External Rings..
It's hard to capture the gloss black on these,
Not sure if they will have a negative affect on sound but it dresses them up a bit, and as always it's worth a try as I'm not out anything but time. Looking forward to having these hooked up again..
    Toolfan66 Posts: 16,916
    These are made of 6061 T6 Aluminum..
  • hochpt21
    hochpt21 Posts: 5,423
    I think it looks sweet. Look forward to seeing a complete speaker.
  • gimpod
    gimpod Posts: 1,793
    Looks nice! Larry.
    It only took you what 6 years after I asked you about it. Put me down for a set for my 1C's. (powder coated) :wink:
    pitdogg2 Posts: 24,585
    Larry do they sammich to the inside rings?
    nooshinjohn Posts: 25,102
    I love the concept Larry, but I do think the screw heads should be countersunk and flushed, or have the rings be threaded through from the inside with no screwheads showing at all. Still trying to wrap my head around bolting things together however...
  • tonyp063
    tonyp063 Posts: 1,048
    edited May 2017
    AndI'll disagree with that. I like the contrast & the industrial look. But.
    De gustibus non est disputandum.
  • westmassguy
    westmassguy Posts: 6,850
    Are they strictly decorative Larry, or do they exert pressure on the rubber surrounds when torqued down?
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • Gerres26
    Gerres26 Posts: 863
    I don't know if they add anything sonically but they sure do look nice.
  • gimpod
    gimpod Posts: 1,793
    edited May 2017
    I don't think it really maters so as long as they don't interfere with the flexible part of the surround, They would keep one from over torquing the mounting screws and dimpling the baskets.
    (One of these days I'm gonna learn how to speall).
    Post edited by gimpod on
    VR3 Posts: 28,052
    I know diffraction is not as important on the SDA design but that was my first thought with these rings... now the stock grills are basically one big diffraction point, but my thoughts for the rings directly correlate to the tweeters
    VR3 Posts: 28,052
    On the flip side, building an insert that brings the baffle flush with the grill... I think that would actually bring some nice positive improvements - kind of like the RTi series and their anti-diffraction baffles.6qu8pmcec7kx.jpg
  • muncybob
    muncybob Posts: 2,973
    They look good to me...would look better if the screws were the same color.
    Yep, my name really is Bob.
    F1nut Posts: 49,806
    Studying the pictures I can say they do not touch the rubber at all on the mid-drivers and maybe just slightly on the outer edge of the PR.
  • westmassguy
    That's what I was getting at. The rubber could actually move or creep under stress, and buckle up.
    edited May 2017
    These do not touch the rubber at all, and I don't think that would be a good idea, I could see it becoming a very big issue down the road if not right away..
  • westmassguy
    Toolfan66 wrote: »
    Excellent. That was my only concern Larry.
    They look sweet!
    txcoastal1 Posts: 13,132
    edited June 2017
    That's sexy and so clean....looking forward to the top and side mods.
    Are you making matching tweeter bezels?
    ...for good reason you're fidgeting ;) ....just a couple more days
    I'm not happy with the tweeter bezels, I'm going to leave them stock for now..
  • vmaxer
    vmaxer Posts: 5,116
    Toolfan66 wrote: »
    Your tweeters are MIA??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    So is the passive, and x-overs :D:D
  • vmaxer
    vmaxer Posts: 5,116
    Toolfan66 wrote: »
    Very nice.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
