Sda crs
isarealboy772
isarealboy772 Posts: 26
edited September 2013 in Troubleshooting
Had my SDA CRS's out last night playing music, when all of a sudden the bottom right speaker in the left channel caught on fire :cry: It burnt through the front screen and also burnt the top right tweeter (these are the dual tweeter earlier model). Any idea why this might have happened and how to prevent it in the future? I was most likely planning on buying new parts from Polk, they're my dads old speakers from college so they're somewhat of a sentimental item after he passed them down to me.
Post edited by isarealboy772 on
«134
  • halo71
    halo71 Posts: 4,604
    pics please....
    --Gary--
  • isarealboy772
    halo71 wrote: »
    pics please....
    Should've put them in the original post, apologies.
    anonymouse wrote: »
    The most likely explanation is a major malfunction in your amplifier or cabling sending a very high voltage to your speaker. It is VERY unlikely normal audio signals and volumes will result in a fire. I'd get that amp checked out by a pro.
    My current receiver is a Kenwood VR-209, and I would say the speakers were playing relatively loud. Nothing crazy, but I'd say about 75% of the way turned up. I'd think I'm better off just buying a new receiver vs. getting it checked out, considering the current one isn't worth that much.
  • gumbay13
    gumbay13 Posts: 360
    Good thing you were around when it happened!
    Personally any electronic/electrical device that catches on FIRE gets replaced.
    I dont fool around trying to fix it unless it is under warranty then i'd be calling the manufacturer for a replacement.
    AMP/Pre Pro: Outlaw 7000x, Marantz AV7703
    Speakers: Fronts:LSiM 705s/ Center: LSiM 706c / Surrounds: LSim 703s
    SUB: Rythmik LV12R x2
    Source:OPPO UDP-203
    F1nut Posts: 50,682
    Damn.....LOL
    I agree with anonymouse that your receiver is the likely culprit. At 75% volume your receiver was being overdriven. The general rule of thumb, keep it below 50%. If that's not loud enough for you, you need more power.
  • TNHNDYMAN
    TNHNDYMAN Posts: 2,145
    Are you related to PFB? That's what happens when you listen to acid rock backwards while cooking meth...
    Just giving you a hard time. That looks pretty scary, I would definitely try a different receiver and you may want to contact someone to do some crossover repair work.
  • headrott
    headrott Posts: 5,496
    Agree with others. You need more (high current) power.
  • markamerica
    markamerica Posts: 203
    Owww... That sucks. I tend to agree with others that you should look at the receiver. Sorry to see the meltdown.
    SDA SRS, SDA SRS1.2TL, SDA-1C,SDA 2B, Soundcraftsmen Amplification (A5002s, MA5002s, MA5002As)
    nooshinjohn Posts: 25,449
    The receiver may not be the problem, in terms of there being a failure inside it. It was clearly being over-driven into what I suspect is a 4 ohm load. The speakers can be fixed fairly easily, but I suspect BOTH suffered some damage. rebuilding the crossovers is a must, and obviously replacing the torched drivers.
    You will find plenty of help here in getting them sounding better than new in no time.
  • isarealboy772
    After all these responses, I think I'll be getting a higher watt amp regardless! Replacing the drivers I know I can do, I'll order some new ones from polk (hopefully that won't break my wallet toooooo much). Anything else... any help with that personally? I'm very new to repairing audio equipment. Any help is more than appreciated :lol: I'll search the heck out of the forums too.
    Welcome to Club Polk!
    That's pretty impressive. I've never seen anything FLAME up like that (finger's crossed). You must have been really pounding them! What kind of equipment were you running? There are some amps that have no "relays" which is not a problem unless, well, unless there is something wrong with them and they decide to discharge a LOAD of current into what can't handle it! I have read about some amps going up in flames (such as the FLAME (PHASE) LINEARS. But never seen a speaker impersonate the Human Torch!
