Logitech Squeezebox Touch vs. Duet
DMara Posts: 1,434
I have a couple questions and hope our CP experts can help clarify:
1. What's the difference between the little receiver that came with the Squeezebox Duet and the Squeezebox Touch? Is the Touch better per audio quality?
2. I currently own the Duet. If I buy an additional Squeezebox Touch for another zone, will I be able to use the Duet controller to control the Touch?
Gears shared to both living room & bedroom:
Integra DHC-80.3 / Oppo BDP-105 / DirecTV HR24 DVR /APC S15blk PC-UPS
Living room:
LSiM707's / LSiM706c / LSiM702 F/X's / dual JL Audio Fathom F113's / Parasound Halo A51 / Panasonic 65" TC-P65VT50
Bedroom:
Usher Dancer Mini 2 Diamond DMD's / Logitech SB Touch / W4S STP-SE / W4S DAC-2 / W4S ST-1000 / Samsung 52" LN52B750
Other rooms:
Audioengine AP4's / GLOW Audio Sub One / audio-gd NFB-3 DAC / Audioengine N22
audio-gd NFB-10.2 / Denon AH-D7000
Living room:
Bedroom:
Other rooms:
Post edited by DMara on
TV: Samsung UN55C8000 | Player: OPPO BDP-95 | Games: Xbox360 / PS3 | Party Music: Squeezebox Duet
Mains: LSi15 | Center: LSiC | Surrounds: LSiFX | Sub: SVS 20-39pci
Pre-Amp: Outlaw 990 | Power-Amp: Outlaw 7700
Cabinet: Salamander Synergy Twin 30 | Speaker Wire: Lowes 12AG w/ monoprice banana plugs
The Duet controller should control the Touch. I wasn't aware you could buy a Duet reciever without the remote.
You should be able to control any SB with the Duet controller. Personally, I hate that controller. If you have an iphone, ipod touch, or ipad, check out the app called iPeng. It is a great Squeezebox controller, it destroys the Duet controller, and turns you ios device into a Squeezebox player as well.
Yes, you can get a receiver without the remote - the product name is just called the Squeezebox Receiver. Beware, though - there's a funky reason why you need at least one Controller if you're using a Receiver. The only way to get the Receiver connected with your server is through the Controller, you can't do that with iPeng.
Ah, Face is right, looks like they've gotten rid of the player as a standalone product.
If it were me I'd get the Touch. I don't use the internal dac so I can't comment beyond what I've read.
There is an iPad version of iPeng. It's a completely different app designed for iPad, you need to purchase it separately. It's called iPengHD. It is excellent.
Are you saying I can actually make my itouch play music from the SQB server? How?
***\\\\\........................... My Audio Journey............................./////***
SOPA
Wierd, that did not come up the other day when I did a search, the regular iPeng did come up and so did Squeezepad but not iPengHD
Living room:
Bedroom:
Other rooms:
Didn't know that. I alredy have iPeng. But now that I think of it, why would I want to add this when I already have two SQB touch to play in the house....
I'm doing this with Pandora in my blackberry. Can't get any better than that.....Is there a sqb controller for the BB?????
SOPA
To play outside of the house.
I'm also going to buy SqueezePad and give it a try later.
I can see that with an iPhone, but at least in my case I don't see that happening with the iTouch.
BTW found this for the blackberry. It works, though the screen is way too small and the zoom is a bit cumbersome.
http://wiki.slimdevices.com/index.php/Blackberry
SOPA
I got a Squeezebox Classic today and I'm thrilled with the sound quality even using the DAC in the unit and the analog outputs, sounds very good. I am having a minor issue though.
I believe this issue is not with the Squeezebox itself, but rather the iPengHD app I'm using to control it. Sometime when I'm listening to one song and then select another song from my library to begin playing the song doesn't actually start. The app will show that it's playing, but no sound, then after maybe 30 seconds or so of blank air it will just skip to the next song on that album, and then I can hit the back button to play the song I originally chose. Clear as mud? Good.
The odd thing is that this doesn't happen when I play something from either the Squeezebox itself or from the web interfact that the SB server runs.
Any thoughts?
Love my setup.
In the very far away past something like that happened to me, but I was playing some "hidef" music via Windows Media Player, a below average PCI soundcard & a moderate CPU. Did you notice the quality of those files? Was it different to the rest?
Living room:
Bedroom:
Other rooms:
Squeezebox Classic, aka Squeezebox 3 is wireless. I have one that I can sell, actually, because I have a Touch on order, and I'll end up with a spare player (have 4 already...). PM me if you're interested.
The infamous Transporter. To buy or not to buy, that is the question. Asked many times, never really answered. It's the same concept as the other dedicated players (eg Touch and Duet - just plugs into preamp, doesn't have any speakers like the Boom or Radio).
It's marketed as the audiophile version of the Squeezebox platform. I've never heard one, so I can't comment on sound quality. It has a few features besides just higher spec electronics that the others don't have:
1. Fully balanced analog outs.
2. You can use it as a dac for another digital device.
3. It can player higher bitrate music. Other than the Touch, the other players will only play up to 1644. The Touch will play 2496 (good enough for my hirez needs). Transporter will play up to 192khz natively, with no downsampling.
4. It has a balanced AES/BSU digital output.
From the reviews I've read the sound quality is definitely great, but there are mods to be done to the Touch, SB3, and Duet that can make them sound pretty amazing, too.
I think I remember something like this happening as well, a long time ago. Not quite sure what I did to fix it but haven't seen that happen in a very long time. What version of squeezecenter are you running?
I've been playing 2496 with the Duet receiver connected to my Denon AVR4810ci via analog IC connections without any issue. When I go to "more info" on the Duet controller to view the file properties, it does show 2496. Was it downsampling when output though?
Living room:
Bedroom:
Other rooms:
