Looking for Misc Audio Deals of the Day? Updated info here!
1212213215217218357
  • CGTIII
    CGTIII Posts: 1,028
    Boston - CR7, CR6s, CR4s.
    ​Thompson Adventures, Inc.
    Clipdat Posts: 12,608
    Very "interesting" entertainment center: https://eastnc.craigslist.org/fuo/d/vintage-lacquer-entertainment/6521995606.html
    Isn't it nice how each component has no room to breathe or dissipate heat? Fantastic. And the speakers are up above, with grilles that are in no way shape or form acoustically transparent. Amazing setup.
  • MrBuhl
    MrBuhl Posts: 2,419
    ^^ art it seems, does not always follow function LOL! ^^
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
    Tony M Posts: 11,017
    what's with that blue/gray pole thing? God that makes it worse! And those orange bowl ashtray looking things... :s
  • MrBuhl
    MrBuhl Posts: 2,419
    Maybe that's the draft tube for the rear fan cooling units!
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
    I want whatever drugs the designer of that monstrosity was on when he came up with that...thing.
    nooshinjohn Posts: 25,101
    Clipdat wrote: »
    I think you found a stash of mushrooms already.
    txcoastal1 Posts: 13,132
    Clipdat wrote: »
    edited March 2018
    Let me know what they were on so I can stay away from that kind of drug. ;)
  • kharp1
    kharp1 Posts: 3,453
    Clipdat wrote: »
    Man, just start me out with half...I don't want to do too much like that guy.
    A bevy of Polk speakers for only $50: https://sfbay.craigslist.org/sby/ele/d/polk-audio-speaker-system/6535252300.html
    2x RT i28
    2x T15
    1x Cs245i - Center speaker
  • FestYboy
    FestYboy Posts: 3,861
    I can't imagine that the power cord is stock... And if it is, wow.
    Perfect example of more money than sense. To buy those speakers and amps and then put them like that, in that sized untreated room. Crazy.
    FestYboy wrote: »
    Certainly looks like a stock cord:
    Let's not forget their great choice of source: "OPPO BDP-205 deck, Roon Ready used in system as DAC and pre-amp (exceptional high fidelity sound)"
    (emphasis mine)
  • mrbigbluelight
    mrbigbluelight Posts: 9,272
    With that toe-in, it looks like the sweet spot would put you about 18" from the fireplace.
    "How'd your feet get burned ?'
    "Well, I was listening to tunes and ,,...."
  • DaveHo
    DaveHo Posts: 3,481
    Clipdat wrote: »
    (emphasis mine)
    While maybe not on par with the speakers & amps, the 205 is no slouch.
    Fair enough. Realized that after I posted it. But still, an OPPO wouldn't be my "go to" source if I had this kind of coin to throw around. Shrug.
    DaveHo wrote: »
  • mlistens03
    mlistens03 Posts: 2,767
    This is a pretty good deal on some infinity reference speakers, listing says there are 4 of them for $200, but they’ve got polycells instead of the original emits :disappointed:
    https://orlando.craigslist.org/ele/d/infinity-reference-three/6524924915.html
  • kharp1
    kharp1 Posts: 3,453
    Duhhh, he's using the wall as a heat sink.
  • aiconn
    aiconn Posts: 277
    This looks like a good deal for you Tejas polkies.
    https://austin.craigslist.org/ele/d/krell-integrated-amplifier/6535354150.html
    PS Audio Stellar Gain Cell DAC/Preamp
    Denon DVD 2910
    Quad 12L Active Monitors
    Marin Logan Dynamo 700W
  • kharp1
    kharp1 Posts: 3,453
    la2vegas wrote: »
    Wow! Nothing wrong with that. :)
    Although not the exact model, you get the picture.fjxkrddsiq6e.jpghttps://orangecounty.craigslist.org/ele/d/marantz-reference-sa14-s1-cd/6482650944.html
    @Clipdat You should grab it, mine won't go that low.
  • Dabutcher
    Dabutcher Posts: 2,591
    How do these Marantz players compare to the Oppo offerings? Peace. D
  • kharp1
    kharp1 Posts: 3,453
    I've never owned an Oppo, though I have heard them, and I'd say the Marantz is on the slightly warmer side. Detailed yet smooth. Pretty good dac. Mechanism is whisper quiet. I think you have to jump up considerably in price to better it. Even though I just got the PSA Directstream combo I doubt I'll sell my 14.
  • CGTIII
    CGTIII Posts: 1,028
    edited March 2018
    Audire Parlando Class-A Amplifier currently bid at $351 with under 5 hours to go.
    Local pickup only in Orange County. (85 lbs.) No affiliation.
    https://www.shopgoodwill.com/Item/50493699
    Is this the same exact model as yours? I thought this one looked newer/older.
    Also, it's silver... boooo
    kharp1 wrote: »
    kharp1 wrote: »
    You will never use the Marantz again after you set to the DirectStream Memory player... it is a couple orders of magnitude better than the Marantz.