    Lots of info on this site about your "crossovers" and replacement drivers are readily available. Those are NICE speakers!
    cnh
  • leftwinger57
    leftwinger57 Posts: 2,917
    I told the story of when I found these ratty Bose 601s that were rehabed and I later flipped. With them the guy offered me a Sansui receiver, I said well lets turn it on .Because it was in the attic for 20 years or so the dust build up caught fire immediately and we walked the thing to the curb and said thanks but no......
    Your problem sounds like it sent 110v right into your speakers and just bypassed the step down x-former. Even before getting that new amp/receiver check the outlet you plugged into just for giggles ,you never know w/ electricity. Not good!!!
  • HTguru1982
    HTguru1982 Posts: 1,066
    Only speakers I've ever seen catch fire were Bose. About 11 years ago, was working at Chuck E Cheese where most of their showroom speakers were Klipsch, which sounded fine. But they also had a large set of Bose speakers which were used close to the stage and there was a complaint about the highs not being very pronounced(surprise, surprise) so tech decided to adjust the equalizer to bring out more detail and then POOF! The tweeters blew.
    Display: Sony 42" LCD
    Sources: Harman Kardon DVD-27,
    Panasonic DMP-BDT110 blu ray player
    AVR: Sony STR-DA2400ES
    Amps: Sonance Sonamp 260(fronts),
    Kenwood KM-894(surrounds)
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
    Surrounds: NHT Super One
    Subwoofer: SVS PB10-ISD
  • gimpod
    gimpod Posts: 1,793
    Man that sucks, but like F1nut said if you need to crank the eviction control knob past 50% or 12 O'clock you need more power. If I'm not mistaken those CRS's are rated for about 200 watts @ 4 Ohms max.
    The first thing I would do before ordering anything from Polk is check all the drivers, tweeters & crossovers so can get an idea on the costs to repair them. Tweeters & Drivers from Polk are around $50.00 each, so worst case you could be looking at around $400.00 for all new tweeters & drivers, On the tweeters if it's just the one you might be able to find a used SL1000 otherwise you'll need all 4, The RDO-194 is the replacement for the SL1000 and polk is out of stock until October.
    The crossovers could run as much as $400.00 or more, just depends on how bad they are. Check out Trey at Vr3Mods he'll be able to give you abetter idea of cost.
    Hope this helps.
  • isarealboy772
    cnh wrote: »
    cnh
    They were running through a Kenwood VR-209. Not exactly a great receiver, but it was holding me over till I found something better. I had them cranked up pretty high but didn't think they'd burst like this! It's probably partially since they hadn't be actively used like this for awhile. I'll definitely be doing my research! Heck of a lot to learn before I get these back in shape.
    gimpod wrote: »
    Hope this helps.
    This helped immensely. It's a 500 watt amp, obviously I was pushing too much power in but had no clue it would result in something like this. After a couple quick google searches I actually found the SL1000 tweeters online for purchase, I think I'll go that route since I don't exactly have the budget to replace everything!
    That crossover price is going to kill me, I'll contact Trey about it hopefully they're not that bad. Thanks a whole lot.
    F1nut Posts: 50,682
    No, that's not it at all. It's not fault of the speakers, it's the fact that you caused the AVR to send a clipped signal/DC voltage because at that volume level it was being overdriven. That's not to mention your AVR is not even rated to drive a 4 ohm load.
    No, it's not a 500 watt amp. It's an AVR, not an amp and it's only rated for 100 wpc, 2 channels driven. Had you actually been driving them with a 500 wpc amp, the speakers would have been fine.
    You weren't pushing too much power, it was too little.
  • isarealboy772
    This goes to show how little I know about this. Haha. Learning experience. It was a receiver I had in my basement and grabbed before I went back to school. My dad, whom claims to have much more knowledge than me, said it should be fine. Obviously wasn't and I'm paying a big price for it. I'll be getting a new receiver also. Sorry if I've frustrated you, big newbie at this.
  • Polkie2009
    Polkie2009 Posts: 3,834
    That model of Kenwood AVR was a pos. I bought one for an ex gf back in 1999 I believe. They were about the cheapest DD5.1 avr back then, I think I paid about $275.00 for it , and it sounded like it! Plus I remember how lightweight it was and plastic. It would distort if pushed very much past 10 o clock, think it was rated around 60 watts per channel, maybe. Those poor SDA CRS's deserved better.
