Finally got my project RTAs
These RTA11TLs have some serious battle wounds.
1x ripped sw83
3x ripped MW6510s (various sized rips, non TOO big)
Missing SL3000 tweeters.
Crossovers look good
No major enclosure issues although contemplating doing a cherry wood makeover.
Will eventually refresh or upgrade the crossovers.
Might sound like a rough draw but I got them for free on the sole promise I would get them back up in running order.
I want to try and repair the rips in the drivers if possible just to see if it will play. I've been skimming posts and see various answers but also that it won't with that era of surrounds.
Will eventually replace all 4 MAd with factory replacements, get RDO198 tweeters and a used sw83 somewhere. I want to reglue the inside of the cabinet and make sure it's all air right.
This is my first polk project, I have a long way to go but I am ready and excited!
«13
  • boston1450
    boston1450 Posts: 7,758
    edited February 2016
    Look forward to how your project goes. Maybe some parts n pieces will pop up. The 198's tweets are well worth the $$$. Im gearing up to do my RTA's also. There are lots of great folk here with knowledge. Dont hesitate to ask anything. Welcome to the forum also
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • 11tsteve
    11tsteve Posts: 1,166
    are the rips in the rubber surrounds or in the actual drivers?
    Polk Lsi9
    N.E.W. A-20 class A 20W
    Keces DA-131 mk.II
    Paradigm DSP-3100 v.2
  • Nightfall
    Nightfall Posts: 10,083
    Have fun and enjoy!
    afterburnt wrote: »
    Village Idiot of Club Polk
  • Just the surrounds. The drivers seem to be untouched except by dust. One driver is completely frozen stuff so I'm guessing fried voice coil.
  • 11tsteve
    either a fried coil or a shifted magnet, which is a pretty good bet.
    I used super glue across the ripped surround on mine (screwdriver slipped) until I could get replacements.
    Re-veneering these is a fun, but time consuming undertaking. But I was very happy to not have to look at that crappy fake walnut any more.
    Polk Lsi9
    Keces DA-131 mk.II
  • Nightfall
    Magnet shift, the glue is so old in these MW's that it lets go. Get some Loctite Power Grab All Purpose so you can apply some to the working MW's and help prevent that happening to your good ones.
    afterburnt wrote: »
  • Makes sense! The magnet turns a little when applying pressure. What's the best way to remove to check? I wanted to reglue all the magnets anyways. As for the drivers, I've heard super glue however I was thinking of something more flexible like marine silicon adhesives or ive heard rv or air mattress patch glue.
  • Would magnet shift ruin the driver and render it useless and unable to repair?
  • boston1450
    Id just get another one.... Its been talked about here where some have tried to repair & gave up. I think there may even be some it worked for & the devices they designed & steps they took to do so. All interesting read. The Search Feature may help with that & tons of info on the 11's
    Randy-Maine
    by David WMG
  • Yeah I read a little about someone repairing the shifted magnet with a pvc pipe, screws and a lot of time positioning. Might be worth a shot until the bank account grows enough to get the factory replacements.
  • boston1450
    Good luck & do share how you make out
    Randy-Maine
    by David WMG
  • Will do guys! I'm sure I'll be back for support soon enough!
  • Got the magnet off without damaging the vc. Loose as a goose now, will try and reapply it later. i0aast4lzsst.jpg
    Also started glueing the surrounds in an attempt to get something that is playable.
    F1nut Posts: 52,101
    Silicone has no place in/on speakers or gear.
  • codycatalist
    codycatalist Posts: 2,661
    I know it really makes me sad to have to do this. =( These speakers had a hard life. Treated like garbage, almost taken to the dump. I just want to get these so I can plug it in and diagnose any xover issues. I plan on getting new replacement drivers, RDO198s and looking for an SW83 to replace it all.
    Only if time were on my side...
    xschop Posts: 5,559
    Are the surrounds butyl or nitrile in these MW's?
  • westmassguy
    westmassguy Posts: 6,850
    MW6510s are usually plentiful on fleaBay, and less expensive than the replacements from Polk. Just contact the seller, and make sure they pack them well for shipping.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • codycatalist
    Yeah I found 3 for $30 a piece which it's a great deal, going to have to snag them up. It's the SW83s I have to be patient for. The monitor 5s I have are the SW80...fail.
    I believe they are butyl but could be wrong.
  • westmassguy
    It's worth waiting for the correct Passive. The 11tls are awesome towers.
  • 11tsteve
    i will check. I might have one.... .no promises.
    Polk Lsi9
    Keces DA-131 mk.II
    Toolfan66 Posts: 18,257
    You're better off saving your money for a set in better shape.. I wouldn't waste my time and energy on that set..
    I know it's fun and all but not worth the money..
    BTW, I just might have a passive..
  • pkquat
    pkquat Posts: 748
    So the TL's switched to SW83's? There is a full set of PR's from an 11T on ebay with SW80 and SW81 shown. SW81 being the larger mass.
  • pkquat wrote: »
    Yeah the larger mass on the 11tls is still SW81 the smaller being the SW83.
    Toolfan66 wrote: »
    I agree I'll be over paying a carp ton compared to buying some on e bay. I however need something to keep me busy and the experience plus the hopefully blissful result will be worth it.
    Got the speakers at least working today although with glued drivers. Good news is the crossovers seem fine and I have a good air tight seal in the box.
  • codycatalist
    They are almost ready! I can't believe it! I have however noticed a good loss in cabinet pressure (holding in the PR I get maybe a second or less until the mid driver pressurized back in place). I plan on sealing the inside of the cabinet seems, when it comes to gaskets a few questions. 1. Did the mid drivers and PRs have gaskets? Mine do not seem to, are there suitable replacements? If not what are good ways to DIY the seal on the drivers and tweets?
    Thanks again everyone!
  • You want armacell, it is available at the Home Depot. All of your drivers and passives should have gaskets. Other forum members could tell you more about the push test on your particular speakers, good luck.
    Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
    Polk SDA2btl highly modded
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
  • codycatalist
    Yeah I've read between 4-5 seconds is good (at least that's what I got from lurking f1nut's posts) I will try and get some to apply this weekend to the drivers I have in place that will stay there. I have at least 1 more mw6510 to get and waiting on Toolfan to respond to buying his PR.
  • codycatalist
    Just ordered my tweeters and 2 mw6510 drivers. As of April 1st we will be fully restored (Driver and tweeter wise) and operational! Now to locate some grilles and seal the cabs. Will post pictures when finished.
  • codycatalist
    Wanting to put dynamat or peel and seal on the speaker baskets. Would Dynatape work? Or should I get the full sheet?
