We're havin' a heat waaaave...
nadams
nadams Posts: 5,877
edited July 2010 in The Clubhouse
... A tropical heat waaaave...
Yesterday I saw my highest temp on the back porch since I moved in 3 years ago... 100.2*f. Today has to be higher, as Weather Underground says that it's 102*F, and that's usually a few degrees under what it is at my house. Wish I were home to look at the thermometer! It probably will have cooled down a little by the time I get home.
How stinkin' hot is it where you are?
Ludicrous gibs!
Post edited by nadams on
«13
  • dee1949
    dee1949 Posts: 1,425
    edited July 2010
    ....100 degrees in our Nation's Capitol at 3pm and HUMID.
    Oh those "COOL" memories of days past!!!
  • bobman1235
    bobman1235 Posts: 10,822
    edited July 2010
    Cracked 100 up here in the Merrimack Velley. Oppressively humid too. I'm usually not an A/C guy but you better believe it's cranking today.
  • Bubinga99
    Bubinga99 Posts: 283
    edited July 2010
    Here's a weather station near my house, currently 107.2F (and it's only 11:45AM) but check out last friday, 119.5F, and that's in the shade.
    http://www.wunderground.com/weatherstation/WXDailyHistory.asp?ID=KAZCHAND32&month=7&day=2&year=2010
    Yes the humidity is low, but a blow torch is a dry heat too ;)
  • FTGV
    FTGV Posts: 3,649
    edited July 2010
    It's in the 90's and very humid here and me dang igloo is melting.
  • Jstas
    Jstas Posts: 14,808
    edited July 2010
    NOAA has current temps at 100 degrees and climbing. Thankfully humidity is down near 25% with a 9 MPH SW wind with gusts as high as 18 MPH. Barometer is steady at 30 inches. But expect that to change by the end of the week 'cause they are saying thunderstorms by Friday night.
    Expert Moron Extraordinaire
  • concealer404
    concealer404 Posts: 7,440
    edited July 2010
    90 here and ridiculously humid.
  • Willow
    Willow Posts: 10,999
    edited July 2010
    108 with humidity here tomorrow is to be worse @ 111
  • muncybob
    muncybob Posts: 3,033
    edited July 2010
    not to worry, NOAA says Thrs it will go down to 96! man, I need to get A.C. at the house!
    Yep, my name really is Bob.
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited July 2010
    Nasty here in Gatineau. Was close to 110 with humidex this morning and I believe it is somewhere around 120 this afternoon.
    I needed to take my car this afternoon and the steering wheel was unbelievably hot. I am sticking inside (air conditionning) until I'm due to go home (1 hour travel in traffic and heat) and will definitely hit for the city indoor pool before going home.
    http://montreal.ctv.ca/servlet/an/local/CTVNews/20100705/mtl_heat_100705/20100705/?hub=MontrealHome
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • polrbehr
    polrbehr Posts: 2,830
    edited July 2010
    This is probably off by a little, but it's close enough to be demoralizing! :)
  • maximillian
    maximillian Posts: 2,144
    edited July 2010
    Electricity went out yesterday twice for about an hour each time. Joy.
  • Fireman32
    Fireman32 Posts: 4,845
    edited July 2010
    99 with 23% humidity and dew point at 55. Tomorrow will be 102
  • TECHNOKID
    edited July 2010
    A 14 year old young lad died yesterday when going up the step of a water slide. Must of had some heart problem as at this age you shouldn't die from effort in the heat.
    DARE TO SOAR:
  • packetjones
    packetjones Posts: 1,059
    edited July 2010
    Not bad right now. It is 73. It has been raining all day though. We are in the mid-high 90's normally. It is gonna be a hot summer that is for sure.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,726
    edited July 2010
    Is it normal for yous guys up in Canadia to get heat like this?
  • TECHNOKID
    edited July 2010
    Sometime we get good summers sometimes bad. It didn't start too well (some people were complaining that it was cool few days ago). I think we rarely get it that extremely hot.
    Summers are fairly warm and humid in Ottawa, although they are moderate in length. The average July maximum temperature is 26 °C (80 °F), with occasional northerly incursions of comfortable, cool air which drop humidity levels, although daytime temperatures of 30 °C (86 °F) or higher are commonplace in most summers. A maximum temperature of 39.5 °C (103 °F) was recorded in the summer of 2005 at certain locations. During periods of hot weather, high humidity is often an aggravating factor, especially close to the rivers. Ottawa annually averages 41, 12 and 2 days with humidex (combined temperature & humidity index) above 30 °C (86 °F), 35 °C (95 °F) and 40 °C (104 °F) respectively. The highest recorded humidex was 48 °C (118 °F) on August 1, 2006.[23]
    Spring and fall are variable, prone to extremes in temperature and unpredictable swings in conditions. Hot days above 30 °C (86 °F) have occurred as early as March (as in 2002) or as late as October, as well as snow well into May and early in October (although such events are extremely unusual and brief). Average annual precipitation averages around 943 millimetres (37 inches). The biggest one-day rainfall occurred on September 9, 2004 when the remnants of Hurricane Frances dumped nearly 136 mm (5½ inches) of rain in the city. The all-time monthly record is 243.4 mm (13.75 inches) set in July 2009. [24] There are about 2,060 hours of average sunshine annually (47% of possible).
