Speaker recommendations please
Hello all,
Moving in a couple weeks into a home that has the living room pre-wired for surround on the cieling corners, for 2 rears and 2 fronts.
1. How difficult would it be to remove the plates and receptacle elec box attached to the joist, and then put in wall speakers?
2. Any suggestions for using elbows (or whatever there is) to attach speakers to the ceiling or near by wall (but i would like to hide or minimize wire from being seen)?
3. Any suggestions for a center speaker setup? The fireplace is in the middle and the TV will go above it making a center difficult to place.
Any suggestions in addition to the questions above will be appreciated.
Bonus Room:
Pioneer Elite VSX-32
RTi A7's / CSi A6
DSW PRO 600 sub
Emotiva XPA-5 & Interconnects
Sony Surrounds (rears) - replacing soon
Samsung BD-C5500
Panamax M5300, Xbox360, ...& more coming
Living Room:
Samsung 58" PLasma
Monoprice in-ceiling speakers
old sony receiver (replacing soon)
RTi A7's / CSi A6
DSW PRO 600 sub
Samsung BD-C5500
Living Room:
Samsung 58" PLasma
Post edited by myke on
You could use a ceiling speaker for the center. Properly installed and calibrated, it should work very well. A "phantom" center is also an option, if properly calibrated.Alea jacta est!
I have the A7s and A6 too. Quite frankly I am getting more and more convinced I like the sound better without center. Perhaps because the tweeters of the towers are right at my ear level and A6 is a bit lower. I still cant quite figure why, and I keep turning the center on and off..I have found that tube based computers provide the best sound quality. ENIAC and MANIAC I offer a smooth, well defined and articulated sound unmatched by the current silicon based CPUs.jeremymarcinko wrote: »But as in all things your perception is your reality.
Ravaneli -
I too tried the phantom approach too but the size of my current room lends itself to a center, the new home has a bonus which the RTi' A's are going into (with hopefully a projector soon......(wife permitting) or one of those upcoming larger plasma's (still reviewing)). I was thinking about getting some polk in wall speakers for the living room, nothing too fancy though.
Has anyone used polk in wall speakers on the ceiling? I'm also worried about how the sound will come across with 4 speaker coming from the ceiling?Bonus Room:
RTi A7's / CSi A6
DSW PRO 600 sub
Samsung BD-C5500
Living Room:
Samsung 58" PLasma
old sony receiver (replacing soon) -
... Has anyone used polk in wall speakers on the ceiling? ...Alea jacta est!
That's what I meant, I was being too general. For the 4 pre-wired speaker receptacles I am considering 4 ceiling speakers. They are placed in the corners of the room therefore I don't have a center pre-wired and was hoping for some ideas that people have tried, or does 4 ceiling speakers not need a 5th (center)?
I am also curious if anyone has tried ceiling speakers in this fashion and what their thoughts were regarding the sound quality, and what about the bass, is a sub still needed?Bonus Room:
RTi A7's / CSi A6
DSW PRO 600 sub
Samsung BD-C5500
Living Room:
Samsung 58" PLasma
Shalom, TonySamsung 60" UN60ES6100 LED, Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga: LCR mids “Foamed & Plugged**”, inside* & out
*soldered **Rob the Man (Xschop) LR: Tri-amped RTi A7 w/Rotels. Woofers - 980BX; Tweets & Mids - 981, connected w/Monoprice Premiere ICs
Ctr Ch: Rotel RB981 -> Bi-amped CSi A6 Surrounds: Premiere ICs ->Rotel 981 -> AR 12 ga -> RTi A3. 5 Subs: Sunfire True SW Signature -> LFE & Ctr Ch; 4 Audio Pro Evidence @ the “Corners”. Power Conditioning & Distribution: 4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s -
The Best idea for your pre wired speakers would be to prewire a center channel in the ceiling directly above your TV which you said will be mount above the fireplace.
If you can't do it yourself , hire a AV contractor in your area ( tell me where you live and I could suggest someone) . Purchase 5 exact In ceiling speakers with amiable tweeters. I suggest inspecting the area where they are prewired to and make sure they didn't do you wrong by putting the wires in bays with pipes or a lot of electrical wires. Also check the spacing from beam to beam , some ceilings have close together beams due to structure reasons. Again not a bad idea to get a professional involved at least for Speaker install , inspection and fishing the center channel. They will have to make a work hole or 2 to get the wires there but drywall is easy to fix and most AV guys will put the drywall back in but you will be required to spackle and paint. You can get someone to do this as well.
This is all worth the money spent so your project goes smooth. Nothing worse then making a disaster out of a project due to wrong tools , knowledge etc.Dan
Yes, Dan (mantis) is right in my opinion: add a center channel above the TV, and aim all your tweeters appropriately.
If possible, I would even use five identical speakers, but you do have the option to use a lesser model from the same range (meaning same tweeter, please!) for the two rear speakers.Alea jacta est!
