Bare-bones integrated with subwoofer output
Clipdat
Stereo integrated amplifier. No frills.
No bluetooth, no DAC, no headphone jack, no phono stage, no balance or tone controls (if possible)
Minimal amount of inputs. Decent power output. A/B preferred, D acceptable. Must have subwoofer pre-out.
Does a product like this exist? If so, I want to buy it.
Here's a few that "kinda" fit:
https://audioengineusa.com/shop/amplifiers/n22-desktop-audio-amplifier/
(Leading contender)
https://nadelectronics.com/product/d-3020v2-hybrid-digital-amplifier/
(Original one doesn't have phono stage, both have BT)
(Leading contender)
https://emotiva.com/collections/amps/products/a-100
No frills (except headphone jack) and class A/B. Reviews outside of Emotiva are very positive for a simple but powerful little integrated amp. -
Not bad Zingo, not bad!
The fact that it has a fan inside of it is a little silly, imo. -
It's not clear to me if the Emotiva's RCA output can be used as a subwoofer pre-out. They describe it as a "loop output" that mirrors the input signal. "A loop output provides a duplicate of the input signal to facilitate chaining additional amplifiers or other devices."
In this case the output will be full range and not dependent on the volume control. I don't believe this would work as a subwoofer pre out. -
I have this amp and the 301 a step above it and like both, but it does have a DAC function you don’t need.
https://www.parts-express.com/teac-ai-101da-high-resolution-stereo-bluetooth-amplifier-with-usb-dac-2-x-26w--248-500 -
Interesting little guy. Vista Spark:
CNET Review:
https://www.cnet.com/news/vista-spark-a-compact-affordable-audiophile-amplifier-from-serbia/Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Wait.....did I just hear someone say "bare bones"?
Vital question: what’s the budget? And does it HAVE to have no frills, or is that to keep it under a certain $$$ limit.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Bedroom 2.1Cambridge Azur 551r; Polk RT25i; ACI Titan Subwoofer -
This guy has a sub out! Sprout by PS Audio.
Cute little guy!
Mmm, capacitor electrolyte used for popping corn!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Maverick Audio class A/B hybid integrated amp with preout.
https://www.mav-audio.com/base/product/tube_magic_a1 -
Mission Cyrus integrated would fit all your bills other than sub out. They usually go around $400 on eBay, although they aren’t too common AFAIK. Like my Mission speakers, only sold in England.
I don’t know much about them, other than that they supposedly sound really good. -
Hey Drew, how about an Ampino integrated? No sub out, but sweet!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
or... or... or...
Howzabout a high-quality power amplifier and a passive attenuator/source selector with two attenuated outputs?
This is the way I roll (well, I guess the high quality part's debatable) and it was trivial (at least from a logistical perspective) to add a (powered) subwoofer when the urge struck.
I have this amp and the 301 a step above it and like both, but it does have a DAC function you don’t need.Interesting little guy. Vista Spark:Vital question: what’s the budget? And does it HAVE to have no frills, or is that to keep it under a certain $$$ limit.This guy has a sub out! Sprout by PS Audio.Cute little guy! (Orb Audio Booster)Maverick Audio class A/B hybid integrated amp with preout.
https://www.mav-audio.com/base/product/tube_magic_a1mlistens03 wrote: »Mission Cyrus integrated would fit all your bills other than sub out. They usually go around $400 on eBay, although they aren’t too common AFAIK. Like my Mission speakers, only sold in England.
I don’t know much about them, other than that they supposedly sound really good.Hey Drew, how about an Ampino integrated? No sub out, but sweet!mhardy6647 wrote: »or... or... or...
This is the way I roll (well, I guess the high quality part's debatable) and it was trivial (at least from a logistical perspective) to add a (powered) subwoofer when the urge struck. -
HT: Samsung QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
I like this suggestion as well as it opens up the flexibility of running whatever amplifier I want. Do you know of a nice passive attenuator/source selector with two attenuated outputs?
https://luminousaudio.com/collections/axiom-ii-passive-preamp/products/axiom-ii-passive-preamp-walker-mod
I like these a lot from Luminous Audio as they are well built, but they also perform really well since Tim builds it to your source and amp specs.
Hell yeah! That's amazing.
Why can't you just run line level to the sub & the speakers simultaneously, as @F1nut suggested in the Setting Up A Subwoofer for 2.1 thread?Audio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
I don't know. I thought the pre-out method was the most easy and intuitive, with good sound quality. -
Drew - If you're considering used, I may be willing to part with my Music Hall A25.2. Fits all your needs, and would be WELL under budget. Nice little integrated that's 4 ohm stable with a sub out and definitely bare bones. Shoot me a PM if interested.
-Al
