Crossover for RTA12B
CH46E
CH46E Posts: 3,579
edited June 2018 in Vintage Speakers
Looking for quality caps for my rta12b. Having a hard time finding 4.4 uf. May have to buy eight 2.2uf.
I need two 56 uf, four 4.4 uf, eight 27uf, two 56uf and four 750pf silver mica.
And two 7.5 ohm resistors.
No Solen, Dayton or Aeoms please.
«134
  • CH46E
    CH46E Posts: 3,579
    Looks like the 4.4 are in a more critical location and am willing to pay good money for the right caps.
    pitdogg2 Posts: 24,639
    edited June 2018
    You do not need the 750pf silver mica caps with better film caps.
    Go to soniccraft.com. Sonicap gen. 1 is going to have most and the others will be close enough.
    If you want Jeff will make the exact value needed. It costs but worth it if you want the exact value.
    F1nut Posts: 49,864
    http://www.soniccraft.com/product_info.php/gen-sonicap-44-uf-200vdc-p-433
    They have the 27's too. For the 56 you'll have to parallel two 18uF and one 20uF.
    You don't need nor should you use the 750pF bypass caps when upgrading to film/foil caps.
  • CH46E
    CH46E Posts: 3,579
    Ok, just remove the bypass 750s? Jeff had me do that when he sold me all the caps for my JBL L80Ts.
    On that 56uf i notice there is very little space for it on the board. Not sure how ill be able to fit 3 film caps on there.
    Thanks guys for the info!
  • CH46E
    CH46E Posts: 3,579
    edited June 2018
    Oh ok..... i was wondering how you found the 4.4 on sonicaps. Turns out my phone was not displaying the pages on his site right. Now i can see all his options. Sweet! This will simplify things.
    I was happy with the sonicaps in the JBLs.
    Do you think thw level 3 matching to within a .25 uf is worth $5.00?
    Off the board with wire leeds to the XO or get very creative
  • CH46E
    CH46E Posts: 3,579
    This is what i have in there now. Think there would be any issues with the Mundorfs for the 56uf? Ill have to get the 27uf later.
    350v will be huge. Just an fyi
    I guess not much different than 3 lol
  • CH46E
    CH46E Posts: 3,579
    Placed the order today. Just need the 27uf caps now.
  • CH46E
    CH46E Posts: 3,579
    edited June 2018
    Do you guys think useing Clarity Cap CSA 27uf 250v would be a good match? They are $25 ea vs the sonicaps at $43 ea. I need 8 of them so it adds up fast.
    Any tips or pointers for improving mid bass punch? I also purchased some speaker gasket to seal all the drivers and PR. I was going to put a fresh bead of silicone in all the seams of the cabinet. I have also been reading about adding a bit of bracing. Was thinking about a brace or two between the PR and the drivers.
  • CH46E
    CH46E Posts: 3,579
    These are the Clarity Caps.
  • CH46E
    CH46E Posts: 3,579
    How do i move this thread to "Vintage Speakers"? And change title to "X over RTA12B"
    F1nut Posts: 49,864
    Mixing brands could work, but it could also be a disaster.
    edited June 2018
    CH46E wrote: »
    @KennethSwauger nuff said
    I know they get pricey but you're doing it once correct? So if you find you do not like it then it is VERY expensive. Take your time, if it was me they would be all sonicap or clarity. I have been putting my caps together now for 8 months saving here and there to make it work for my 2.3TL's.
  • CH46E
    CH46E Posts: 3,579
    Thanks Kenneth!
    Pitt, i may just go ahead and wait to purchase the Sonicaps. Uggh.
  • [Deleted User]
    [Deleted User] Posts: 7,658
    You're welcome!
  • CH46E
    CH46E Posts: 3,579
    Good lord, you aren't kidding! These things are huge!
  • westmassguy
    westmassguy Posts: 6,850
    You can relocate the 4.4s to the center, and 2 X 27uf hand matched for 55uf
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • CH46E
    CH46E Posts: 3,579
    Thanks Westmassguy.
    Do you think relocating the 56uf to center is a bad idea? Im not sure if the inductors will be affected by it. Also, what did you use to seal up thoes inductors? And one more question, once i have the old caps off what can I use to clean the boards? Mine look horrible!
  • RandyCroissant
    Looking great! You will love the sound once broken in. One thing I don't recommend any silicone be used in speakers, silicone outgasses corrosive fumes and will corrode your connections.
    Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
    Polk SDA2btl highly modded
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
  • CH46E
    CH46E Posts: 3,579
    edited June 2018
    Should i even bother with sealing the joints? As far as i know there are no leaks. Just figured if i was i there might as well make sure its sealed.
    If so, what should i use?
    Thanks for the heads up on the silicone!
    Also, i just set it there to see if it would fit. Have not started on them yet. Still need 8 27uf caps.
  • westmassguy
    CH46E wrote: »
    Thanks Westmassguy.
    Hot glue on the inductors. I use a china bristle and canned air for dust, and 99% isopropyl alcohol for the old adhesive. Inductors and caps don't interact when placed next to each other.
  • CH46E
    CH46E Posts: 3,579
    edited June 2018
    CH46E wrote: »
    Thanks Westmassguy.
    Juat happened to find out the wife has a hot glue gun! Score. One less thing to buy! Now if i could only find my solder iron! I was going to set the SRS2's back up while i work on the 12B. Maybe it is just my room, (to small for the srs 2) but they dont sound as good as the 12b IMHO. Cant wait to get these done.
  • drumminman
    drumminman Posts: 3,396
    You will love these after the sonicap upgrade. I would also recommend upgrading the tweeters to RD-0194’s - major improvement!
    I did both of these mods to my RTA-12c’s.
  • CH46E
    CH46E Posts: 3,579
    edited June 2018
    drumminman wrote: »
    Would that call for a value change in capacitors? I thought i read in the past that the 194 is not a sutible tweeter for the 12B. I recently removed the silver coil domes (sl2000?) and put some oem peerless in. I like them. When i got these 12b both tweeters were bad.
    Post edited by CH46E on
    F1nut Posts: 49,864
    The RD0194 is the direct replacement for the SL2000 that came with your speakers.
  • CH46E
    CH46E Posts: 3,579
    edited June 2018
    Mine came with peerless. Or so i thought......Thats what i have in there now.
    F1nut Posts: 49,864
    Ok, I see now that you replaced the original Peerless with the SL2000, so yeah stick with the Peerless.
  • CH46E
    CH46E Posts: 3,579
    Ok thanks, i thought maybe my message was a little confusing.
  • CH46E
    CH46E Posts: 3,579
    edited October 2018
    I did one XO last night. Still waiting on buying the 27uf caps. Think I may go with Mundorf. I did have to solder some leads to get the 56uf cap in that spot. These boards are very easy to solder on. Nice surprise.
    I also removed the old tweeter leads and put some Audioquest type 4 solid copper leads in there. I did not solder them to the tweeter yet as I'm not done with the caps.
    These caps are not directional right? Non-polarized??
