Equipment Racks
I want to know how stoned this guy was when he reviewed this rack and wrote this:
"Components placed on it will sound more upbeat and lively, which will be right up the alley of Naim-oriented people. By this I mean that if timing and a rhythmic quality is valued above everything else, this rack might be an excellent choice. However, it tends to harden and flatten the sound in a way that does not complement my system." -
Pretty sure it will not help his Hello Kitty Boombox!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Yeah, so that's my conundrum right now. Finding something affordable with the least amount of front to back and side to side wobble, that can support a 30lb turntable on the top shelf.
That was my worry as well, that because they have to make these things shippable, that the parts where they screw together would be the weak/flex point. As opposed to one solid length of column like the Adona racks.
They do look like they can be filled with lead shot, maybe if you insert each individual piece of shot one at a time.
So I'm sure you knew this was coming Using the failsafe @Clipdat method of mass loading one individual lead shot sphere at a time, assuming 8 hours/day with no potty breaks, it will take you 33.6 days to fully complete your task!
Another point for consideration! Hope this helps!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Just make a funnel out of a 2 liter bottle and use sand. Then call it a day.
Lead is more dense but sand packs harder and is much easier to fill. And last time I priced shot for reloading it was almost $2 a pound. You can buy a 50 pound bag of sand for about $3.
Unless you just want to spend more money for bragging rights?? -
Molten lead fill for the win."Make a man a fire and he'll be warm for a day. Light
a man on fire and he'll be warm for the rest of his life." -
Sand has a high moisture content and should be dried (usually in the oven) before using. I paid around a buck a pound for coated. -
Looks sweet. Wish I had room for a "double wide" rack like that.
In hindsight I wish I had bought a single width rack, with two maple plinths on each side for the amps. I think it would look better, and certainly provide better airflow for the amps. In fact, I have been wondering what piece of gear to upgrade next. Maybe a rack upgrade is in the cards.
Three 20 amp circuits. -
Fox,
You've relegated PASS ... To-The-Floor??
Sacrilege!AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
That ‘floor’ is more solid than the rack. It is on a concrete slab, which sits on the ground. Actually, it works out perfect for the Pass pre power supply.Lumin X1 file player, Westminster Labs interconnect cable
Bud, It looks to me like you could have the existing shelving cut in half, re-drill new holes in the shelves and accomplish this.
Utilize the large, lower shelf for you Amp Stands.
Sorry!
Not sure where you reside. I (mistakenly) assumed you lived in a home with a basement (like most folks in my vicinity)
Cannot beat the slab for SQAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
Mike Reeter wrote: »Looks sweet. Wish I had room for a "double wide" rack like that.
That’s not a bad idea. Thanks.
After a bit of schooling on mass loading, these 3"x3" extrusions from 80/20 would fit the bill. For the main posts.
So I was looking for an alternative to the big honking 3" x 3" posts for legs, and found these. Same overall size, ability to mass load, but would look more integrated when assembled.
For you DIYers out there, a common 2" ID pipe could use these for easy assembly. they also have nice endcaps for a finished look.
https://www.ebay.com/itm/Oajen-metal-threaded-star-type-insert-2-OD-round-tube-3-8-16-20-pcs/231688691332?ssPageName=STRK:MEBIDX:IT&_trksid=p2055119.m1438.l2649
Have a link handy? -
Yep. Looks like were a custom run and these are surplus.
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/331341606913Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Shipping just to me is over 50.00 each. So it's 120.00 a piece. Ouch.
I like it, but, it's not for me.
I'll have to stick with wood I guess.Most people just listen to music and watch movies. I EXPERIENCE them. -
I’m negotiating shipping for 2 pieces, which will be cut in half for the legs. Yeah he’s pretty steep on shipping. We’ll see what he comes up with.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Yeah, that shipping would price me out. If I was close by and could work a deal out I'd like to try and build a rack with this material.
Can you build one for me while you're at it?Yeah, that shipping would price me out. If I was close by and could work a deal out I'd like to try and build a rack with this material.
I think it would look better......
Having sad that....
I agree about modifying your rack given its $3500+ price and the reduced resale value and possibility of having to ship to sell it. I bet a good woodworker could cut off one half of those maple shelves to make a singe width rack. Then make amp stands with the others using the left over hardware....with some cutting and modifications. They should be able to match the deep rosewood finish. Heck, Samson / Mapleshade might even tell you what products they use to finish them?
Someday, I would love to build a DIY rack like yours.
2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Mirage Omni S8 sub1 | Mirage Omni S8 Sub2 -
Speaker Cables: Organic Audio Organic Reference 2
Interconnects: Argento Organic Reference 2, Argento Organic 2
Puritan PSM156 -
LOL, we've officially come full circle, back to the racks that were discussed on Page 1!
My threads go the distance!12 pages... wow.
I wonder what the functional/real world/rigidity/wobble/isolation/etc. difference is between these two:
looks like the isolation will be better on the first one.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
Too bad those platforms are small, I can't fit my preamp and monoblocks on the same shelf.looks like the isolation will be better on the first one.
maybe go with the 3 or 4 level rack and 2 amp stands.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
A good suggestion but I don't have any room. I only have room for a rack of this shape/size.
I could put the amps on the same surface as the speakers. But not sure how they would like the vibrations.maybe go with the 3 or 4 level rack and 2 amp stands.