    F1nut Posts: 50,682
    No worries, we all start at the beginning on the road of audio knowledge.
    If you want to be able to play them at concert levels, you need to buy a really good integrated amp or a separate pre amp and amp. Whatever it is, it must be rated to drive 4 ohm loads. Forget AVR's/receivers, they don't have what it takes, period.
  • isarealboy772
    Polkie2009 wrote: »
    Must be the reason it was sitting unused in my basement. Looks like it'll end up on craigslist soon for some other poor soul to deal with!
    Any recommendations on the preamp/amp or integrated amp setup? I'm not sure if this falls under concert levels, I just need them to at the very most be loud enough to overpower a group of about 35people (I have parties in my apartment here and there). Never even thought of looking at anything other than a receiver. You're helping out more than you can imagine.
  • Hermitism
    Hermitism Posts: 4,272
    I had no idea about the 50% rule. I HATE having to ask dumb questions, but if your AVR doesn't use the 1 to 10 scale, how do you know where the halfway mark is? I think I remember reading that mine tops out at +12dB. I've never looked where the scale starts on mine. They should install a warning light when you get to 50% and a R.I.P. blinking light when you get to 75%.
    tonyb Posts: 32,983
    For starters, keep it under -10 on that scale. I'm not so sure you want to sink that kind of coin into them. Drivers....crossovers.....tweeters, your talking a complete rebuild here. This will be some coinage, best rethink that sentimental value thing. Of course unless you have the coin to throw at them, then rock on.
    F1nut Posts: 50,682
    Absolutely, how deep down the rabbit hole do you want to go? In other words, what's your budget?
    I agree.
  • Hermitism
    For music I keep it between -30 and -20. For home theater -25 to -20. It's in a small room. I bought the speakers used, so I can't speak for the original owner. All I know is that he was using a Denon AVR to power them.
    tonyb Posts: 32,983
    Well then, he already did some damage most likely before you got them driving them with a receiver. You doing the same thing didn't help any and just fast tracked the inevitable.
  • Hermitism
    I think you're getting me mixed up with the other guy in this thread.
    tonyb Posts: 32,983
    Hermitism wrote: »
    Your right, I did.....my apologies.
    F1nut Posts: 50,682
    isarealboy772, tonyb has a point about the potential cost, but as far as I can tell you only need one driver and a tweeter at this time. Before you go any further remove the crossover and check it for any visible damage. A cooked resistor, inductor or blown/leaking cap will be easy to spot.
    tonyb Posts: 32,983
    My point Jess, even though we don't know about the crossover's condition yet, I'm betting seeing as these were abused fairly well that it's more than likely toast. Now, I don't know if the OP has the skills to do any or all of whats needed either but if he has to farm it out the cost can be up there.
    Before he goes ordering woofers, best to check the crossovers first and get a good idea of the costs involved to get these puppies back to spec. Aside from that, we are talking one speaker here when we both know both will need to be redone so double that cost.
  • leftwinger57
    As f-1nut once told me that's called a logarithmic scale (what ever that means I failed algebra about 16x)) and I had my own problems overdriving my avr.I bought a new Yamaha RX-V665 90wpc so I thought .And like I said many times before I wanted to air it out as it were.Well air it out I did, it got so hot it clipped and went into protection mode.Thankfully it came back and after being scolded here for pushing a weak machine the wrong way I learned my lesson .Comfortable listening on a avr for me is -30/-27Many have said this when getting an avr make sure it has pre/outs so you can add an external amp when the time is right.
  • isarealboy772
    For the amp setup, probably under $400, and used equipment for the sake of price vs. quality. I tried hooking up the other speaker and something is clearly wrong with that too... it's only playing sound through one tweeter. About to open both up and check for visible damage too.
    leftwinger just opened my eyes a bit about the pre/out thing, didn't know what that was until now. This receiver does have one, if that helps at all.
