SDA-1C Transitional Model Upgrade
westmassguy
This was a very interesting project. From the exterior, they're typical 1Cs, with slab tops and bottoms, and wrap-around grills. The IC was blade/blade, and the cabinet was a modified 1B. Inside, was a heavily modified 1B split crossover. I had reached out to @F1nut and @KennethSwauger for assistance. Apparently, during the transition from 1B to 1C, they not only used leftover cabinets, but crossovers as well. This gave me the chance to use @gimpod 's superb replacement circuit boards. I will say up front, I despise any and all Molex style Connectors. From my years building computers, they leave a lot to be desired.
The owner and I decided the Tweeter and Woofer Harnesses would be soldered directly to the board, and angled spade connectors would be used for the Binding Post Harnesses. All the Inductors were removed from the old Circuit Boards, and the Binding Post Cups were modified, since they had unused spools on the back. Sonicaps and Mills Resistors were chosen. New Erse SuperQ Inductors, SpeakONs, and New Binding Posts rounded out the upgrade. All Caps were hand matched, as well as the old Inductors, which were way off. What a pleasure working with the new boards. New mounting plates with Hurricane nuts were fabricated. Nylon Standoffs with Stainless Cap screws were used to secure everything.
Home Theater/2 Channel:
Cables: Speaker: Furez 10/2 with GLS Locking Banana Plugs
Interconnect: Furez 10/2 with SpeakONs
ICs: Custom Furez by Douglas Connections
Den:
Bose 901 Series II Continentals Restored, Re-Built Equalizer with Elna Silmic IIs, Sonicaps, and Silver Mica Caps
Carver CT-3 Pre, Carver C-500
dhsspeakerservice.com/
Den:
Outstanding work as always David!VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
Den:
dhsspeakerservice.com/ -
Nice Save Dave! Nothing like saving great set of speakers. I think somebody has a smile on their face like I do.2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
Thanks DarrylHome Theater/2 Channel:
Den:
Very nice Dave. Those original c/o's look like a complete cluster f**k. New boards look clean and neat. Even though my 1c's are fine, it makes me want to redo everything with the gimpod boards.
Hey Bruce, thanks. They are a pleasure to work with.Home Theater/2 Channel:
Den:
Very nice work.
Den:
beautiful work from the master in our lives!!"if it's not fun, it's not worth it & remember folks, "It's All About The Music"!!
tophatjohnny wrote: »beautiful work from the master in our lives!!
Thanks BrotherHome Theater/2 Channel:
Den:
VERY NICE!, I like the idea of using spade connectors instead of the MATE-N-LOCK Connectors (These are different than the Molex type used on PC's), I chose to stay with the MATE-N-LOCK Connectors so everyone could use the stock wiring (pug & play) and not mess with putting new terminals on the stock wiring.
But again Very Nice job David.
“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
Thanks Tony.Home Theater/2 Channel:
Den:
