I will be buying a DAC this week, what one should I choose?
polkfarmboy
polkfarmboy Posts: 5,703
edited April 2013 in Going Digital
My wife is giving me her blessing to go ahead and pick one even though I just bought a gaming pc
My question is what one? I have never even owned a good cd player as everythings been focused on everything but 2 channel music. I am all done with HT for the moment so this week I will probably just be reading a whole bunch about Dacs
My budget is around $2000 and don't want to go higher and there are many good options out there. It needs to be black even though silver or white sounds the same as I want to to blend with my gear. Right now all I have is my laptop as a source for delivery nothing more. I don't really know where to buy music from thats good quality or what programs to run to play them
Post edited by polkfarmboy on
    EndersShadow Posts: 17,542
    edited March 2013
    Well its not just a DAC but the Benchmark DAC1 HDR comes to mind. Its a combo DAC/Pre with a remote. Only connection lacking is TT. It gives you options later on to add more stuff than just your computer.
    Just my .02. I want one myself someday for my 2 channel system.
  • polkfarmboy
    edited March 2013
    I know benchmark has the dac 2 now and I like the idea of a dac with a preamp built in as its kinda like ... instant 2 channel just add music
    edited March 2013
    Yup, dont know if the DAC 2 has a remote though....
  • polkfarmboy
    edited March 2013
    I just spoke to a guy on audiogon he has a wyred4sound dac 2 listed for $1075. The bad news is that its in silver so strike that option even though that is a killer price on that and it too has a pre and remote
  • bklynNupe
    bklynNupe Posts: 728
    edited March 2013
    w4s dac2
    emotiva xpa-2
    emotiva xpa-3
    Denon 3312ci
    Rtia9 /csia6 / FXi A6
    Samsung LN46A650
    SVS PB-12-NSD sub
    Audio Research SP-9 MKIII (GNSC mods)
    W4S ST250
    Lsi 9 (mods)
    W4S DAC-2
    Mac Mini
    Audio Aero Prima CD player
    Pro-Ject debut
  • nspindel
    nspindel Posts: 5,343
    edited March 2013
    Just make sure you get one that's indestructible! :lol:
  • polkfarmboy
    edited March 2013
    bklynNupe wrote: »
    w4s dac2
    I know I am like ... WHY!!!!!!! does it have to be silver lol. I have never saw the price on that dac that cheap before
  • bklynNupe
    edited March 2013
    well, it's kind of black with the trim.
    I guess you can hold out if even a little silver is a non-starter.
    emotiva xpa-2
    emotiva xpa-3
    Denon 3312ci
    Samsung LN46A650
    SVS PB-12-NSD sub
    W4S ST250
    Lsi 9 (mods)
    W4S DAC-2
    Mac Mini
    Pro-Ject debut
  • cstmar01
    cstmar01 Posts: 4,424
    edited March 2013
    http://app.audiogon.com/listings/da-converters-ps-audio-perfectwave-dac-i-2013-03-02-digital-01341-conway-ma
    or the newer one:
    http://app.audiogon.com/listings/da-converters-ps-audio-perfect-wave-mkii-dac-2013-03-03-digital-14526-penfield-ny
    Both great DACs the MK2 being black but honestly if it sounds good I wouldn't care too much about what it looks like.
    There are a TON of Dacs Wyred is a good one too, so many, Esoteric also good, just going to come down to what you can find.
    Wadia has a small one thats black that performs well. Another forum that had a member that upgraded from the Wadia to the Esoteric 07 mk2 and was very happy with it. However the new 07 is around 4K or so.
    http://app.audiogon.com/listings/da-converters-esoteric-d-07-dac-preamplifier-with-full-warranty-2013-02-19-digital-01060-florence-ma
  • bklynNupe
    edited March 2013
    I caught mine for about the same price with shipping and didn't regret it one bit. it is a good price.
    emotiva xpa-2
    emotiva xpa-3
    Denon 3312ci
    Samsung LN46A650
    SVS PB-12-NSD sub
    W4S ST250
    Lsi 9 (mods)
    W4S DAC-2
    Mac Mini
    Pro-Ject debut
    heiney9 Posts: 25,091
    edited March 2013
    If all you have is a laptop for a source, don't waste $2K on a dac.
  • polkfarmboy
    edited March 2013
  • falconcry72
    falconcry72 Posts: 3,580
    edited March 2013
    Higher end Audio gd big boy, i.e., nfb-7 or 8. It'll blow that w4s out of the water. I might have one for you.
  • falconcry72
    edited March 2013
    heiney9 wrote: »
    Huh? If he's running lossless files with a bitperfect media player, there's hardly a better digital source.
    I'm interested in the rest of the rig though, cuz the 2k may be able to be triaged in a more effective way.
    Toolfan66 Posts: 16,938
    edited March 2013
  • nspindel
    edited March 2013
    I used to own the W4S Dac2 (in black...). Sold it to someone here. I ended up buying a Marantz SACD player that can also function as a Dac. I like the sound just as much as the Dac2, it's less money, plus you can obviously play SACD's! Check out the Marantz SA8004. If you get it, you'll thank me. Oh, and it's black.
  • polkfarmboy
    edited March 2013
    My rigs just a ht setup with an anthem d2 and anthem amps I have exp1 speaker cables and ic's and will be using Martin logan Vista for 2 channel listening
  • falconcry72
    edited March 2013
    Dude, you could go way cheap by just getting a usb>spdif converter hooked straight into your pre/pro, then spend the extra 1.7k elsewhere.
  • BlueFox
    BlueFox Posts: 15,251
    edited March 2013
    If you are not using USB then this is it.
    http://www.audioadvisor.com/prodinfo.asp?number=BYBDA1
    If you need USB then spend a few extra dollars.
    http://www.audioadvisor.com/prodinfo.asp?number=BYBDA2
  • polkfarmboy
    edited March 2013
    I heard the bryston bda1 and was not really loving it but it was a local demo and it was using paradigm speakers. The bda 2 though is only a few hundred more so I will get my read on with that
    As far as buy the usb>spdif converter hooked straight into your pre/pro, spend the extra 1.7k elsewhere. I have thought a little along those lines but I figured if I start with a nice dac then I can tough it out till I get a nice 2 channel amp then start on things like a good tube pre and higher end cables
  • BlueFox
    edited March 2013
    So many variables you never know what you are listening to. I upgraded from a Benchmark DAC1 to the BDP1, and love it. It gets good reviews except for the USB, which sucks. The BDP2 fixes the USB issues, and has newer DAC chips. It is supposed to be a bit better than the BDP1. I am sort of thinking of getting one for myself, but maybe a little later since I am really happy with both the two channel and HT at this time.
  • Moose68Bash
    Moose68Bash Posts: 3,842
    edited March 2013
    I'm very happy with my Cambridge Audio Azur 840C CD player that also functions as a DAC. Actually, I was so pleased with the first one I bought that I bought a second one to use my my second system.
    However, this model has been discontinued an replaced with the Azur 851C, which also serves as a digital preamp. I haven't heard one, but if it sounds as good as the 840C, it's worth a listen and it's in your price range.
  • nwohlford
    nwohlford Posts: 700
    edited March 2013
    I would go this route. I doubt a separate DAC is going to be much of a bump over the D2.
    If you want to buy a DAC, you could do the Wyred4Sound DAC2 and use the HT bypass in it. Personally, I like to use ARC in two channel as well. I found this to be better than a separate DAC.
  • mantis
    mantis Posts: 17,059
    edited March 2013
    I got a lot of experience with many different DAC's now Including the DAC 1 from Benchmark. We have a used one that you could get a killer deal on but we also have the brand new DAC 2. We also got in the Teac DAC's that I have not personally tested yet. we got Peach Tree , Cambridge , the Dragon Fly , man we are loaded with DAC's.
    if you join our website www.audiolab.com , you will get a discount. Also mention you know me and further your discounts. if you want to PM me , we could discuss your needs , price further or do it here. Either way I can help you get into a killer DAC for a Killer price.
    Dan
  • brgman
    brgman Posts: 2,859
    edited March 2013
    Get one of those Audioquest Dragonfly's and spend the rest on music.
    Or hookers and blow.
    I’M OFFENDED!!!!
  • Drenis
    Drenis Posts: 2,871
    edited March 2013
    heiney9 wrote: »
    *shakes head*
  • falconcry72
    edited March 2013
    nwohlford wrote: »
    If you do go this route, the USB>SPDIF converter to get is the Stello U3. Beats the pants off the Audio GD Digital Interface and Musical Fidelity V-Link, both of which beat the pants off the internal USB solutions on most USB/DACs.... including the Bryston BDA and the W4S DAC2.
  • BlueFox
    edited March 2013
    You forgot the Emotiva DAC.
  • falconcry72
    edited March 2013
    BlueFox wrote: »
    Isn't "emotiva" and "DAC" an oxymoron?
  • falconcry72
    edited March 2013
    I currently own (2) of the Audio GD "Big Boys" (NFB-7 and NFB-8). I will gladly put either one of them up against any of the DACs mentioned in this thread. Who's down for a shootout???
