. Both of those are LGC and one being in wall correct
  • machone
    machone Posts: 1,562
    DSkip wrote: »
    Check out he Wireworld Helicon 16. It comes in OFC and OCC versions.
    I used the OFC version of the Helicon 16 in my 2.3TL's.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    machone wrote: »
    DSkip wrote: »
    Notice a difference?
  • machone
    Pittdogg2,
    This is what I posted shortly after I installed the wire.
    "The improved separation of instruments and vocals creates more depth, clarity and realism."
    It's a lot of work building the harnesses but I am glad I did it. It also presents the opportunity to replace the fastons. Some of the originals were not as tight as they should have been.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    Thanks did you use the ohno or ofc?
  • mantis
    mantis wrote: »
    PM me , I can hook you up. Just let me know how much you need in feet.
    Dan
  • machone
    OFC
    It took 15 meters to do the 2.3TL's.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    machone wrote: »
    OFC
    Thanks a bunch machone
    machone wrote: »
    OFC
    So you gonna start with re-wiring them internally first, and then do the Xover upgrades I take it?
    edited November 2017
    machone wrote: »
    OFC
    I'm speaking hypothetically. I have a friend who is asking me to look into stuff for him. Trying to get all ducks in a row to give an idea what the full Monty will be for him.
    Post edited by pitdogg2 on
    So is there a downside to using silver coated copper wire? Is it grainy or harsh sounding?
    Has anybody used Silvered copper? I'm not talking tinned copper
  • headrott
    headrott Posts: 5,496
    Personally, I would do OCC wire. In my experience, it gives greater clarity and detail compared to OFC.
    I must confess, I have not used OCC for rewiring the internal wiring in my SDA's, so far. But, when I used it in my DAC it was very evident in the sound quality difference.
    No decisions have been made. I'm just doing my due diligence to cover all bases. Silver coated copper had been brought up by another. I have only used it in video applications and was under the impression that for audio it could be harsh, sterile or whatever.
    Skip is correct when using 60-65 feet that cost can get out if control quick like.
    Thanks guys
    mhardy6647 Posts: 35,201
    FWIW, I don't like the sound of "pure" silver wire -- dunno about the silver-plated copper; no ears-on experience. I guess there's some logic to silver-plated copper, related to the skin effect (which isn't really a factor at audio frequencies, tho' some folks insist that it can be) and the relative resistivity of silver vs. copper.
    YMMV. I'd say try before you invest too heavily in it.
    F1nut Posts: 51,954
    I'm now using solid silver cables between the power supply and the main amp. For years I was afraid this would result in a bright sound. Boy, was I wrong and sorry I waited so long to get the cables. They brought even more realism to my rig that I thought was pretty real already.
    You guys know more about this stuff than do I.
  • headrott
    What cable are you using Jesse?
