Magnify Mini is bricked after attempting firmware update via Google Home. Support is useless
I tried to update the soundbar via Google Home and the red light just blinked until the thing finally turned off. Support office was closed so I emailed them, but no response after 24 hours; now they're closed again.
Trying to reset by holding down the WiFi button on the back does nothing; same exact thing: Red light blinks until the unit turns off. I tried holding the button both until I heard a single tone, and until I heard a single tone followed by a tri-tone, both have the same effect.
Only way to get it to do anything is by unplugging it and plugging it back in, won't even "reset" via wifi button unless I do this.
I've tried hooking it up to ethernet and "resetting", nothing. Tried disconnecting optical and HDMI hookups and resetting, nothing. I've tried everything I can think of to get it to restore, or start working again and nothing works.
I'm at the end of my rope and Support is useless, so don't tell me to call them. Can anybody, for the love of God, just tell me how to do a factory reset of this thing? It's impossible to find out how to do this. Even if you have to PM me because of some terms of service BS, that's fine; I just wanna get this thing working without having to jump through a bunch of hoops on the phone or waiting 2 weeks for an email back.
  • NightfallNightfall Posts: 7,134
    First, downloading and installing corrupt or incorrect firmware means the item in question usually needs to be sent back to the manufacturer so they can reflash it. For example, unplugging your TV while it's halfway done installing a new firmware.
    Second, I would never use a third party device to update something as sensitive as the firmware on something. That's just asking for trouble.
    I would tell you that you need to call and get in contact with Polk but seeing as that's not an answer you want I'll just say best of luck to you.
    | Front - Dynaudio Emit M20 | Center - N/A | Rear - Polk Monitor 4 | Sub - N/A |
    | AVR - Yamaha Aventage RX-A1020 | Preamp - Dared MC-7P | Amp - B&K Reference 4420 |
    | Turntable - Yamaha PX-3 | Cartridge - Dynavector DV-20X2H | Digital Source - AURALiC Aries Mini |
    | TV - LG 60" 4K | Gaming - Xbox One - PS3 - New 3DS XL - Nvidia Shield TV |
    This body holding me reminds me of my own mortality
    Embrace this moment, remember, we are eternal
    All this pain is an illusion
  • mdaudioguymdaudioguy Posts: 4,037
    Nightfall wrote: »
    Not sure why you're preaching to the OP. There's no indication in his words that he downloaded or installed corrupt or incorrect firmware. He didn't use a third party device. Google Home is the app Polk uses to facilitate the update over WiFi.
    Don't know what to tell the OP other than keep trying to contact Customer Service. Hopefully @KennethSwauger or @KenCustomerService will jump on here and help. These soundbars are awesome when they work, but can be a bit flaky sometimes, as you might have read on here...
    7.1 - polk RTi10 x 3 (LCR) : FXi3 x 2 : RTi4 x 4 : Sunfire SDS-12 : Yamaha Aventage RX-A2040 : Adcom GFA-7500 : Squeezebox Touch : DIRECTV : Roku SE : Panasonic PT-AX200U PJ @ 120"
    5.1 - Definitive Technology ProMonitor 800 x 4 : ProCenter 1000 : Klipsch Sub-10 : Pioneer Elite SC-91: DIRECTV : LG OLED55B6P : Roku Premiere+
    Garage Duty - polk Monitor 10s : Pioneer A-717 Integrated Amp : Squeezebox Classic
  • LeeSoFLLeeSoFL Posts: 19
    Their support phone line is jammed during regular business hours. I've used their option of having them call me back, and they are very reliable in returning the call quickly. That's the only recommendation I can make El_Pared.
  • tonybtonyb Posts: 28,060
    Try leaving it unplugged for like a good half hour. Too short of time may not reset it.
    ERA D-5
    B&K 1403
    Cary Xciter dac
    Joule LA-100
    SVS SB-2000 SUB
    Sony 4k bdp
    Sony 4k 55 850c
    FX 500 surround
    Acoustic zen Satori SC's
    Pioneer elite vsx21
    Sonos-Cullen mod.
    Audio Metallurgy GA-0 digital
    PS Audio Quintet
    Analysis Plus crystal ovals
    Acoustic zen Matrix 2's IC
    Wireworld eclipse 7 Ic's
  • KennethSwaugerKennethSwauger Moderator Posts: 6,130
    Hello,
    I'm sorry you're having a problem. I'll send your email address to my friend at Polk and I'm sure he will contact you as soon as possible, probably on Monday.
    "Passion is inversely proportional to the amount of real information available", G. Benfield
  • El_ParedEl_Pared Posts: 2
    edited January 6
    alright, I guess I can try calling them on Monday. Thanks for the replies everyone. Kenneth I'll also check my email regularly, thanks for getting your "man on the inside" involved ;)
    mdaudioguy wrote: »
    Nightfall wrote: »
    The speaker thing that you talk to? Google's version of Alexa. "Hey Google, play that hipster song with whistling." device is what Polk uses for updates?
    Apologies maybe I'm the one confused.
    You're welcome. I'm sure he'll be able to help.
  • kthomsenkthomsen Posts: 9
    Nightfall wrote: »
    mdaudioguy wrote: »
    Nightfall wrote: »
    Google Home is the name of the app that you use to control all your Google devices, like Chromecast, Google Home speakers etc.
Howdy, Stranger!