    Destructive summer weather events such as tornadoes, major flash floods, extreme heat waves, severe hail and remnant effects from hurricanes are rare, but all have occurred in the Ottawa area. Some of the most notable tornadoes in the region occurred in 1978 (F2), 1994 (F3), 1999 (F1), 2002 (F1), 2004 (F1) and west end Ottawa 2009 (F0).[25][26]
    http://en.wikipedia.org/wiki/Ottawa
    DARE TO SOAR:
  • mantis
    mantis Posts: 17,189
    edited July 2010
    I hate this crap.
    Dan
  • nadams
    nadams Posts: 5,877
    edited July 2010
    Almost 11pm and it's still 87 outside. Yes indeedy! Thank you for A/c!!!
    Ludicrous gibs!
  • janmike
    janmike Posts: 6,146
    edited July 2010
    No thanks. Keep cool folks.
    Michael ;)
    NORTH of 60°
  • PerfectCreature
    PerfectCreature Posts: 1,456
    edited July 2010
    Well, from someone who practically lives in an Igloo....ha, just joking.
    Up in Maine it has been around 90-95 for the past week or so, really humid and rainy as well....
    just a mess.
    Receiver
    Harman Kardon HK 3490
    Speakers
    Polk Audio Monitor 50s
    Subwoofer
    Klipsch KSW-100
    Cables
    AudioQuest Rocket 33s 10ft
    AudioQuest Optilink1 2m
    AudioQuest Alpha-Snake 25ft Interconnect
    AudioQuest HDMI-1 2m
    Alienware X51 R2
    PS4
    Samsung Smart TV 40" 1080p 3D
  • Jstas
    Jstas Posts: 14,808
    edited July 2010
    Rain would be a godsend at this point.
  • PerfectCreature
    edited July 2010
    Oh, no way, it is just awful. It is hot and humid and the rain is even warm. I went out side all exited that I would get a cold shower, nope it was a hot rain. Just enough to wash my clothes had I had any tide.
    Now that the rain has stopped, it is still humid and they have even opened up a couple private/ indoor pools that used to require a fee, to the public for the time being.
    We are just ill equipped for the heat.
    Receiver
    Speakers
    Subwoofer
    Klipsch KSW-100
    Cables
    Alienware X51 R2
    PS4
  • audiobliss
    audiobliss Posts: 12,518
    edited July 2010
    11:15pm here and it's 79.2 out with 84% humidity and a heat index of 83. Thanks to links in this thread I just discovered www.weatherunderground.com. So I'll be keeping tabs with humidity, now. Everyone says it's humid here..and it is...but now I can actually look it up.
    And it rained today...totally didn't help anything.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • Rivrrat
    Rivrrat Posts: 2,101
    edited July 2010
    Welcome to my world this time of the year... Hot, humid, and thunderstorms. :p
    Actually, it's 91 at a little after 10 pm here, but I have something that most of you east coasters don't have....Whole house AC.
    Hopefully it cools down a bit for you all, and everyone gets through it in one piece.
    My equipment sig felt inadequate and deleted itself.
  • mmadden28
    mmadden28 Posts: 4,283
    edited July 2010
    Here is my favorite weather site:
    http://tinyurl.com/b7w9pw
    I had to 'Tiny URL' it because the URL itself might offend... ;)
    This was today's temp in my neck of the woods--my thermometer topped out at 103--It was hot but not unbearable--At least I didn't have to work outside in it.
    At least it looks like we'll get a storm to help break things up a bit on Wed. :cool:
    ____________________
    Pool: Atrium 60's/45's
    edited July 2010
    The high here hit over 110*F in Beijing and a few buses lit up because the ground temps (black asphalt) were purported to be over 154* F.
    I'm 'inside'..got the A/C running in the bedroom!
    cnh
  • lightman1
    lightman1 Posts: 10,788
    edited July 2010
    Sissies.....put on your girlie pants and cry.
  • mantis
    edited July 2010
    Jstas wrote: »
    I would so welcome it. I'd be like a kid and go outside and enjoy it.
    Dan
  • bobman1235
    edited July 2010
    Rivrrat wrote: »
    Since when are "humid" and "Arizona" synonymous? Is Tucson different than Phoenix in that regard?
  • hearingimpared
    hearingimpared Posts: 21,137
    edited July 2010
    UGH!!! Let the dog out at 7:00 AM, open the door and get hit in the face with a wall of heat and pea soup!. Check the weather online for my area 85 degrees w/52% humidity. The metorologist who posted those readings had to be drunk. Okay the 85 temperature but there is no way the humidity is 52%.
